Old May 14, 2015, 09:41 PM
quigley257 is online now
Find More Posts by quigley257
Say when.....
quigley257's Avatar
United States, MO, Hillsboro
Joined Sep 2005
Help!
Water Based Contact Cement
I'm currently using Loctite 200 spray adhesive which I buy at Walmart for $6.97 for a 13.5oz can. It works good for laminating large surfaces. It can be used on Dollar Tree Foam with no ill effects. It does work for what I use it for and I get pretty decent mileage out of a can. The guys across the pond have access to a product that I would like to get my hands on for modeling. It is a water based contact cement by Evo-stik called Solvent Free Impact. It is foam safe, water based, and thin enough to be brushed on. Once dry, it is an instant, permanent bond. Do you know of any similar product available in the U.S. that has these same qualities? I'd like to hear actual user opinions. I have seen some online, but none seems like a good match to the Impact adhesive.
quigley257 is online now Find More Posts by quigley257
Old May 15, 2015, 12:42 AM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
http://www.lepageproducts.com/ProductDetail.aspx?pid=89
Get it at Home Depot.
Granted is offline Find More Posts by Granted
Old May 15, 2015, 06:28 AM
compressor man is offline
Find More Posts by compressor man
CAP smasher
compressor man's Avatar
GA,USA
Joined Jul 2010
Rubber cement works pretty well when used as a contact cement.
compressor man is offline Find More Posts by compressor man
Old May 15, 2015, 08:10 AM
flypaper 2 is offline
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Big plus here too for the Lepages Green stuff. Works very well.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old May 15, 2015, 09:18 AM
Say when.....
quigley257's Avatar
Joined Sep 2005
Thanks for the tips! How is the LePages for sanding once dried?
Old May 15, 2015, 09:32 AM
SlowJeff is online now
Find More Posts by SlowJeff
Taranis Soarus Wrecks
SlowJeff's Avatar
United States, MO, Richmond
Joined Apr 2015
SlowJeff is online now Find More Posts by SlowJeff
Old May 15, 2015, 01:27 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Mine was used to sandwich two sheets together, therefore, never had to sand it.
Being a rubber base, I doubt it would sand very well, but of course, can't say for sure.
Gord.
Old May 15, 2015, 02:30 PM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Once dry the stuff is as resilient as a latex condom, so imagine trying to sand a condom.
Old May 15, 2015, 03:41 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Have to remember that one.
Gord.
Old May 15, 2015, 04:01 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Would that be in the package or installed?
High Flyin' is offline Find More Posts by High Flyin'
Old May 20, 2015, 01:14 PM
Say when.....
quigley257's Avatar
Joined Sep 2005
I'll try to find the LePage stuff locally and give it a try. Thanks guys.
Discussion Foam contact cement DAROBB Foamies (Scratchbuilt) 8 Nov 06, 2014 11:49 AM
Discussion Good Plastic to Foam contact cement? stuka Electric Plane Talk 9 Sep 30, 2014 04:37 PM
Elmers Rubber Cement V.S. Dap Weldwood Contact Cement kenny_dilger Electric Plane Talk 11 Feb 18, 2003 11:08 PM
DAP Weldwood Contact Cement and Reynolds Crystal Wrap? CheeseWing Parkflyers 1 Sep 23, 2001 07:50 PM
