Old Mar 28, 2012, 06:09 PM
Joined Jan 2010
"Giant 15Kwatt Foamy Jet"
Over the years I have done number of triptych paintings mainly of marine subjects depicting 'romantic days of sail'. So I got this great idea why not build "TRIPTYCH" EDF jet. The main 7.5Kwatt 127mm fan will be supported on each side by 4Kwatt, 90mm unit creating some 16kg thrust. Three ESCs with total 420 Amp capacity will supply power from four 6S and four 4S/4-5Ah batteries. The whole model is being build from 6mm sheets of foam using my lamination method and over 30 meters of C/F. Aprx. 10x7 feet model is expected to weight 12-15kg inc. 5-6kg in batt. I'm so exited about this monster that I'm already well ahead with my build time schedule to see if I can make it or brake it? Joe.
jofro is offline Find More Posts by jofro
Old Mar 28, 2012, 06:28 PM
USA
Joined Apr 2007
that ' all
space 1 is online now Find More Posts by space 1
Old Mar 29, 2012, 03:43 AM
Joined Jan 2010
More progress on the way, Joe.
Old Mar 31, 2012, 04:45 AM
Joined Jan 2010
I loaded it up today with all the bits to get some idea about my batteries placement to minimize the length of leads. Will have to solder on 8 extra capacitors to my 3 ESCs.
Old Mar 31, 2012, 11:58 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You need to fill us in on some specs!! All CS fans? Battery weight? You might consider some channel iron in the center section, to hold all those batteries!! At least some CF.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Mar 31, 2012, 01:03 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Holy Batterys Batman!
D_FAST is offline Find More Posts by D_FAST
Old Mar 31, 2012, 01:57 PM
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Looks GREAT Jo!!! keep up the great work.
falcon5 is offline Find More Posts by falcon5
Old Mar 31, 2012, 03:52 PM
kings lynn, norfolk uk
Joined Sep 2007
Wow.... that a lot of battery, looks good so far
peter24 is offline Find More Posts by peter24
Old Mar 31, 2012, 04:52 PM
A Texan abroad
torque roll's Avatar
Joined Oct 2011
Holy $h!t
That's downright impressive! I hope you are successful! Good luck!
torque roll is offline Find More Posts by torque roll
Old Apr 02, 2012, 05:43 PM
Joined Jan 2010
Thanks for all above comments, I'm pleased to say the frame is complete and starting to hand paint the whole thing today firstly applying base coat to spot all the dints. Originally I expected AUW to be 12kg but after ading all the bits it will end up minimum 15kg.The paint alone might be 1/2kg after some 3 coats. Bit of the set back as I decided to upgrade, to double my Elevon servos to 4 and new stronger Elevon controls will be made up just for the piece of mind, Joe.
Old Apr 02, 2012, 10:11 PM
Joined Jan 2010
Painting is on the way starting with the belly, Joe.
Old Apr 05, 2012, 03:41 AM
Joined Jan 2010
Painting is going well and at the same time making up the landing gear. My booster power units were align and formers well anchored to the frame so I can start now on the nightmare of the electronic hook up, it is going to take lot of soldering of heavy 8 gauge leads and connectors not very enjoyable job but it has to be done. I only wish there were more hours in the day, Joe.
Old Apr 05, 2012, 04:19 AM
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Very nice! I've been designing something a little different myself over the last few months. Looking forward to seeing more of your progress
PS I like the idea of the different sized fan units. This should give you a unique sound.
Eddie P is online now Find More Posts by Eddie P
Old Apr 10, 2012, 04:36 AM
Joined Jan 2010
Great news, first day after Easter received the extra two servos needed to hook up my completed Elevon controls. Nearly 18kg torque on each control gives me now piece of mind. Joe.
Old Apr 10, 2012, 07:12 AM
USA
Joined Apr 2007
Is that a gyro I see in last pic
Discussion Giant Foamie Home Depot F-15 Otto Dieffenbach Foamies (Scratchbuilt) 809 Sep 08, 2014 09:51 PM
Discussion Giant Foamie Home Depot YF-22 Otto Dieffenbach Foamies (Scratchbuilt) 1049 Aug 26, 2014 03:12 AM
Discussion "15Kwatt, TRIPTYCH" foamy jofro Foamy EDFs 52 Jan 29, 2013 04:58 PM
Discussion 15Kwatt "Quad Finned Triptych" Foamy Jet. jofro Foamies (Scratchbuilt) 16 Apr 13, 2012 04:37 AM
For Sale 3D Foamy F18 Park Jet Kit nxtdoor Aircraft - Electric - Airplanes (FS/W) 1 Feb 27, 2012 11:01 AM
