Old Jul 21, 2015, 09:11 PM
jegouvrc is offline
Find More Posts by jegouvrc
jegouvrc's Avatar
United States, FL, Kendall
Joined Jun 2015
Video
A Flite Test Simple Soarer with a modified wing
This plane is the Simple soarer from Flite Test. What I did was used the same wing template but without the polyhedral angles and I added ailerons With 2, 9oz servos and a Y connector.
for the radio I'm using the same TacTic That came with R.F 7.5 ( it came with a free 6 channel receiver ) so I only bought the servos and a 6v Rx battery pack.
My first attempt to fly after 25 years. This is the one of the few slopes close to where I live. but the wind was blowing about 45 Degrees into the slope so I tried my best to keep the glider on the slope. This is a Scratch-build foamy so I wasn't expecting to fly that well. If you see it flying funny sometimes is because I was testing different C.G's and sometimes was tail heavy others were nose heavy. The wind was dying on me at the end so I had to stop.
winds were around 8-12 mph. at the end went down to the 5-8 mph
FT Siple soarer with a straight wing (4 min 8 sec)
now I'm waiting for the new servos, extensions, "y" connectors for my other project. the 90 Inch wing span glider. so I can Finish it and make a video of it too.
jegouvrc is offline Find More Posts by jegouvrc
Old Jul 22, 2015, 01:40 AM
boa2110 is offline
Find More Posts by boa2110
United States, AZ, Tucson
Joined Apr 2012
Nice plane and good flying. I wish I had a gentle slope to fly off.
boa2110 is offline Find More Posts by boa2110
Old Jul 22, 2015, 07:16 AM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
I still have more room for improvements on the glider. I'm slightly changing the angle of the horizontal stabilizer It wasn't penetrating like I wanted... Its like a huge elevator now. I had to trim it full to compensate the elevation creating unnecessary drag .
I'm fixing that and I'll give it a new test flight.
Thanks.
Old Jul 22, 2015, 02:41 PM
kcolraw is offline
Find More Posts by kcolraw
Kcolraw
United States, NC, Asheville
Joined Feb 2015
To slow .... needs a couple edf's. J/k.
I would love to find a place around me for some slope soaring, never tried it.
kcolraw is offline Find More Posts by kcolraw
Old Jul 22, 2015, 03:36 PM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
jegouvrc:
Nice flying after 25 years. Thanks for the great video. It was atreat!
Dave-
foamdave is online now Find More Posts by foamdave
Old Jul 22, 2015, 06:09 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
Originally Posted by foamdave View Post
jegouvrc:
Dave-
RF 7.5 Helped
Thanks Dave.
Old Jul 22, 2015, 08:48 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
Once I get it right. This plane should glide like a sailplane is meant to glide.
I'm fixing the angle of the horizontal stab. This should make the glider fly faster. Even when the wing is flat, the airfoil doesn't help much is an under-cambered style airfoil (High Lift, Low Speed).
I'm not an expert with glider but I read in an article that sometimes you need to add more weight to the glider (ballast) so it can generate more energy to penetrate the wind and convert it to lift.
The best way to find out is by trial and error. so I'm preparing different sets of small weights That I can Add with Velcro in the CG of the plane and test it next time I fly it. maybe that will help with the speed issue.
The good things about foamies is that with basically $ 2.00 I can make another wing with a better airfoil for more speed.
Old Jul 22, 2015, 09:02 PM
ant0 is offline
Find More Posts by ant0
Joined Jul 2013
Nice flying! Welcome back!
ant0 is offline Find More Posts by ant0
Old Jul 22, 2015, 09:27 PM
kcolraw is offline
Kcolraw
Joined Feb 2015
I had built a DLG glider but with where I fly the winds change from day to day it seems. It would glide well after a toss but there just wasn't enough wind. I will build another one perhaps with even lighter wing loading.
Old Jul 22, 2015, 10:04 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
Old Jul 22, 2015, 10:19 PM
jegouvrc is offline
jegouvrc's Avatar
Joined Jun 2015
You should...
With the right conditions... gliders can be fun
There has to be a park or place even with a small slope 10-20 feet that should give you enough lift for a DLG.
This video I did it on a 15-20 feet slope by about 150 feet wide. and the wind was on the 15-18 mph range
FT Simple Glider At VistaView Park (5 min 0 sec)
For Sale Flite test simple storch with power pack. mikesoby Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jul 22, 2015 11:26 AM
Cool Can a traxxas stampede 4x4 auto tow the FT Simple Soarer? mvch Sailplane Talk 15 Feb 27, 2014 11:35 AM
Discussion Flite Test Simple Soarer Electric abieex Electric Sailplanes 7 Feb 23, 2014 09:26 PM
