Old Aug 02, 2009, 06:55 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Mats IYF 44 Build
Going with the IYF as I want something thats aerobatic, and can slow down for some good close in flying at the park.
Plus its my first wing so need a nice slow one to learn with
No fixed power plant/battery combo, she will have big bays to move stuff around as it will have several diferent setups as I use this as a bit of a KIWIRC demo/try things out wing.
Tonite have cut the spar slots, trimmed The main spar to size and attacked the motor mount with a dremel. I cut a slot on the end of the square tube so that it slots over the main spar. There is no way this puppy will move out of alignment.
Sorry the photos are a bit blurry
matwelli is offline Find More Posts by matwelli
Old Aug 02, 2009, 02:29 PM
eckace1 is online now
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
Lookin good so far Matt.
Keep us posted
eckace1 is online now Find More Posts by eckace1
Old Aug 02, 2009, 05:01 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Looks like you driled the motor mount for the CF tude if so nice idea.. it will help tie everything together..
Looking good..
PaulVi is offline Find More Posts by PaulVi
Old Aug 03, 2009, 12:53 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Thanks guys, will update here as things progress
Yea Paul, sort of, used the dremel and slotted it, so I could glue the wing and spar, then filled the hole with PU and slid the mount in. Seems to be locked in real nice :-)
Old Sep 05, 2009, 10:27 PM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
I had Adam do my 36 inch lightning twin with the mounts that way.. tied to the spar so the motors would be tied to a more ridge frame...
Old Sep 06, 2009, 07:50 AM
jstoll is offline
Find More Posts by jstoll
cant leave things stock
jstoll's Avatar
United States, KY, Lexington
Joined Feb 2007
adams builds are nice & when he is building chrisses wings ..... its a combo that cant be beat for sure
I want to do a big high wattage twinn at some point
I have a couple of 36mm outrunners here with about a 2000KV which should do well
you all have a great week
JAK
jstoll is offline Find More Posts by jstoll
Old Sep 06, 2009, 01:29 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Hey, yep locking the mount into the carbon works a treat, I have 13 flights on the IYF44 lite build so far, 1/2 of them with the Microdan 2535 Custom wind.
next time to lock it even more, may drill a 6mm hole nearer the motor end of the mount, and put a 75mm (3 inch) long spar in , so theres two solid mounting points
I see I never finished this thread off
Heres a completed photo, color scheme has changed (weak eyes) and it is currently Fluro Orange and white on top, and fluro green and white on bottom.
Battery capacity is between 2250 mah to 2350 mah 3S ( I run a combo of batts, two batts side by side in the bay) some combinations put my CG on the recomended point, some combos move it back 10mm. with it back it wags its tail a bit in a cross wing, but requires about 2mm less reflex, so is faster.
Three motor combos I use on this. Emax 2805 1600kv, it flies but not enuff punch. Emax 2812 1535 kv with APC 7 by 5 prop - flies nice, long flight time, Microdan "Custom" 2535 kv on a 6 by 4 e prop - my prefered motor, as is lighter than the emax, and can be throttled back for "In Yo Face" flying, or throttled up for a bit of speed :-) but you cant beat the Emax for value for money.
Old Sep 06, 2009, 08:35 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Super clean build and finish Matt. Your work is prestine
Atom1025 is offline Find More Posts by Atom1025
Old Sep 07, 2009, 12:06 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Heh, tks adam, but I wouldnt go that far, you havent seen it up close !
Old Sep 07, 2009, 02:46 AM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
LOL. thats the same thing I tell people bout my stuff
Old Sep 07, 2009, 07:51 PM
jstoll is offline
jstoll's Avatar
Joined Feb 2007
really nice work
get some video of it
have a great week
JAK
Old Sep 08, 2009, 06:28 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Will try and get some vid :-) tks for the complement.
The MD motor makes this thing move, maybe a bit to fast , but hey another flight on it today, that 14 so far. still at a cross roads as to my next wing (TL50 powered, TL50Slice powered, ltg36.......)
Old Sep 12, 2009, 08:38 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
Right, with about 18 flights on her now (11 in the last week !) and with the elevon hinges and wing tips needing attention, I decided to do a small mod......
I hope it works.
Jacko very kindly donated a set of tips from his Dlite40 (he has balsa ones for it) so I cut and sliced these in. I also used some offcuts from the main spars on the wing tips to protect the elevons.
Note the color scheme, its the only way my tired eyes can see it, the underside is Fluro Green !
Motor is swapped back to the emax 2812 on a 7 by 5 apc pro (then back to the MD, damn speed calling me)
Ok, back from field - flight test - no better/no worse - the looks I like
Old Sep 21, 2009, 12:06 AM
PaulVi is offline
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
How about a 3/4 view so we can see how it looks with the inboard winglets
Old Sep 21, 2009, 03:53 AM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
sweet as !
Now have 9 flights on her in this config.
With the outboard wing tips, after 4 flights the EPP would rip where the winglets were hotglued
Set up like this, no more probs, and the motor/prop is nicely tucked awy
Just wish I had RITEWEAVED this one, as I learnt to fly wings, she has taken some abuse, and looks tatty.
Discussion Fast IYF Ritewing Build. klique Flying Wings 870 Mar 20, 2014 10:43 PM
Discussion Wedell Williams 44 Build Thread Carnifax North Coast Electric Flyers 14 Jan 03, 2006 08:15 PM
