Old Apr 04, 2005, 11:56 AM
My Precioussss! is offline
Find More Posts by My Precioussss!
Flags blow'n, I'm go'n
My Precioussss!'s Avatar
USA, WA, Bellevue
Joined Jan 2004
Help on Rotor Build!
This is a Rotor fuse I was able to pick up this last weekend. All I have is the fuse. I need info on who could bag a set of wings and the tail sections. I know Jay has built one recently, I saw it fly and it was sweet! Any help would be much appreciated! I know WinchDoc has the hardware! What servos would I want to use? A metal gear digital with a bunch of torque, would be my first thought.
Here are a few pic's of the fuse and how I would like it to come out!
MP
My Precioussss! is offline Find More Posts by My Precioussss!
Old Apr 04, 2005, 12:08 PM
USA, WA, Bellevue
Joined Jan 2004
I found these Shrike wings!
http://skykingrcproducts.com/accesso...rbonwings.html
Would they work!
MP
Old Apr 04, 2005, 04:34 PM
winchdoc is online now
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
Shrike wings on a Rotor
MP,
My infamous 'hornet' Rotor (13 years old? I forget) currently has a set of wings that I bagged up from Harris Nelson Shrike cores. Yeah, they will work on your rotor. Important to be sure you get the right size tubing inthe wings the stock Shrike is designed to use a 1/4" wing rod. Different wingeron systems may require different rods.
My system uses a 5/16" ejector pin, but you need to install 3/8" ID tubing in the wing for it to work. Plan ahead!
Doc
winchdoc is online now Find More Posts by winchdoc
Old Apr 04, 2005, 04:46 PM
USA, WA, Bellevue
Joined Jan 2004
Thanks for the info Winchdoc! I would like to use your system, seems like the best out there.
MP
Old Apr 04, 2005, 04:52 PM
SkyKing RC is offline
Find More Posts by SkyKing RC
Minneapolis
Joined Feb 2004
Shrike Wings on a Rotor
I do have some Carbon Bagged wings in stock if you want them but I should tell you that the Shrike wing is very thin. The wing rod for this wing is 1/4". The wing is too think to handle anything larger but you might be able to sleeve the fuselage tube so that a 1/4" wing rod would not be an issue.
Ed
SkyKing RC is offline Find More Posts by SkyKing RC
Old Apr 04, 2005, 05:04 PM
Brian Courtice is online now
Find More Posts by Brian Courtice
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
What is the wingspan on a stock Rotor?
If it's 60" I might be able to provide you with a set of Ultron wings. I'm making them with the correct tubes inside for Winchdoc hardware. The planform and tip shape are similar so Ultron wings would look OK on a Rotor I think.
Better yet, Jay Decker might be able to provide a set of Rotor cores. I think he was cuting his own, so he probably has the templates needed already.
Brian Courtice is online now Find More Posts by Brian Courtice
Site Sponsor
Old Apr 04, 2005, 06:21 PM
USA, WA, Bellevue
Joined Jan 2004
This is some info I found on the Rotor, thanks to Jay!
Ken Stuhr's Original Rotor Design:
Span: 58"
Length: 44 1/2" to the end of the "stinger"
Area: 305 sq. in.
Original Airfoil: E374 thinned to 7.5% thickness.
Original wt and loading: 31 oz and 15 oz/sq. ft.
This Rotor:
Span: 58"
Area: 305 sq. in.
Airfoil: DS4, 9% thick, 1.64% camber
Wt and loading: 40.6 oz and 19.6 oz/sq. ft.
Servos: HiTec HS-5945 (Dual BB, Digital, MG, Corelss, 153 oz-in)
Jay Decker
Kennewick, WA
Old Apr 04, 2005, 08:17 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
I use 2 meter 7003 all carbon bagged wings on my Rotor-- works very well! Ken offered the Rotor with 2 wings-- the shorter "fast" wings and a longer 3021 "thermal" set of wings that were near 2 meters. I just used the long length to make a faster overall plane. Nearly any wing will work-- depends on what you want the plane to do.
Timmig
timmig is offline Find More Posts by timmig
Old Apr 05, 2005, 01:14 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
You should ask APC to provide you a special set of wing/rotors. Once you get this thing spinning the wings will act like an APC propeller and you can go hunting for thermals.
davidjensen is offline Find More Posts by davidjensen
Old Apr 05, 2005, 02:46 PM
USA, WA, Bellevue
Joined Jan 2004
Guess I need to buy a bagging video and get geared up! Maybe I should make a fuse mold while I'm at it. Any pointer's on pumps and supplies? Would like to start off on the right foot! Maybe a good starting point would be the video! Which Video!
This looks like a pretty good one! Does it go over pumps and where to get bags and supplies?
http://home.paonline.com/hayman/PAGE2.htm
Any others I should take a look at?
MP
Old Apr 05, 2005, 03:02 PM
Minneapolis
Joined Feb 2004
Phil Barnes Video
You've hit the jackpot. The Phil Barnes video is by far the best one available. It covers everything you'll need to know in high detail. Phil has developed many tricks/techniques not covered on the other videos I've seen on this subject. This is a video that you will actually study and maybe even take notes on.
If you need a vacuum pump I'd be glad to help you with that. I have two options listed on my web site: www.skykingrcproducts.com
You can also find great deals on pumps by going to e-Bay and typing the words "gast vacuum pump" in the search engine.
Ed
Old Apr 05, 2005, 03:40 PM
USA, WA, Bellevue
Joined Jan 2004
Thanks Ed,
Just ordered the Video! Let me watch it and I need to ask around a few buddies to see if they have any bagging equipment. If not, seems like you’re the man to see! What is the big difference between the two systems you sell? Seemed very similar to me.
MP
Discussion A little help on a scratch build stefalo Parkflyers 2 Apr 20, 2007 10:13 PM
Help on Ark X400 Tail Rotor Assembly Jovsdapogi Mini Helis 19 Nov 14, 2005 11:37 AM
help on wiring a coaxial rotor heli? grant31781 Coaxial Helicopters 7 Jul 19, 2005 11:22 AM
Help on my Molt Hellcat build Dave K Parkflyers 4 Sep 25, 2004 09:25 AM
Need help/ideas on what to build! awood12345 Scratchbuilt Indoor and Micro Models 0 Dec 06, 2002 02:52 PM
