Old Feb 27, 2010, 12:28 PM
Mark Wolf is offline
Find More Posts by Mark Wolf
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Build Log
B-26 Marauder "ISH-TAK-HA-BA"
15 years ago I purchased a book about WWII nose art. While flipping through the pages I came across a picture of "ISH-TAK-HA-BA", a B-26 Marauder of the 384th bomb group. On it's 101st mission, Ish-tak-ha-ba struck and sheared off a telephone pole. The damaged bomber not only brought it's crew home and landed safely, but did so with 11 feet of the pole hanging out of it's wing. That's an airplane and crew worth remembering! I knew then that I'd have to model the plane some day.
That day begins today! What follows is my build of the Wowplanes.com 80" wingspan B-26 Marauder.
Standard disclaimer: I'm not an expert builder. I present the following only as a description of what I've done and make no claims as to this being the best way to build this or any other model.
Basic specs and prebuild goals:
Wingspan: 80 inches
Wing area: 820 sq.in.
Length: 67 inches
RTF weight: 11-12 pounds
Power: 2 Scorpion 4025-16 outrunners on 6s, battery TBD
Springair retracts
The Wowplanes kit consists of pre-cut white foam parts and vacuformed canopies and cowls. Most of the construction details are left to the builder, but a general construction guide is available on Wowplanes web site. There is also a thread devoted to the model HERE.
I'm just getting started, so far I've unpacked the kit (three big boxes) and did a quick inventory. Also shown in the picture is the equiptment and wood I've purchased so far for the project. Man! That's a lot of foam!
Mark Wolf is offline Find More Posts by Mark Wolf
Old Feb 27, 2010, 01:21 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I'll be watching this one closely. I have one in it's box too. I just bumped it back one in the build que though so it'll be great to see how yours goes first. Are you going to glass ir liquid sheet it?
Gree is offline Find More Posts by Gree
Old Feb 27, 2010, 01:23 PM
Helihead is offline
Find More Posts by Helihead
Helihead's Avatar
United States, AL, Huntsville
Joined Feb 2003
As a long time browser of interesting nose art I'd say you picked a great subject :-)
I have been eyeballin the wowplanes for a while. Just can't decide which one I want to build first so I'll be watching this build with interest.
Thanks for sharing...
Helihead is offline Find More Posts by Helihead
Old Feb 27, 2010, 03:21 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
better not turn that work lamp on Mark, or you could end up modelling an 80" jellyfish!
Good luck mate, we will be watching with interest. "i am not an expert modeller" SHEESH!
Craig
trumps is offline Find More Posts by trumps
Old Feb 27, 2010, 04:02 PM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
I'm going to sheet it with 1/32 contest balsa then 0.5 oz fiberglass per Jim Ryan's TECHNIQUE. Fahim seems to get decent results with his liquid sheeting but I'm much more comfortable glassing and IMO the balsa/glass will yield a more hangar-rash resistant surface. Bigger models tend to get bumped around more.
Old Feb 28, 2010, 01:46 AM
Buzz Bomb is offline
Find More Posts by Buzz Bomb
Ham Call Sign: KK4KGJ
Buzz Bomb's Avatar
United States, GA, Stone Mountain
Joined May 2006
Mark
I've seen the liquid sheeting first hand and it's very hard. Pretty cool stuff.
Joe
Buzz Bomb is offline Find More Posts by Buzz Bomb
Old Feb 28, 2010, 03:12 AM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Originally Posted by Buzz Bomb View Post
Mark
Joe
To each their own. I'm more comfortable sheeting and glassing.
Old Feb 28, 2010, 06:56 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I know what you mean Mark. It's hard to get away from the "tried and true".
J
J Morgan is offline Find More Posts by J Morgan
Old Feb 28, 2010, 08:41 AM
Steve85 is offline
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Mark,
I'm of the balsa persuasion myself, but have occasional foam tendencies in moments of weakness , so I'll be watching this one with interest!
Steve
Steve85 is offline Find More Posts by Steve85
Old Feb 28, 2010, 09:34 AM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Originally Posted by Steve85 View Post
Mark,
Steve
I was discussing this subject with a good friend just yesterday. For some people "foam=cheap foamie" and that's simply not true. There are models built from foam and there are foamies. I need to switch mediums occasionally or I get bored. Over the past few years I've done a few depron builds, then 3 balsa projects, and now this. After spending way too long whittling out my Waco YMF, the last thing I want to do right now is glue sticks together. I do want to build one of Jim Youngs Laird-Turner racers, so I will probably be back to balsa after the B-26.
Old Feb 28, 2010, 10:08 AM
awrightbrother is offline
Find More Posts by awrightbrother
Wowplanes.com
awrightbrother's Avatar
Florida
Joined Nov 2007
If looking for a rock hard surface, sheet with 1/32 balsa, and apply 3 coats of LS with or without the cloth.
It makes for a surface harder than epoxy/cloth and best of all, eliminates all that knuckle bruising sanding.
Fahim
awrightbrother is offline Find More Posts by awrightbrother
Old Feb 28, 2010, 12:01 PM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Thanks for the tips guys. I'm sticking with balsa and glass though. I'm confident in the results I can achieve and for me that's important on a project like this. I've got one of Fahim's little B-25's started, maybe I'll go back to it someday and give the liquid sheeting a try.
Begining of actual construction. First step: epoxy the bottom seam on the fuselage parts. I also glued up the stand.
Old Feb 28, 2010, 12:25 PM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
I was digging around the house looking for B-26 reference material and came across a B-26 plastic model I had squirreled away. This thing is older than I am. Bring back memories for anyone?
Old Feb 28, 2010, 12:34 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Mark, unfortunately it's not older than me The memory that it brings back for me is that Aurora kits were about the worst plastic kits on the market.
I will be following your build with interest.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Feb 28, 2010, 05:23 PM
Buzz Bomb's Avatar
Joined May 2006
Wow check out those scimitar props!
For Sale B-26 Marauder Cowling dan n Aircraft - Fuel - Airplanes (FS/W) 2 Nov 07, 2009 07:57 PM
Discussion Veritgo B-26 Marauder tailskid2 Fuel Warbirds 0 Oct 04, 2009 04:31 PM
Build Log Dumas B-26 Martin Marauder..She flies! 56S Scale Kit/Scratch Built 102 Aug 19, 2009 06:20 PM
Video Dumas 30" conversion B-26 Martin Marauder 56S Electric Plane Talk 6 Mar 19, 2009 07:18 PM
Discussion Martin B-26 Marauder scale drawings bipeflyer Scale Kit/Scratch Built 15 Mar 05, 2005 03:15 PM
