Old Oct 06, 2004, 09:25 PM
jonson is offline
Find More Posts by jonson
Joined Aug 2004
Question
how to "break in" a sp400?
how do i properly break in a sp400(stock) for my ep sailplane?whats water break in?
jonson is offline Find More Posts by jonson
Old Oct 06, 2004, 10:08 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
It isn't really necessary to break in a SP 400. Water break in simply refers to running the motor while it is under water. You will see the water turn cloudy as the motor runs. This is the dust from the brushes wearing to the commutator. The motor is run at a low voltage. I used two 1.5 v D cells.
I never saw any advantage to doing it. Speed 400 motors seem to run fine out of the box especially for sport flying.
BM
BillM is offline Find More Posts by BillM
Old Oct 07, 2004, 05:37 PM
jonson is offline
Joined Aug 2004
thank you for your input! really appreciate it.
Old Oct 08, 2004, 04:19 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I juts run em up at art throttle till the brushes bed in. Takes a few minutes.
Thing to avoid is massive current before they are bedded in - burns the commutator.
Old Oct 17, 2004, 10:07 AM
thermite is offline
Find More Posts by thermite
thermite's Avatar
London, England
Joined May 2003
I don't think it improves performance much but longevity can be greatly improved. I've broken in all my 300-400 motors. It takes much less time to seat the brushes in water and I've only had one 300 motor fail on my ss as I had run it hard on 8 cells for quite a few flights. It shorted out under full throttle on a steep climb out. All my other cheap can motors are still in service and running well.
thermite is offline Find More Posts by thermite
Old Oct 17, 2004, 11:05 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As vintage, so correctly, says..... if you don't bed in the brushes on the comm, then crank it to WOT first time out, you'll get a lot of arcing and pitting of the comm. It really is better to do a gentle water break-in.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 20, 2004, 04:33 PM
Norman Greene is offline
Find More Posts by Norman Greene
Dublin, Ireland
Joined Mar 2002
A half hour on really low throttle, no need for water, although with water it is quicker.
Norman Greene is offline Find More Posts by Norman Greene
Old Oct 20, 2004, 07:27 PM
Russell2 is offline
Find More Posts by Russell2
Deer Park, Tx, USA
Joined Feb 2001
I use 2 "C" cells in series, run motor in water for about 5 minutes ( turns cloudy ), after timing it for rotation direction. I think it has improved the longevity for me with not much effort expended. Most of mine have lasted more than a flying season
Russell2 is offline Find More Posts by Russell2
Old Oct 20, 2004, 08:15 PM
thermite is offline
thermite's Avatar
London, England
Joined May 2003
I did once try to use one of those DC adapters which can switch voltage 3v, 6v, 9v, 12v
I set it to 3v and ran the motor suspended in water. Eventually, the adapter couldn't handle the amp draw and died. I think two cheap alkaline cells is definitely the way to do it.
Old Oct 20, 2004, 08:33 PM
thermite is offline
thermite's Avatar
London, England
Joined May 2003
Sorry, accidentally posted twice.
need to know how to break in siro engine kidz12003 Motorcycles 3 Jul 29, 2004 01:13 PM
How to break in new brushed motor? samcrismon Power Systems 17 Apr 14, 2004 12:10 PM
Yippee! how to break in 350c motor and 7/8 cell 730mh AAA hty GWS (Grand Wing Servo) 13 Nov 24, 2003 08:34 PM
How to break in a brushed motor with ESC built in. saint Power Systems 1 May 12, 2003 02:22 PM
How to break in a motor NoVaNewB Power Systems 2 Feb 26, 2003 01:16 AM
