Old Sep 03, 2013, 05:04 PM
Quiktrade_1 is offline
Find More Posts by Quiktrade_1
Joined May 2006
Originally Posted by 320pilot View Post
Quciktrade_1
Sounds like fun. I wonder if you were "2Km high"? That would be over 7000 feet ().
I have had my Pulsar 3.2 REF above 3000 AGL, and it was pretty small. And that was directly over the field with a cloudy background. If you transition to blue sky, when you are that high you can completely lose sight of the sailplane. Sounds like you had a taste of that So if I want to go that high, I make sure I am directly (or almost directly) over the field. That way, if I am worried I might lose sight of the sailplane, I just put out full flap, push the nose (visible as a dot!) down in a spiral dive, and wait for it to "re-appear".
Get a RAM 3 from www.soaringcircuits.com, and then you will know how high you really were.
Glad you are having fun with your new Pulsar.
Perhaps I'm exagerating a little.... It was bloody high that's for sure and certainly the highest it's ever been. Going to have a look at F5J so an altitude measuring device goes part in parcel with that type of competition.
The full size gliders in the Camden area have a 3000' AGL limit and our legal limit is 400' AGL unless otherwise approved.
Cheers,
Jason.
Quiktrade_1 is offline Find More Posts by Quiktrade_1
Old Feb 27, 2014, 03:50 PM
P Farley is offline
Find More Posts by P Farley
P Farley's Avatar
United States, WA, Spokane
Joined Aug 2006
3.2 fuse
I know a few of these have been crashed over the years...I am looking for the nose cone from a 3.2 ALES version if there are any out there? Thanks.
P Farley is offline Find More Posts by P Farley
Old Mar 10, 2014, 05:01 PM
harrye is offline
Find More Posts by harrye
United States, CA, Pleasanton
Joined Apr 2002
Side Thrust ?
Guys,
I've just "de-splooge'd" the nose of my Pulsar 3.2 Pro RES and I have my motor mounted.
Just eye-balling things there seems to be very little side thrust, or at least less than I am used to seeing.
The motor shaft is 90 degrees to the left / right plane of the front of the fuse and the spinner fit is perfect.
Maybe I looking too hard at the situation. What's been your experience ?
TIA for any feedback.
:harry
harrye is offline Find More Posts by harrye
Old Mar 11, 2014, 12:21 AM
Petem is online now
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
Don't bother
My Pulsar has no side or downthrust and needs only down elevator compensation to control the climb (a bit from a mix, the rest by thumb).
I have used a bit of right thrust on a couple of other electric soarers, but have been unable to tell any difference.
Put it together and go flying!
Cheers,
PeteM
Petem is online now Find More Posts by Petem
Old Mar 11, 2014, 12:01 PM
harrye is offline
Joined Apr 2002
Thanks PeteM.
:harry
Old Mar 12, 2014, 07:43 PM
bafbob is offline
Find More Posts by bafbob
bafbob's Avatar
United States, VT, Brattleboro
Joined Aug 2012
New Electric Pulsar thread
There is more up to date E-Pulsar activity in this other thread -
http://www.rcgroups.com/forums/showt...41844&page=57\
Not that this thread lacks good info ..
bafbob is offline Find More Posts by bafbob
For Sale Great Planes 65" Ultimate Bi Plane NEW RTF, Gas, New Brison 3.2, 3D Only 5 Flights Damon Darnall Aircraft - Fuel - Airplanes (FS/W) 5 Apr 07, 2007 11:47 PM
FS: 50 new CBP 1050mah 2/3 A NImh cells Al P Aircraft - Electric - Airplanes (FS/W) 1 Jun 19, 2004 09:31 AM
FS: 12 NEW Sanyo 1300 2/3 SC Cells Twmaster Aircraft - Electric - Airplanes (FS/W) 0 Nov 29, 2003 06:00 PM
