Old Apr 04, 2013, 07:56 AM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Tidying up wires to the wing
I want to tidy up the wires to my wing which are currently a mess.....
I have 2 x ailerons, 2 flaps, 2 gear and lights... this makes for a lot of wires and connectors and Y-splitters.
I've seen an install using MPX connectors which can connect 6 wires.... and supposedly rated at 30A. This is a small plane.... with less than 5A on the RX circuit.
So I was think I could use a common +ve and -ve for all the wing servos power and then carry the signal to each of the flaps, gear, aireron and lights one the 4 remaining wore connections. This would give me one connector and take away a lot of the mess and hassle.
Has anyone done this? Any tips, thoughts or advice? Thanks.
Toppers is offline Find More Posts by Toppers
Old Apr 05, 2013, 03:01 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I have never actually used them, the most I have had to connect at one location is three, I usually stick double sided foam tape to the connectors to form a block.
Some people use the 9 pin sub 'D' connector.
A search on, MPX connector, and on, D connector, setting the search for thread titles should find a few threads, here's one on the 'D' -
9 pin D-Sub connector source?
The glider guiders are probably the main users, aileron, flaps, brakes, etc.
eflightray is online now Find More Posts by eflightray
Old Apr 06, 2013, 12:41 PM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
I have some like that on my larger scale machines with removable wings/panels, so picked up some multi-connector bits from Hansen Hobbies booth at the Toledo Show yesterday. They basically are set up so you only need to unplug one pair at removal. As I make my own extensions this is relatively simple setup:
http://www.hansenhobbies.com/product...1inconnectors/
Cougar429 is offline Find More Posts by Cougar429
Old May 27, 2013, 06:13 AM
Mark Derbyshire is offline
Find More Posts by Mark Derbyshire
Mark Derbyshire's Avatar
United Kingdom, England, Salisbury
Joined Jul 2011
I am slowly converting all mine over to the Multiplex 6 pole connectors. I gang up the +ve and the -ve and use the outer two pins as the + and -. If you look closely these pins are actually marked + and -
This leaves 4 pins for signals
Mark
Mark Derbyshire is offline Find More Posts by Mark Derbyshire
Old May 28, 2013, 08:34 AM
Toppers is offline
Toppers's Avatar
Joined May 2008
Yes, this is what I did and it seems to work fine.
I'm still a bit concerned that a solder joint to the MPX connector may come lose... but it is so much more convenient.... just takes a lot of guts to start cutting off the servo connectors.
Old May 28, 2013, 04:20 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
el cheapo D plugs are ideal, as you can get them in a variety of sizes to suit the number of plugs etc, plus you can mount them so they auto-connect when you attach the wings.
Helpfully they have numbers on the back, so simply jot the numbers down on a bit of paper ie:
Pin Function
1 Aileron +ve
2 Aileron -ve
3 Aileron sig
4 Flap +ve
etc etc.
Its not as intimidating as it sounds and has the benefit that you can cut off the connectors for extension leads and have one less connection to worry about.
I bundled the leads going to the rx inside a spiral cable tidy, once connected to the Rx, keeps them all out of the way.
MCarlton is offline Find More Posts by MCarlton
Old Jun 21, 2013, 07:27 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
If the standard 6 pin Multiplex connector doesn't work, there is an 8 pin version as well (panel mount version is nice for wings)
http://www.rcmicroflite.com/E-Powers...air_p_332.html
http://www.espritmodel.com/multiplex...tors-8pin.aspx
ltc is offline Find More Posts by ltc
ltc is offline
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
You can also buy the housings for 6 pin Multiplex connectors for more standard wings
http://www.espritmodel.com/multiplex...sing-pair.aspx
Old Jun 21, 2013, 07:37 AM
Joined Jul 2011
I've been trying to source some 8 pin mpx connectors in the UK but no one seems to stock or import them. Same with the secure clip for the 6 pole ones. I can get them from Germany but they want 16GBP for shipping! !! - a bit excessive me thinks for a pack of 5
Mark
Old Jun 21, 2013, 07:57 AM
ltc is offline
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Can Espritmodels send them to you?
Have you asked Paul at Electricwingman?
Old Jun 21, 2013, 02:37 PM
Joined Jul 2011
I got the 6 pole ones from Electricwingman. I'll ring him when I get back in the UK. If not I may take you up on your offer
Mark
For Sale Servo wire running tool for wings and fuselage! unclegeorge Aircraft - General - Miscellaneous (FS/W) 2 Apr 01, 2013 09:11 AM
Discussion Spektrumized and tidie'd up Eco ;) Chachin Electric Heli Talk 13 Mar 20, 2007 09:27 AM
Trex tidy wires? stevenkelby Mini Helis 34 Nov 22, 2005 11:39 AM
