Old Feb 06, 2014, 05:20 PM
Joined Jan 2012
Question
3D Profile Plane
Hello All,
I'm looking for a 3D Profile Plane that would fly with the existing the existing battery I have. I have some 3s 1800 batts.
It would be apreciated if someone can suggest a plane. I would be ideal if it came with the electronics.
AJ
aja1216 is offline Find More Posts by aja1216
Old Feb 06, 2014, 06:28 PM
Joined Jan 2014
Andrew Jesky, is this a windup?
If it,s not a wind up, to help you, why do you want a profile? What's your thinking?
Dwayn is offline Find More Posts by Dwayn
Reply With Quote  (Disabled)
Old Feb 06, 2014, 06:51 PM
Joined Jan 2012
Not sure who Andrew Jesky is or what you mean about windup. But I want to start learning to fly 3D. I figured a profile foamy is the cheapest route.
Old Feb 07, 2014, 12:46 AM
United States, UT, Ogden
Joined Nov 2004
I would agree with you but to learn and keep it cheap, you need to keep it light so a smaller foamie is the way to go and for that you will only need a 2or3s 450-500 mah battery.They are only 5 - 6 bucks each so dont let the battery size be your starting point. There are alot of great foamies out there- pick one that fits your budget and fly it till the wings fall off. We have a great affordable kit that is highly prefabricated and comes with electronics if you want it that way. Plus we think they are some of the "best looking foamies on the planet"
Lou Griffin
GriffWerks.com
asat is online now Find More Posts by asat
Old Feb 07, 2014, 03:20 AM
Joined Jan 2014
Profile planes can be aerofoiled or have a 'flat sheet' wing. They are both very different animals and is why i asked why do you want a profile. 'Flat sheets' fly slow and stable and hence perfect for 3D training, and Lou is 100% right.
Old Feb 08, 2014, 03:47 PM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
you could fly one of the techone SU31's from nitroplanes on 1800's (would have to lengthen the battery slot easy to do) or something like the EPP hummer types from valuehobby.com, both are very durable which is great for learning 3D
http://www.nitroplanes.com/02a-003-su-31-epp-arf.html
http://www.valuehobby.com/airplanes/...p-profile.html
spastic is offline Find More Posts by spastic
Old Feb 08, 2014, 03:58 PM
Joined Jan 2012
Thanks guys I'll check out those sites. I'm also looking at this one.
http://www.nitroplanes.com/02a-008-1...d-epp-arf.html
looks like this would work for my batteries.
Old Feb 08, 2014, 04:26 PM
United States, MI, Waterford Charter Township
Joined Aug 2008
1800's are pretty good size batteries, so you might consider a little more/bigger wing to carry them well? The 47"/1100mm Techone Swift might be a better choice?
Also, your link is to an ARF that includes a set of electronics that are pretty easy to improve on, especially the servos. If you buy the kit (that does not include any electronics), and spec your own higher quality stuff out carefully (metal gear servos, 40a speed control for instance), there's very little difference in price, kit vs. ARF.
Been beating on the Yak and the Swift for about 18 months now. Teaching myself 3D is the excuse I give for all but having stopped flying gas. Truth be told, these are a blast to fly!
Lots of guys asking about mine. Here's a complete list of all the components required to assemble the kit versions I put together for those that are curious. This is the stuff I'm using. You can buy better stuff, but not at this price level. It will also be pretty hard to beat the durability of this stuff. Planes are from Nitroplanes, the rest is all from Hobbyking's stateside warehouse. -Al
Yak-
http://www.nitroplanes.com/02a-008-1...d-epp-kit.html
Swift-
http://www.nitroplanes.com/02a-004-swift-epp-kit.html
3530 Motor for Yak http://www.hobbyking.com/hobbyking/s...arehouse_.html
3536 Motor for Swift -
http://www.hobbyking.com/hobbyking/s...strSearch=3536
Note: both of these Turnigy motors have very large diameter shafts I haven't managed to bend yet - despite MANY attempts. They have plenty of power for 3D, without overpowering or adding any more weight than necessary.
40a ESC
servos (4)http://www.hobbyking.com/hobbyking/s...arehouse_.html
Batteries (what I would go with if ordering tomorrow)
I've flown the planes with 1500, 1600, 1800, and 2200mah batteries. I like the smaller ones, but it will do fine on the bigger ones if you had them 'in stock' already?
Matching battery connectors for use on speed control and charger (if you don't have an adapter)
You'll need 2 servo extensions about 18"/45 cm long (for rudder and elevator). I've been splicing in the correct length of wire.
http://www.hobbyking.com/hobbyking/s...rvo_Plugs.html
Or, these extensions are new, have a clip on them so the won't pull apart?
http://www.hobbyking.com/hobbyking/s...dProduct=46775
Props - these are 10 time more durable than the APC equivalent. Highly recommended for either motor!
Optional: 3 axis stabilizer. Yes it works, no you don't need it....
http://www.hobbyking.com/hobbyking/s..._Receiver.html
ahicks is offline Find More Posts by ahicks
Discussion Seeking Receiver Ready Profile 3D Plane itsme2 Electric Plane Talk 4 Jan 04, 2014 11:24 AM
Discussion Profile plane for 3d , wich one is the best? victorfriessen 3D Flying 13 Jan 02, 2014 04:02 PM
Sold Tech one Venus 3D EPS Profile plane ARF $60 LPU Johnnymeg Aircraft - Fuel - Airplanes (FS/W) 2 Dec 26, 2013 12:08 PM
Sold Tech one Venus 3D EPS Profile plane ARF $60 LPU Johnnymeg Aircraft - Electric - Airplanes (FS/W) 1 Dec 25, 2013 03:37 AM
