Old Jun 26, 2014, 08:05 AM
bamiller is offline
Find More Posts by bamiller
bamiller's Avatar
United States, CO, Castle Rock
Joined Dec 2009
70mm EDF 10 blade Fan Unit
Greetings...
Wondering if this unit will support the following motor / esc combination.
http://www.nitroplanes.com/53p-20014.html + http://www.nitroplanes.com/60p-dy-10...resccombo.html
Would be running on 4s
Many thanks.
-B
bamiller is offline Find More Posts by bamiller
Old Jun 26, 2014, 12:23 PM
RaidenCharlie is offline
Find More Posts by RaidenCharlie
HobbypartZ Support
Joined Jul 2011
It will work but I would still recommend putting a watt/amp meter to it to see how much it's drawing to make sure that the included ESC can support the system.
RaidenCharlie is offline Find More Posts by RaidenCharlie
Old Jun 27, 2014, 08:10 AM
bamiller is offline
bamiller's Avatar
Joined Dec 2009
Thanks. Would there be a better setup you would definitely recommend?
Old Jun 27, 2014, 12:01 PM
HobbypartZ Support
Joined Jul 2011
From us no, the combo that you have listed is the closest thing we have to the manufacturer recommend motor for 4S usage. The other motors that we have is either to low or to high in KV.
Wanted Dual 70mm EDF fan units ricebowl1988 Aircraft - Electric - Jets (FS/W) 0 Apr 22, 2014 02:22 PM
Sold High-Speed EDF Ducted Fan Unit 3Blade 2.75inch 70mm Pusher Fan Unit with ARC 28-58-1 brandonmoon Aircraft - Electric - Jets (FS/W) 2 Dec 15, 2013 09:28 PM
Sold High-Speed EDF Units 3Blade 2.75inch 70mm Pusher Fan Unit with Cyclone C2800 brandonmoon Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 09:27 PM
Sold 10 Blade Alloy DPS 70mm EDF unit - 4s 3000kv 1200watt awayne Aircraft - Electric - Jets (FS/W) 2 Nov 15, 2013 06:06 PM
Sold Cyclone 64mm EDF fan unit and Chagesun 70mm EDF fan unit The Don Aircraft - Electric - Jets (FS/W) 2 Jan 25, 2012 04:14 PM
