Old Feb 22, 2012, 10:54 PM
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Question
what is 27% MAC?
yes, it seems to be another dumb question. my manual states "for CG proper position should be at 27%MAC.
(is this telling me the distance from the leading edge?)
how many inches/cm/mm is 27%MAC? (im confused lol)
out of stock is offline Find More Posts by out of stock
Old Feb 22, 2012, 11:19 PM
USA, IL, Wheaton
Joined Oct 2010
MAC is Mean Aerodynamic Chord
Hi
Once you get past the acronym, this isn't hard to figure. Mean Aerodynamic
Chord (MAC) is the width of the wing taken as an average over its span. If the wing is a simple rectangle in shape, you simply measure from the leading edge to the trailing edge to get the chord, which is also the MAC. Multiply that by 0.27 to find where the CG should be. Then mark it on the wing, measuring from the leading edge. For simple tapered wings, you add up the chord at the tip and the root and divide by 2. If you have a wing with straight and tapered sections, you need to factor in the areas of the different pieces. The average chord of the straight part times the fraction of the wing area it represents is added to the average chord of the tapered parts times their area fraction. It gets a bit more complicated if the airfoil changes from point to point.
Regular looking model wings use the simpler averaging. Don't ask me to do a Spitfire wing in my head. You can get close by using the chord half way out on the wing. Deltas are the trickiest for this. If you're modeling an B-70, you may just need to build a cardboard model and add paperclips to the nose till you get it right.
When you express things this way, it allows you to change the wing top view and still get a reasonable way to find the CG.
Hope this helps
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Feb 22, 2012, 11:28 PM
DONT PANIC! :)
Joined Jan 2012
thanks joe. ill have to read this a couple more times lol. i have an aerobatic 3d plane.
i was told a good point to start is at the thickest part of the wing or the wing tube.
Old Feb 23, 2012, 12:34 AM
DONT PANIC! :)
Joined Jan 2012
my browser is buggin. sorry for the double post.
Old Feb 23, 2012, 12:36 AM
DONT PANIC! :)
Joined Jan 2012
actually by looking at this illustration i found actually helps and should or will eventually help someone else. (although this pic only represents rectangular wings. mines is an sbach wing i guess)
so what im looking for is 27% of my MAC from the leading edge? feel free to correct me.
Old Feb 23, 2012, 08:40 AM
USA, IL, Wheaton
Joined Oct 2010
Out of stock
I found the calculator you need from a quick Yahoo search. The National Association of Scale Aeromodellers has an on line calculator and a very good diagram here to go from wing planform and % MAC to CG position at the wing root.
http://www.nasascale.org/howtos/cg-calculator.htm
You've got the idea for the rectangular wing. If you run that calculator, you should get the tapered wing too.
Old Feb 23, 2012, 10:38 AM
DONT PANIC! :)
Joined Jan 2012
Originally Posted by DuPageJoe View Post
Out of stock
thank you so much! so my wing is called a tapered wing? i dint know. thanks ever so much!
Old Feb 23, 2012, 10:44 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Here is a very good CG calculator that also take the tail area and distance into account.
There is also the facility to change the 'Static Margin' for sensitivity.
http://www.geistware.com/rcmodeling/cg_super_calc.htm
There are also calculator around on the forums for canards, and flying wings.
eflightray is online now Find More Posts by eflightray
Getting out of RC what to trade my stuff for a IPod or other Mac stuff JStory Aircraft - Electric - Airplanes (FS/W) 15 Feb 25, 2003 03:46 PM
