Old Dec 18, 2004, 08:14 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
End of Day LiPo Recharge
After the last flight of the day should I recharge my LiPo batteries or just let them set until the next flying day?
RC Man is offline Find More Posts by RC Man
Old Dec 18, 2004, 08:19 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Depends on how much charge remains and when they will be used next.
Best stored at 40%-50% charge and at cool temp.
http://www.batteryuniversity.com/partone-19.htm
Charles
Old Dec 18, 2004, 08:41 AM
RC Man is offline
United States
Joined Feb 2001
That is interesting but I have no test equipment so I have no idea of what the voltage is.
The voltmeter on my Triton is kind of strange because when I first start a charge the voltage will first drop a little then start to rise. Which voltage is correct or is that the way LiPo’s charge?
Old Dec 18, 2004, 09:27 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
A simple meter can be purchased for as little as a few dollars. Using Li cells without having a meter to check them is not safe. Periodically measuring Li cells with a meter can help prevent loss of an expensive Li pack, and possible venting with flames that could start a fire.
It's normal for the charge voltage to drop at the beginning of a charge. The 40-50% charge is only required for longterm storage, i.e. weeks or months. There's no problem leaving Li cells full charged for days at a time. If they are stored at full charge for longer periods, the cells will gradually lose capacity.
Li cells are not plug and play. They require extra care and attention in order to be used safely. For the safety of themselves and their families, anyone who is not willing to take the time for this extra care and attention should stick with NiCd and NiMH.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Dec 18, 2004, 09:43 AM
Southern Pride
Not strange ,voltage rises during charge and decreases during discharge.
Dave's post is correct. Lipos require more than just a casual relationship.
You can check the pack voltage with you Triton Charger.
Set to proper cell count voltage 11.1 for a 3 cell pack , set to Discharge at 0.1 A rate. This will show the packs voltage under a very light load which will be close to a no load voltage.
40% charged would be 3.9 V per cell or 11.7 v for 3 cell pack.A full charged 3cell pack would read approx. 12.40-12.50.
Charles
Old Dec 18, 2004, 08:16 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
If you expect to fly again in a reasonably short time (say, within a few weeks) just charge 'em up. They'll still be charged when you go to fly. If not, then all the makers recommend storing them for long periods at about half charge as the other guys have pointed out.
I almost always just recharge after coming in from a flying session (as I am doing right now). That way, I'm ready to go fly (presuming charged transmitters ) just about at any time.
BEC is offline Find More Posts by BEC
Old Dec 18, 2004, 09:47 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Nothing strange, the Triton measures the pack voltage before starting the charge to determine if the settings are correct. It will try charging at 0.1A for a bit and than stop and measure the voltage. You know this is happening when the current reads 0.0A. It might do this a couple of times before it starts charging at the inputed level.
hoppy is offline Find More Posts by hoppy
Old Dec 18, 2004, 10:01 PM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
I believe that lipos are safer when they are discharged. They are less likely to vent with flames from being dropped, left in a hot car, etc. I leave my batteries discharged after flying, and recharge them the morning before I fly.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Dec 19, 2004, 05:12 AM
RC Man is offline
United States
Joined Feb 2001
Is that really true?
How about some other opinions.
Old Dec 19, 2004, 09:43 AM
Joined Feb 2000
The problem with this line of reasoning is that while it sounds logical, it has not to my knowledge been proven. Someone reading this might get the idea that it's safe to leave discharged LiPos in a car parked out in the sun on a hot day. This would not be good.
I would run this theory by some true LiPo experts before putting any faith in it.
Old Dec 19, 2004, 11:31 AM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I always recharge after flying, the exception being if It'll be a long time, ( months?) till I'll use them again.
Since I'm not waiting for the next flight, I'll usually also charge them at a very low rate as thats supposed to be less stressing on the cells, and seems to allow a slightly higher ending resting voltage than if I charged at a higher rate.
BTW, I also use a kokum safety guard while charging. Pretty much impossible to overcharge while these are in the circuit.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Dec 19, 2004, 12:01 PM
Joined Feb 2000
That would be true only in the case of balanced packs. Since Kokam SGs only limit total voltage to the pack and not individual voltage to cells, they cannot prevent individual cells in an out-of-balance pack from being overcharged.
Old Dec 19, 2004, 12:10 PM
Joined Feb 2001
True Dave, but overcharging a individual cell is a problem any charging scheme other than charging each cell individually would run into.
Old Dec 19, 2004, 01:14 PM
Joined Feb 2000
Right, Dean. The only reason to be picky about how this is stated is that someone reading this thread might get the idea that the SGs protect against overcharge in all situations, including unbalanced packs, which they do not. As you note in your last post, pack balance must be checked in order to assure maximum safety from overcharge event whether using SGs or not.
Old Dec 19, 2004, 07:06 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
The idea that discharged LiPo cells are safer than charged ones may have some validity. One of the problems that can occur with LiPo and LiIo cells is a phenomenon often referred to as thermal runaway. I don't profess to understand the dynamics of this phenomenon but I do know that it is typically triggered by extreme discharge rates like dead shorts. This is why it is strongly recommended that a LiPo pack be immediately moved to a safe location and monitored for at least 30 minutes if the leads are shorted even momentarily.
Thermal runaway requires energy and a fully-charged cell obviously possesses more energy than a discharged one so in that respect, a discharged cell could be considered safer than a fully-charged one. But thermal runaway isn't something that happens spontaneously. It requires a trigger event like the previously-mentioned dead short and it's not real likely that a pack stored with even the most rudimentary level of protection will suffer such an event.
So the bottom line (at least in my book) is that if you are in the habit of storing your LiPo packs on your work bench or somewhere where they can be hit by falling objects or have things accidently set on them then you may want to consider leaving your packs discharged until you need them.
I prefer to keep my packs charged because I can never tell when a rare (this time of year) opportunity for an after-work flight might present itself and there's nothing worse than having such an opportunity but no charged battery packs. I don't leave my packs just laying around, though, so the state of charge that I store them in is a moot point.
Pete
PGR is online now Find More Posts by PGR
End all to Lipo Explosion Worries- Feedback Hugequark Batteries and Chargers 28 Jun 23, 2005 11:30 AM
cleaning your nitro car at the end of the day? fga Nitro and Glow Power Cars 6 Jan 08, 2005 05:09 PM
End of the Day Wingo 1 Aerial Photography 1 Sep 07, 2004 11:13 PM
