Old Jan 26, 2015, 09:32 PM
payne9999 is online now
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Question
Anyone had Trouble with the Robart Electric Gear?
I received my electric Robart gear for my Giant scale P-47 kit build and to say the least I am disappointed.
It was a real sacrifice to spend nearly $500 just for the mains.
Here is what I have observed:
1. They won't function (kind of a major bummer)
2. Paint chips everywhere
3. Gear legs assembled bassackwards.
Now, one could argue 2 and 3 are now big deal cause war birds get worn but for $500 frickin dollar gear? They should come in a stained oak presentation box (just being sarcastic). Hey, I am a working guy and not one of those that shows up at fly in's with a big trailer and a 50K RV so it is a big deal to drop this kind of money.
Also, the control box has issues:
1. the connectors on the gear are polarized but the connectors to receive them in the control box are not and the opening in the control box allows them to be plugged in either way but you really have no idea if they are making contact.
2. The instructions say to look at the box to see if they are "A" or "B" type but nothing on the box, manual or drawing indicate which type they are.
3. The control box is cheesy, flimsy and looks like what you would expect from China in a $20 receiver.
EVERY SINGLE electric retract I have bought from E-Flite or Hobby King has worked right out of the box and continued to be reliable. However, for this bigger model they don't make gear or gear legs that would really work. So for the Top Flite P-47 I really could only choose between air or electric Robarts.
Anyone else had issues with the electric retracts from Robart????
Dave
payne9999 is online now Find More Posts by payne9999
Old Jan 29, 2015, 07:35 AM
scale_only is offline
Find More Posts by scale_only
# Scale is a way of life
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
Mine worked fine right out of the box,,
Right from the instructions.
The Robart Electric Series uses different motor amp-out
settings depending on the size, weight, and geometry of the
retract. Type A has a lower amp-out threshold. Typically,
smaller retracts and tail wheels require Type A settings.
These actuators will have a Type A sticker on the leads. All
other actuators are Type B unless otherwise noted with a
. When using less than 6.0V, it is
recommended to use Type A settings for all retracts.
I have the original control box, marked type 1/2 not a/b,, and used the jumper not the dip switch, but they work in either position, just faster at the higher amp setting #2
The "#2" sticker is actually on the Actuator cylinder on my tail wheel retract, not on the wire. There is no stickers on the Mains actuators. As the instructions say, no sticker, assume use it on the "B" setting, unless you're running a low voltage system
Polarity? Mine are marked, (-) is to the right, empty signal to the left
Hope this helps,,,, if not contact Robart, you may have gotten a DOA control box
good luck
scale_only is offline Find More Posts by scale_only
Old Jan 29, 2015, 10:56 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
good luck
Apparently the box is DOA, sent it back a couple of days ago. It is just very disappointing to after all these years being able to buy what is supposed to be the best and having it defective.
Dave
Old Jan 29, 2015, 02:49 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Post your findings with the new gear, I look forward to hearing your outcome.
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Old Jan 29, 2015, 03:07 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Will do. Just hoping the new box will come soon so I can make sure they work and carry on with my project.
Dave
Old Jan 30, 2015, 04:47 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've posted this before, about a friend that had a giant TF FW-190 with Robart electric gear. He had to send that gear back 3 or 4 times for repair. It was a variety of problems, mechanical bent metal shafts (not struts), electrical (doa when first received), intermittantly functionality. The straw that sent him over the edge was getting it back, good bench testing, good preflight test at the field, then failed in the air and had to belly in. Sent them in one last time, and sold the plane after he got it back. I'm kinda soured on electrics for now.
Having said that, I took robart air retracts and modified them with firgelli linear actuators. They work fine on the bench, so next step is to do some mods to the wing for fitting. These are commercial linear actuators I stumbled onto about 5 years ago and finally got some to experiment with. Since then, they've started advertising here on rcg. You can get them with a standard receiver interface that will operate them proportionally. You can select different gear ratios and different lengths. I should have mine installed and functional about mid summer in my TF P-47. I might have to make a few end fittings to connect to the rotating shaft on the Robarts but so far my prototype works fine. I just have to cut open a hatch in the wing and cut a hole in an adjacent wing rib for the actuator to fit into. It's longer than the current robart, Eflite, or other rc specific actuators currently on the market.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jan 30, 2015, 06:59 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Hey edwin. Could you post a few pics and some details of which Firgelli actuators you installed?
I have been thinking of trying some out. They look like the top choice for being able to make the best scale operating time for retracts.
davidmc36 is offline Find More Posts by davidmc36
Old Jan 30, 2015, 08:17 AM
Joined Sep 2003
Heres what Ive done so far. I have to finish some other planes first before I get back on the P-47. Its that time of the year again, cycling batteries, and general airframe maintenance. You can see one modified and one stock. Since they are a bit long, I need to make a hole in an adjacent rib. I took a little grinding on the plastic, just a very minor amount. The aluminum side frames are stock 1/16" aluminum plate, very easy to fabricate. You have to program the actuator throws at the transmitter. So I start with throws both directions at about 20% and adjust from there until they lock. These are the L16-R series, L16-50-63-6-R is the part number. I dont remember which gear ratio I ordered. Might be 50:1 based on what I see in the part number, not sure.
Edwin
Old Jan 30, 2015, 08:18 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
I am also looking into this source for future projects:
http://www.shindinmachine.com/
Dave
Old Jan 30, 2015, 08:44 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by edwin1 View Post
Heres what Ive done so far....
Sweet info. Thanks.
Old Jan 30, 2015, 09:12 AM
scale_only's Avatar
Joined Apr 2010
Edwin
So are you using a separate channel for each actuator??
Did you make a custom piece for the pin attachment or grind/drill the actuator shaft
Old Jan 30, 2015, 06:50 PM
Joined Sep 2003
Made a custom piece. The end fitting that came with it was plastic. I didn't think that would be strong enough. I made the side rails out of 1/16" aluminum plate. It took a little grinding on the plastic cam housing for some clearance, very minimal.
Haven't gotten far enough to decide on two channels or Y cable. I use a DX18 so channel count is not an issue for me. With two channels I can control the speed of each retract independently and slow them down or run one slower than the other.
Edwin
Old Jan 31, 2015, 07:04 AM
scale_only's Avatar
Joined Apr 2010
Good info,,, hadn't looked at those in a while,,, looks like the price has come down and they have many more sizes, might be an option now
Old Feb 01, 2015, 12:47 PM
Martin5465 is offline
Find More Posts by Martin5465
Martin5465's Avatar
United States, TX, Haltom City
Joined Mar 2013
This may be irrelevant to your problem but in another thread
on Robart electrics it seems part of the malfunctioning problem
was due to inadequate battery voltage.
Martin5465 is offline Find More Posts by Martin5465
Old Feb 02, 2015, 10:03 PM
radfordc is offline
Find More Posts by radfordc
radfordc's Avatar
United States, KS, Lansing
Joined Jan 2002
That's pretty much the same experience I had with Robart electrics.
radfordc is offline Find More Posts by radfordc
Discussion has anyone had troubles with the new spektrum ar6255 sportsman Electric Plane Talk 4 Oct 22, 2010 12:36 AM
Question Anyone had trouble with a 9CAs Synth usinf crystal based RXs? RobZ Radios 0 Sep 29, 2008 08:08 PM
Question Anyone had troubles with Infinity Hobby? darmar Trader Talk 13 Jan 24, 2007 08:29 AM
Poll Anyone had troubles with Intellect 1200 2/3A cells Jeremy Z Batteries and Chargers 3 Apr 18, 2006 01:02 PM
Has anyone had trouble with the Tower pro 30 amp esc for brushless motors? randall1959 Electric Plane Talk 0 Sep 19, 2005 11:57 AM
