Old Oct 02, 2012, 10:13 PM
lennyk is offline
Find More Posts by lennyk
Joined Dec 2003
Burnt Turnigy 3536 1400
Well I finally burnt my Turnigy 3536 1400 motor.
It's a 12n14p, would like to rewind it and get it back working.
Does anyone know if this is standard 12n14p dLRK ?
I see that the stator has "12t" written on a couple teeth.
Anybody rewound these and used same 12 turns ?
thanks,
L
lennyk is offline Find More Posts by lennyk
Old Oct 03, 2012, 06:58 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
http://www.rcgroups.com/forums/showthread.php?t=1673722
Similar motor which was dLRK delta. With a good set of wires on it the motor will be significantly more powerful and efficient. If the Kv is good for your application I would stick with it. When I wound the 3530 I counted 13T on the only tooth that came unwound. I later discovered the spec was 14T. The slightly higher Kv worked out fine when compared to the OEM wind in the test charts on fly brushless. Don't be surprised when you unwind it that the turn count is inconsistent from tooth to tooth.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Oct 03, 2012, 07:41 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
As you can see in his thread, zeroback learned that removing the green factory insulation coating from a stator with glued windings really adds some work to a rewind. But a stubborn motor re-winder does not give up easy on dead motor.
We had a good thread show up here a few months after he did that and it surfaced some good methods for getting glued windings off using heat rather than solvents. That thread is here:
Removing old windings? - http://www.rcgroups.com/forums/showthread.php?t=1709338
Saving the original coating will really speed up the rewind. If you can get a count on the turns or even an approximate count it will help with choosing the new Kv if you want to adjust that.
Jack
jackerbes is offline Find More Posts by jackerbes
For Sale ParkZone F4F Wildcat custom aluminum motor mount for Turnigy 3536 solarr Aircraft - General - Miscellaneous (FS/W) 2 Apr 28, 2012 04:33 PM
For Sale NIB Turnigy SK 3536-1400 kV Motor RC4RS Aircraft - Electric - Power Systems (FS/W) 2 Apr 23, 2012 08:12 PM
Sold 5 Turnigy 2830-1050kv, 3536-1100kv, 2730-1500, BL 22-2216/6 2200kv joesmith285 Aircraft - Electric - Power Systems (FS/W) 6 Mar 16, 2012 10:04 AM
Found anyone have a 3536-1400 laying around? Doubledog Aircraft - Electric - Power Systems (FS/W) 2 Jan 12, 2012 12:57 AM
Discussion Trying to modify a Parkzone T-28 with a 3536-1400 Rich in ILM Electric Warbirds 3 Jan 24, 2011 09:56 AM
