Old Jun 06, 2006, 03:57 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
T-Rex tracking questions
I have been trying to document the correct procedure for adjusting the tracking based on the picture below from the manual. It states to adjust the linkage rods "A" and linkage rods "D". It does not however define which way to adjust them.
From my experience the following seems to be correct. I am hoping that someone can confirm this:
To adjust the HIGHER blade:
--For large variations, INCREASE the length of linkage rod "A"
--For slight variations, DECREASE the length of linkage rod "D"
To adjust the LOWER blade:
--For large variations, DECREASE the length of linkage rod "A"
--For slight variations, INCREASE the length of linkage rod "D"
More questions:
Is there any reason to adjust the lower blade versus the higher blade or vice versa?
Does adjusting the tracking change the original swashplate leveling settings and or the original zero pitch settings during initial setup?
John
JohnM is offline Find More Posts by JohnM
Old Jun 06, 2006, 04:42 PM
nregjeb is offline
Find More Posts by nregjeb
Mount Joy, PA
You have it correct.
I put a mark on the grip and on the blade so they stay matched up if I have to disassemble for any reason. I then just make the adjustment for tracking on the marked side of the head. If blades are out of track....I make a change to the marked side. Choose to increase or decrease pitch....just pick one....if tracking gets better keep adjusting in that direction. If it got worse. Go the other way.
Simple and works. As long as I have a good background to see. Normally takes a one to four changes to have 'razor' edged tracking. Your ears will also learn to hear when it is correct. (head speed increases a little and blade sound gets crisp....especially with carbons.)
Take the time to get them right. It makes a big difference in performace.
Jim
nregjeb is offline Find More Posts by nregjeb
Old Jun 06, 2006, 07:02 PM
ShuNut is offline
Find More Posts by ShuNut
Hotep
ShuNut's Avatar
UK
Joined Dec 2005
Finless has a vid on blade tracking, check the sticky thread.
ShuNut is offline Find More Posts by ShuNut
Old Jun 06, 2006, 07:55 PM
JohnM is offline
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Thanks for the tips nregjeb and I will download that video Shunut. It must be a new one.
John
Old Jun 07, 2006, 04:35 AM
Rickenbacker is offline
Find More Posts by Rickenbacker
Sunday Flier
Rickenbacker's Avatar
Sweden
Joined May 2005
I could never see those damned colored stickers, so I quit putting them on and marked one of the grips. Now I only ever adjust the marked side.
That said, as long as I set up the pitch to be the same during the initial setup, the blades pretty much always track right from the start.
Rickenbacker is offline Find More Posts by Rickenbacker
Old Jun 07, 2006, 10:22 PM
Kam is offline
Kam
Find More Posts by Kam
Kam
Yokine, Perth, Western Australia
Joined Feb 2006
Once ur pitch is setup, u need to mark one side, and adjust tracking on that side ONLY. If u start adjusting both sides, u will soon lose ur pitch setting. Instead of having +/-11 degrees, u'll find oneday that ur running, say +9, -13 or +12, -10 etc.
Kam is offline Find More Posts by Kam
Old Jun 08, 2006, 12:09 AM
arclite5 is offline
Find More Posts by arclite5
Joined Nov 2005
I found that trying to adjust the tracking of the blades by "trial and error" usually takes more time than is worth it. I bust out my pitch gauge and adjust till both blades show 0 pitch at mid-stick in throttle hold (linear pitch curve). Then they're both perfect, and when I spin it up after replacing the blades TADAW! perfect tracking.
I love perfectly tracked blades.
Makes me feel confident.
Other than that, my little thing for adjusting the lengths is "L for lower, R for rise" as in left turn = lowers the pitch, right turn = raise the pitch. Of that one particular blade of course.
arclite5 is offline Find More Posts by arclite5
Discussion T-Rex 450 questions - align 35a bec ormandj Mini Helis 7 Jul 01, 2006 09:38 AM
T-Rex 450X Questions rich_hodgetts Mini Helis 1 Sep 24, 2005 02:50 PM
T-rex fuselage questions and answers. darthdrk Mini Helis 9 Jul 11, 2005 04:41 PM
T-rex tracking video genexis Mini Helis 7 May 08, 2005 03:50 PM
T-REX tracking issues fixed ChrisT88 Mini Helis 16 Jan 13, 2005 02:47 PM
