Old Apr 08, 2015, 10:53 AM
vafan13 is offline
Find More Posts by vafan13
United States, MI, Ann Arbor
Joined Apr 2007
decent, cheapish charger for micro/mini quads
I'm looking to get something to replace the default/terrible USB charger that comes with WL Toys micros, etc. Basically just need to be able to charge multiple 300mAh 45C turnigy packs, something around 750-950 for the v636 that's on the way, or possibly even ~1300 3S if I ever get a ~250 FPV quad.
I don't want to spend too much given what I'm trying to charge and was looking at the B6AC V2, which I can get off of amazon for $66 shipped or an accucel-6 80w and a cheap power supply from HK. which of these is the better choice, or should I get something else entirely?
thanks in advance!
vafan13 is offline Find More Posts by vafan13
Old Apr 08, 2015, 12:31 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Please, when you mention a battery. list all the specs. What is the cell count of the 300mAh 45C Turnigy pack mentioned above?
thanks in advance!
I have not read much good about the B6AC V2. Therefore that being the choice I would go with the Accucell-6.
But if you can go a bit higher in price take a good look at the HobbyKing Reaktor charger. For about what you would have spent on the B6AC you could have 300W.
http://www.hobbyking.com/hobbyking/s...dProduct=56924
But for a power supply I would go with a converted server power supply. That way when you decide you need a bigger charger you will have the power supply part covered.
http://www.lipoconnectionsolutions.c...rgers-1244.htm
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Apr 08, 2015, 01:26 PM
Ferdinando is offline
Find More Posts by Ferdinando
Italy, Lombardy, Milan
Joined Apr 2015
if cells are 1s, you can use SKYRC Quattro Micro Battery Charger
it don't need external pws.
Ferdinando is offline Find More Posts by Ferdinando
Old Apr 08, 2015, 02:21 PM
vafan13 is offline
Joined Apr 2007
Glen
Hmm, I'm assuming there's no reason I can't use a regular computer PSU. I have a number of older 400+ watt quality PSUs lying around from old builds. At least I think they are still in the basement.
Old Apr 08, 2015, 02:41 PM
USA, GA, Marietta
Joined Aug 2005
No reason at all as long as you are up to doing the small amount of conversion work.
Glen
Old Apr 08, 2015, 04:44 PM
SilverSport is offline
Find More Posts by SilverSport
25th year Newbie
United States, LA, New Orleans
Joined Dec 2014
HiTec X1 AC .... fits your price range, 50W and people love them. You will just need some charge leads or parallel boards.
I personally would never get something as low as 80W that you also need a DC supply for.
SilverSport is offline Find More Posts by SilverSport
Old Apr 08, 2015, 11:02 PM
vafan13 is offline
Joined Apr 2007
thanks for all the suggestions!
Is this a proper charge harness for doing multiples of the 1c nanotechs and would it work with the suggestions above (accucel, reaktor, X1 AC)?
http://www.overskyrc.com/6s-charging...ies-p-302.html
Old Apr 08, 2015, 11:10 PM
25th year Newbie
Joined Dec 2014
I wouldn't use that, it looks like it charges from the balance port. Shouldn't be a bad thing if the charger will charge with nothing on the main output. I can't say the X1 will do that. I use a 1s balance board that plugs into the main outputs with a black and a red 4mm banana plug. I charge my eFlite 150mAh packs, I don't know about the connector needed for your battery.
Old Apr 09, 2015, 04:47 AM
USA, GA, Marietta
Joined Aug 2005
I think you want something like this:
http://www.amazon.com/Hyperion-Paral.../dp/B005I5GLQ4
Glen
Old Apr 09, 2015, 10:09 AM
Snardo is offline
Find More Posts by Snardo
United States, MD, St Mary's
Joined Apr 2013
Actually, it looks like it uses a JST connector with the balance port. I guess it spoofs the charger into thinking it's charging a 6S battery.
If you're on a budget, I could recommend the Thunder Charger AC680. It's not real fancy but gets the job done. I'm pretty budget minded and I've been using this charger for all my battery charging for a couple years now. It charges 6 1S e-flite style batteries without any trouble. It would just be a matter of finding the right charge harness for the battery type you are using.
Snardo is offline Find More Posts by Snardo
Discussion charger upgrade for micro quad(s) vafan13 Multirotor Power Systems 2 Apr 04, 2015 12:44 PM
Discussion Recommend me a decent Radio for 250 Quad FPV flying helihoshi FPV Racing 17 Mar 25, 2015 08:16 PM
Discussion Where to get a decent case for a portable charger? derelict001 Batteries and Chargers 5 Mar 07, 2015 06:52 PM
Question Looking for a plug and play FPV system for mini/micro quads rctech96 Mini Multirotors 12 Dec 19, 2014 08:53 PM
Discussion What would be a decent controller for my quad? Not the best, but decent.... rcminiman Multirotor Electronics 3 Mar 30, 2014 09:45 PM
