Old Jan 06, 2011, 12:19 PM
nkcook is offline
Find More Posts by nkcook
Albuquerque, NM
Joined Nov 2010
Parkzone Radian motor won't work, Help
Just got my Radian 3 weeks ago, put it together the first week and went to fly but too windy, at that time everything worked fine. Took it out today and motor does not respond to Tx. Everything else works. I have good batteries, completed charged Lipo. I even checked the throttle control using FMS and it works. I tried swapping servo channel on Rx to another and still nothing. When I first connect the Lipo sometimes the props move slightly during init power up but nothing else.
Any suggestions?
Wayne
nkcook is offline Find More Posts by nkcook
Old Jan 06, 2011, 01:13 PM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
You didn't mention what type of radio you have, but you need to be sure your throttle is at full idle and that the throttle trim is all the way down so the ESC can arm. Since your servos are working, your BEC circuit and receiver are not the problem. In 90+% of the cases like you describe, it's almost always the throttle channel settings that are the problem.
Try this first. Remove the prop from your motor. Make sure you have the throttle travel adjustments set to at least 100% in both directions. Trim your throttle idle to max low trim position and then plug in your RX and see what happens. If it still doesn't arm, unplug the RX, reverse the throttle channel (either by a reversing switch or by programming depending on your TX type), and then plug in the RX and see if it works. If it still doesn't work, plug the ESC into the Elevator channel of your RX, turn on the RX and move the elevator to full up and hold it there for a five count. BE CAREFUL because if the ESC arms, it will start the motor as soon as you release the throttle. If the ESC doesn't arm, move the elevator to the full down position and hold it there for a count of five.
Let us know what you find out.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Jan 06, 2011, 03:14 PM
nkcook is offline
Albuquerque, NM
Joined Nov 2010
McD
McD,
Thanks that's exactly what I found out by experimentation. Got it working. Took a little work to get the glide trim set up but patience paid off. Like all Radian's took a lot of down elevator to keep from looping on climb out. Did the dive test and worked out fine.
Made a 12 minute flight, this thing really lifts easy. Flying over a snow covered field with patches of brown dirt made finding lift pretty easy. I even let go of the stick and it just flies by itself.
I made four more short flights to practice landings and climbs. All went well. On my last short flight (lipo was getting low), I caught a gust of wind and over corrected, wing tip caught a tumbleweed and it nosed over. My luck the nose hit right on a rock (only one around for 10yds) and snapped the nose right off.
All in all a great time, now to glue it all back togther. Love the Radian.
Wayne
Old Jan 06, 2011, 04:11 PM
kingsflyer's Avatar
Joined Sep 2005
Originally Posted by nkcook View Post
Love the Radian.
Wayne
Glad you got it flying. Sorry about the nose, but a little 5-minute epoxy should have you back in the air ASAP.
McD
Old Nov 18, 2012, 11:38 AM
flyhigh42 is offline
Find More Posts by flyhigh42
Joined Aug 2012
Motor wont arm
I'm having the same problem with my Radian. The motor spools up to about half throttle, then it just cuts off. I was trying to test it as a glider (no batteries) and it stalled then came down on its nose - cracked clean off. I guess its to be expected...I'm totally new to flying. When you first launch, do you use full throttle?
I'm not sure why to motor won't arm... I'm suppose to charge the Lipo to 11.1 v (balanced) right?
McD,
Wayne
flyhigh42 is offline Find More Posts by flyhigh42
Old Nov 19, 2012, 12:29 PM
ekletke is offline
Find More Posts by ekletke
Winnipeg, Canada
Joined Jul 2006
flighhigh
Charge your battery to about 12.5 if you're going to use it that day. If you plan to leave it out of use for a bit a storage charge of about 11.5 is better. I don't usually use my batteries as low as 11.1.
As the radian is a powered GLIDER, the intended method of flight is full power as quickly as possible to gliding altitude then power off and glide.
However that does not prevent you from using it as a trainer for a newbie and flying around at lower power while you get used to controlling an RC airplane.
EK
ekletke is offline Find More Posts by ekletke
Discussion Why won't this motor work? Berkie Power Systems 29 Dec 13, 2010 09:33 AM
Wanted Parkzone 480 motor (Radian or T-28) zeus3313 Aircraft - Electric - Power Systems (FS/W) 1 Nov 12, 2010 06:09 PM
Wanted Parkzone 480 (Radian or T-28) Motor zeus3313 Aircraft - Sailplanes (FS/W) 1 Nov 12, 2010 06:03 PM
Help! help with new motor won't spin just shudders hotdog1 Power Systems 8 Nov 04, 2010 10:17 AM
Help! HELP!! New LBA10 Balancer won't work...what the??? planebldr Batteries and Chargers 43 Sep 09, 2010 09:09 AM
