Old Sep 14, 2006, 01:35 PM
rumme is offline
Find More Posts by rumme
Joined Apr 2004
9 VOLT rechargeable battery question....
I just purchased some 9volt- nimh 250 mah rechargeable batteries. I have not put a charge on these yet and do not plan to use them right away, they are for emergency use. What is the best way to store them and ensure the longest life and how long can I expect the batteries to stay good for, unused? Should I put a full charge on them 1st then store them away in a cool dark place, like my basement or store them uncharged as they came ? Also, does anyone know what the mah rating is on a normal 9 volt non-rehcargeble battery..like duracell or eveready ?
rumme is offline Find More Posts by rumme
Old Sep 14, 2006, 01:45 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
According to Energizer thier 9V is 565 mAh
http://data.energizer.com/SearchResult.aspx
IMO you would be better of using non rechargables for emergency.
I would store them charged in a refrigerator in a sealed zip lock bag. Let the battery come to room temperature before opening the
bag.
Charles
Old Sep 14, 2006, 01:50 PM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
for emergency, well yes i whould also recommend using some brand alkaline,
they are expensive, but many years of sheld life, and realiability.
z-matrix is offline Find More Posts by z-matrix
Old Sep 14, 2006, 01:51 PM
rumme is offline
Joined Apr 2004
Thnaks Charles...I also see they are now making lipo rechargeable 9VOLTS..with a 550 mah rating..of course they need a special charger..
Old Sep 14, 2006, 01:52 PM
rumme is offline
Joined Apr 2004
yes, I agree..and I do have normal 9 volts to for emergencys...along with solar/hand crank radios/lights..etc..
Old Sep 14, 2006, 02:05 PM
Southern Pride
For emergencies I have many deep cycle 12 volt batteries that range from 4Ah to 88 Ah an invverter (12 VDC to 120AC) a buch of AA high capacity NiMH cells and ofcourse a buch of 12VDC powered chargers to charge the AAs and my many Liolys. I have modified one of my Ham Radio Dual Band HTs to use a 3S LiPoly.
The 12 volt deep cycles (large ones) can be charged wth my truck or SUV and then there is always my 7000 Waty cont. / 12,250 watt surge generator that will run my whole house if I use a little common sense and try to run everything at the same time..
I am curious as to why a 9V is needed for emergency.
Charles
Old Sep 14, 2006, 03:07 PM
rumme is offline
Joined Apr 2004
Well I didnt say they were " needed" ..I just wanted to have a few around as backup.
Old Sep 14, 2006, 03:22 PM
sfsjkid is offline
Find More Posts by sfsjkid
Japan, Mie Prefecture, Ise
Joined Aug 2004
I think they would be good for a small radio and what not. I also think that alkalines are the way to go, even after 4 years of storage at 70 degrees, they'll have 85% of their capacity left. Nicads & Nimhs would self discharge in months unless they were left on a trickle charger. Haven't done any research on lithium though. Good luck!
http://www.steatite.co.uk/batteries/...y_alkaline.htm
sfsjkid is offline Find More Posts by sfsjkid
Old Sep 15, 2006, 08:49 AM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I just went thru the same thing and finally decided on some 1200 lithium primary batts for smoke alarms, scales, dvms, ect. I was getting tired of rechargeing nimh batts.
Then I wnt and doubled order by mistake, doh.
gulio is offline Find More Posts by gulio
Old Sep 15, 2006, 12:35 PM
Red Scholefield is online now
Find More Posts by Red Scholefield
Molon labe
Red Scholefield's Avatar
USA, FL, Newberry
Joined Nov 2000
Sounds like someone may be working marketing magic on you.
1) rechargable 9 volts are more likely to be 7.2 volts.
2) The mAh rating of Energizer rechargable Ni-Mh "9v" is 175 mAh.
Understand that the charge retention of Ni-Mh is rather poor, you would be lucky to have much charge left after 3 or 4 months.
Red Scholefield is online now Find More Posts by Red Scholefield
Old Sep 15, 2006, 12:54 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
My old generic ones are 7 cells at 170 mah. The newer ones are supposed to be 250 mah.
The primary lithium cells I bought are supposed to be 5 -10 years and 1200 mah. I am thinking of sacrificing one for a test since I got twice as many as I wanted.
Old Sep 15, 2006, 01:44 PM
Barry2 is offline
Find More Posts by Barry2
Joined Apr 2006
My apologies for this being slightly off topic, but considering the limitations of the 9V battery format in both disposable and rechargeable forms (expensive, low capacity, etc.), I have given up on it and only use electronics that run on a better format, particularly AAs. You can even get smoke detectors that run on AAs now, as well as virtually anything else.
But good luck with your 9V batteries.
Barry2 is offline Find More Posts by Barry2
Old Oct 24, 2006, 09:51 AM
Frankenator is offline
Find More Posts by Frankenator
Canton, Michigan, United States
Joined Nov 2000
400mAh Lithium Ion / 250mAh NiMH 9 Volt batteries
I just ordered some 9 volt 400mAh lithium Ion batteries and one 250mAh NiMH battery to try for my wireless mikes at our church. I will let you guys know what I find out with them. I like the fact that the lithiums can be recharged in full in ~ 1 hour. The others require an overnight charge. I ordered them from here: http://www.batteryspace.com/
One thing to note right away is that the NiMH batteries are bigger in size than alkalines and the lithiums are even bigger. It's a matter of .5 to 2 mm, but in some cases that is enough to not make it fit in what you want to power with them.
Your original question was on using rechargeables for emergency purposes. I would do what some of the other guys recommended and use alkalines or the primary lithiums (1200mAh) for this purpose. The NiMhs need to be used right away to get the maximum capacity out of them.
Frankenator is offline Find More Posts by Frankenator
9 volt battery power for e-planes? Tres Wright Parkflyers 47 Jul 28, 2002 11:33 AM
Just got a Rayovac 9 volt NiMH battery will this work on an IFO?> JStory Electric Plane Talk 7 Aug 06, 2001 06:23 PM
Anyone please help - Can a 7.2 volt charger charge a 9 volt Battery pack? Jamie- Electric Plane Talk 5 Jul 29, 2001 07:49 PM
Rayovac 9 volt Battery found on-line. PaulNJ Parkflyers 0 May 12, 2001 12:23 AM
sanyo cells in 9 volt battery frankenfoamy Electric Plane Talk 3 Apr 28, 2001 11:29 PM
