Old May 10, 2009, 07:48 PM
rye 332 is offline
Find More Posts by rye 332
chicago
Joined Aug 2008
battery for lights
hi
well i finish the cabin crusies here a movie runs good but with the fuel pump for water pick up and led lights she run dry in 12 minutes so i am going to try just water pickup that at prop speed and get reid of the pump and i want to get the light of the main 12 volt 7 amp gel cell and use the 12 volt 1.3 amp for the lights but could i use the same charger for this small battery as i do for the big one they are both 12 volt one is 7 amp one is 1.3 amps heres they are what would the charging time be on the small one with the same charger that i use on the big ones ,i need bellast anyway on the right thanks rye
http://www3.towerhobbies.com/cgi-bin...?&I=LXL373&P=V
http://www3.towerhobbies.com/cgi-bin...?&I=LXL370&P=M
movies
http://www.youtube.com/watch?v=QHifq...e=channel_page
rye 332 is offline Find More Posts by rye 332
Old May 11, 2009, 01:59 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
What battery did you use previously that ran out in 12 minutes?
Can you accomodate the 12v 7 amp battery?
If you are running LEDs for you lights, the amp draw on them is nominal and I would not worry about that.
Tachikaze is offline Find More Posts by Tachikaze
Old May 11, 2009, 02:09 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
i pull around 1 amp with 40 LED's a 2300mah 4.8v supplies one circuit, and the main drive 6v 4500mah supplies the second circuit. and a days illumination at an event is within the capabilities of the 2300mah pack
Ghost 2501 is offline Find More Posts by Ghost 2501
Old May 11, 2009, 04:21 PM
rye 332 is offline
chicago
Joined Aug 2008
hi
i am using a 12 volt 7amp gel cell some one told me to gear the motors they are two 700 graupuer ,but i dont know which gear box to get thanks rye
Old May 11, 2009, 06:12 PM
太刀風
Tachikaze's Avatar
Joined Jan 2003
The Graupner 700 BB turbo can accomodate up to 33v I believe, but it works best at 9.2v. If you plan on running it at a voltage higher than that, gear it. Many will run 2:1 and some run 3:1.
An issue will be your batteries, gel cells do not like to get warm, and have a quick load drop, Nicads work much better for this.
Perhaps, use the gel cell for your lights, and a couple 4000mah Nicads ( using D cells) for your drive. Make sure you water cool your engines, and draw through should work.
I had a passive draw through on my tug ( springer), which only trickled when it ran the first time. I have since replaced the 1/8" ID aluminum wrap around tube with 3/16", marked improvement in water flow. Plus under the recommendation of Umi, dropped the depth of the intake to where it is below the center of the prop.
Old May 11, 2009, 06:20 PM
rye 332 is offline
chicago
Joined Aug 2008
hi
thanks ,do you have any web pages for the gearing
Old May 12, 2009, 12:50 PM
太刀風
Tachikaze's Avatar
Joined Jan 2003
Here are a couple of spots to look at:
http://www.modelflight.com.au/rc_mod..._gearboxes.htm
http://www.icare-rc.com/gearboxes.htm
Old May 12, 2009, 06:38 PM
rye 332 is offline
chicago
Joined Aug 2008
hi thanks
i dont see what i need thanks anyways rye
Battery for Lupo AndrewK Parkflyers 0 Jun 20, 2001 08:58 PM
The overall best battery for the litestik for the money! gassyanimal Parkflyers 4 Jun 18, 2001 05:16 PM
cheap cell phone battery for lite stick Skywalker Parkflyers 1 Jun 01, 2001 02:43 PM
What battery for a 480 motor... tnsfrk Electric Plane Talk 9 May 28, 2001 12:41 AM
X250 Owners, where do you place your battery for the CG? Scott C Electric Plane Talk 4 May 13, 2001 04:15 PM
