Old Mar 01, 2011, 06:21 AM
theflyingeagle is offline
Find More Posts by theflyingeagle
theflyingeagle's Avatar
Ouderkerk a/d ijssel (Holland)
Joined Dec 2006
LED's on a Brushless ESC
Hi all,
Is it posible to conect leds between the 3 wires of a brushless ESC.
Will it affect the ESC or not...
Is there someone who can tell me more...?
theflyingeagle is offline Find More Posts by theflyingeagle
Old Mar 01, 2011, 07:55 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
Originally Posted by theflyingeagle View Post
Hi all,
Yes it is possible to connect them but it is unlikely anything would happen.
What you need is a brushed esc with only 2 wires. There are pleny of threads here which cover that.
electrotor is offline Find More Posts by electrotor
Old Mar 01, 2011, 08:29 AM
Joined Dec 2006
Have you done this before..?
I think it will work but Iím not sure of the ESC is capable of handling some extra LED's...
A brushless ESC does some measurements I believe...
Old Mar 01, 2011, 11:38 AM
Bonnie Scotland
Joined Jun 2004
A brushless esc works by converting the battery DC into phased AC. LEDs use DC.
IS THIS A WIND-UP?
Old Mar 01, 2011, 12:14 PM
Joined Dec 2006
IS THIS A WIND-UP?
Got it... but still..
I have done it... it works... a LED is a diode so when de ESC is going negative it will block, no problem.
But i didn't like it, my motor starts to squeal a bit and it stops like the brake is on..
So i removed the LED's and leave it by this experiment, just use a Brushed for LED control...
Old Mar 02, 2011, 02:18 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
IS THIS A WIND-UP?
As said a diode will work in one way and block in the other. So that's not the problem. Max. blocking voltage might be lower than the battery voltage - could burn the LED.
More of a problem will be the software. As you see with some motors, if something goes wrong the motor just stutters and won't run. As the diodes won't return the signals as a motor does it certainly won't "run". So I dont't think you will see more than a short flash.
RK
rkopka is offline Find More Posts by rkopka
Old Mar 02, 2011, 04:44 PM
691175002 is offline
Find More Posts by 691175002
Joined Feb 2011
Your ESC is potentially dumping many amps into the motor. A typical LED wants 0.02 amps.
It should be easy to see why this is a bad idea.
691175002 is offline Find More Posts by 691175002
Old Mar 03, 2011, 04:43 AM
rkopka is offline
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
A LED should always be used with a resistor or other kind of current limiting device which can not be an ESC (BL or brushed).
The ESC dumps no AMPs !!!!!!!! It just sets a voltage and the motor draws as much current as voltage, rpm and prop need. A 100A ESC can also drive a 1g motor. It just will be heavier than the plane :-)
RK
Old Mar 03, 2011, 03:14 PM
Joined Feb 2011
RK
By dump I didn't mean force the maximum current through at all times. Either way your point is at best a technicality since setting voltage and providing current are just two sides of the same coin.
My point is simply that almost any brushless/esc combo will be dealing with far more current than an LED could ever survive which makes this a bad idea even without considering how a diode would screw with the ESCs feedback monitoring.
Old Mar 04, 2011, 01:05 AM
rkopka is offline
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Yes and no. For electricity we differentiate between current and voltage sources. A voltage source provides voltage and allows current to flow.
A current source will provide (in theory) any voltage it needs to let a set current to flow.
An ESC is a voltage source. It normally doesn't care for current. The better ones shut down if a max. current has been reached. The cheap ones just go up in smoke :-)
A diode has a voltage by that it begins to conduct. If there is no resistance added the current will rise very fast above this voltage. So it's no good idea to use a LED without a resistor even if the voltage is very near to the LED flow voltage or it will easily burn.
So any LED installation without a dedicated current source/limiter needs a resistor in series.
The current value of an ESC doesn't matter because that's just the value the ESC will get to its limit. It will usually provide more current with the strong risk of destruction.
I just write this because from other posts I found that some people don't get the current value correct. They think if they take a 20A ESC the current will not go higher no matter what motor they use !
So apart from the question if a BL ESC will work at all, a LED needs a resistor(or such) in any case. And the current value of the ESC doesn't matter.
Even if you could setup the ESC to switch on in such short pulses that the average current will be in the LEDs range, it will burn the LED because the current spikes are too high.
RK
Old Oct 11, 2013, 04:28 PM
david.merc is offline
Find More Posts by david.merc
United States, VA, Blacksburg
Joined Jun 2010
Here is one that works but not sure how he wired it:
ESC v0.3 driving the LED harness after repair (0 min 22 sec)
david.merc is offline Find More Posts by david.merc
Old Oct 13, 2013, 04:13 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Nice find Dave!
His circuit emulates the "K" motor winding. The LEDs, which are diodes, are wired in diametric opposition. That means one if forward bias and the other is reverse bias as the ESC switches phase. That's why you see them alternatively flash as the throttle is advanced. The resisitor on each leg acts as a current limiter. At higher switching speeds you can't see the flicker. A bit of overkill to make a LED light....but....NEAT!
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Oct 13, 2013, 04:51 PM
Dark Yet??
Joined Dec 2009
I thought the idea of using a brushless ESC had some potential so I mocked up a couple different circuits using LEd strip. I attached one ESC lead to the each end of the positive bus and the remaining lead to the negative. The LED strip would blink at low throttle but then go off past mid throttle. I suspect this is due to not sensing any change in the motor position during the idle phase of the cycle. The brushless ESC depends on sensing the motor position thru the idle phase wire. My guess is it errors out at some point of not sensing the motor turning.
I then tried 2 pieces of LED strip diametrically opposed. I swapped the positive and negative at the central junction and wired one lead to the negative bus, and one to each end of the pseudo positive bus. Same results. Flashing at low throttle and goes off past mid throttle.
Neat idea. Different ESCs, different timing settings may give different results. Cool experiment.
Question ESC heating on LED testing tayarati Night Flying 2 Feb 18, 2011 08:07 PM
Sold Walkera 4#3 Heli's 1 brushless, MIA, LED, 2-3 more Heli's & tons parts $199 shipped Rat57z Aircraft - Electric - Helis (FS/W) 8 Feb 13, 2009 02:31 PM
Two Or Four Brushless Motors On A Plane Do Need Two Or Four Brushless Esc's agapornis Power Systems 1 Jul 17, 2005 06:17 PM
Red LED on ESC going on when I add pitch msg73 Mini Helis 3 Oct 25, 2004 01:46 PM
F/S on EBAY: 2 maxcim brushless motors and ESC's valkyrie83 Aircraft - Electric - Airplanes (FS/W) 0 Sep 08, 2004 11:34 AM
