Old Jun 07, 2015, 03:57 AM
asaad_civic99 is offline
Find More Posts by asaad_civic99
United States, IA, Ames
Joined Jun 2011
My selected board in tools-> Board is Arduino mega 2560
and in the APM_config.h file it is crius_v1
I have the HK AIO board by the way.
Does this error has anything to do with HAL_board under ArduPilot?
asaad_civic99 is offline Find More Posts by asaad_civic99
Old Jun 07, 2015, 04:07 AM
TheQuestor is online now
Find More Posts by TheQuestor
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
umm wrong area sorry
There should be a dropdown tool called ArduPilot and make sure you select MegaPirateNG.
If they aren't there then see if my tool works
http://www.computerguy.ws/Apps/MPNGBuilder/
It crashed on me when I ran it now but I clicked continue and it seems to have worked.
Anyway it downloads and sets up everything so you can build your own and then walks you through most of the needed settings.
I wrote this a long time ago and since then have ...um....misplaced the source code and I don't really feel like re-writing.
TheQuestor is online now Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Jun 07, 2015, 04:11 AM
Joined Jun 2011
I have a drop down menu for ArduPilot -> Hal_board ->
I have three options :
1-none
2-ArduPilot mega 1
3-ArduPilot mega 2.x
Old Jun 07, 2015, 04:22 AM
TheQuestor's Avatar
Joined Mar 2013
1-none
2-ArduPilot mega 1
that means you missed copying over the java file and possibly the libraries and why it is trying to compile for a board other than the one you are compiling for.
Run my installer, it will set that all up and all you will then need to do is tweak any of the sketch and click upload
Old Jun 07, 2015, 06:50 AM
Joined Jun 2011
Tried your software but I couldnt manage to flash it. I desperately tried the flashtool 1.1r2 and it worked finally.
thanks for your help. I really appreciate it
Old Jun 12, 2015, 06:59 AM
ben749 is offline
Find More Posts by ben749
Joined Oct 2014
Hello, is there any nice tutorial upon
1) getting the crius pro & associated GPS module
2) the whole configuration for enabling rth upon a quadcopter ?
Thanks for any advice
ben749 is offline Find More Posts by ben749
Old Jun 13, 2015, 05:26 AM
geofrancis is offline
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
get a cheap apm from ebay it will work with mission planner without any messing around with arduino.
geofrancis is offline Find More Posts by geofrancis
Old Jun 13, 2015, 05:54 AM
TheQuestor's Avatar
Joined Mar 2013
This is about as good as you're going to find.
I've attached all the PDFs I used to use with these boards
Old Jun 13, 2015, 04:02 PM
Joined Jun 2011
There is a nice tutorial on youtube done by rcjoseb multirotors. It was done 1 year ago. Since then, there is a simple flash tool to upload the megapirate firmware easily on the board
Old Jun 13, 2015, 04:07 PM
Joined Jun 2011
I just got my ublox neo 6 m GPS working on my board. I have already flashed my board with megapirateng 3.1.5 firmware. My setup is an X quad. Just want to know your thoughts if this is the best firware version or ai should upload an older version
Old Jun 14, 2015, 01:56 AM
Joined Jun 2011
Im powering my board from the usb connector and my GPS is has power from I2C connector.
Is it ok if I power my board from external power (UBEC) while connected to the laptop?
I will eventually need to do this in order to plan for missions in the missions planner while the GPS gets power from the S1-S3 port
Old Jun 18, 2015, 10:03 AM
Joined Jun 2011
Hey guys, I have encountered another obstacle:
I have flashed my board with 3.1.5r2 firmware using the latest version of the flash tool. I hooked up e board via USB and started the calibration process. When I got to the part of calibrating the RC, non of the sliders in the mission planner moved when I moved my sticks.
i am using an old FM transmitter with a corona synthesised Rx. I have choosen the PWM from A8 to A.... What could be the problem?
Old Jun 18, 2015, 02:45 PM
Joined Feb 2010
you have to set pwm on the flasher default is ppm. if that doesnt work get a ppm encoder.
Old Jul 08, 2015, 11:55 PM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
hello
I radio Turnigy 9x and Crius AIOP v2 hobby-king.
that in choosing Flashtool MultiWii? or Standard?
thank you
magik30 is offline Find More Posts by magik30
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 30 May 14, 2014 09:52 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
