Old Jan 24, 2015, 08:24 PM
osman1986 is offline
Find More Posts by osman1986
Cpt.
osman1986's Avatar
United States, NC, Benson
Joined Aug 2012
Question
disharging nimh
I have a jr 1500mah 4.8v 4c nimh pack which is brand new. I charged it with a trickle charger about 30 hours for the initial charge and got a peak of 5.6v. I am currently just leaving the rx on to discharge it and I need to know at what point should I stop the discharge. I have a map that reads the voltage that plugs into my rx so I am going off of that. I was also reading about a 12v light bulb that I could wire to a battery connector that would discharge the battery at a quicker rate, has anyone tried this? If I had the money to get a nice charger and discharger I would already have it, but I don't so I'm trying to work with what I have here.
osman1986 is offline Find More Posts by osman1986
Old Jan 24, 2015, 08:52 PM
vollrathd is online now
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
If you're trying to discharge your battery with only the receiver, that could take several days.
Another option is to take a run to your local Radio Shack, and pick up a 10 Ohm, 10 Watt power resistor.
http://www.radioshack.com/10-ohm-10w...l#.VMRak_7F90Y
With around 5 Volts DC, your current will be I=E/R, or 5 Volts/10 Ohms which equals 0.5 Amps.
With a 1500 Mah (1.5 Ampere Hour) battery, your battery should last 1.5/0.5 or around 3 hours.
You can discharge your battery down to around 1.0 Volts per cell, or 4 Volts DC with no problems. At 4 Volts DC, your batteries voltage will be dropping like a rock, you need to keep a close eye on it.
Or, just run it for two hours, and if the battery is still holding around 4.4 Volts DC, call it "good"
vollrathd is online now Find More Posts by vollrathd
Old Jan 24, 2015, 10:01 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
So here is what I did with the materials I could find around the house. I found a igniter from a old rocket launcher and soldered a battery lead to it that would plug in to the charge hookup. I taped the safety key in place so the light would stay on. Now all I have to do is flip the power switch on the plane and I can get a current volt reading from my maping device that is plugged into my rx. I have heard mixed opinions on weather or not to cycle the nimh batteries, what is your opinion on that? So you are saying that I should discharge the battery down to 4.4v before I put a charge on it? Pics coming momentarily.
Old Jan 24, 2015, 10:07 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
Old Jan 24, 2015, 10:19 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
First question :
Why are you discharging your NiMh ?
Second :
What do you hope to achieve by doing this ?
Nigel
solentlife is offline Find More Posts by solentlife
Old Jan 24, 2015, 10:32 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
It is a new battery and the guy at the hobby store said I should cycle it a few times before I use it.
Old Jan 24, 2015, 10:33 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
Or am I good to go after the initial charge?
Old Jan 24, 2015, 10:35 PM
Dukat is offline
Find More Posts by Dukat
Dukat's Avatar
United States, CA, San Diego
Joined Jan 2013
If you want to discharge the battery hook up a LED light it a light build and let it sit there.
Dukat is offline Find More Posts by Dukat
Old Jan 24, 2015, 10:47 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
I tried a led light and it wouldn't work for some reason.
Old Jan 24, 2015, 10:50 PM
GMB48 is offline
Find More Posts by GMB48
GMB48's Avatar
Joined Oct 2009
Cycling new Nixx battery packs, usually about 3 to 5 cycles, will bring them up to full potential. Having a charger that is programed to do cycles is the best way to go but I see you are having to do without a charger having that feature. Just be careful that you don't discharge them too far nor overcharge them to where the pack becomes hot. Discharge down to 1 volt per cell should be fine and expect about 5.6 volts for a full pack. Once a pack is full, excess charging is given off as heat. Therefore you will feel the pack warming up once it is full. A few degrees above room temperature is okay but don't let them get hot.
GMB48 is offline Find More Posts by GMB48
Old Jan 24, 2015, 11:16 PM
Dukat is offline
Dukat's Avatar
Joined Jan 2013
Could have been a 12V LED, it wont come on if you power less....unlike an incandescent where it will but dim
Old Jan 24, 2015, 11:39 PM
solentlife's Avatar
Joined Jan 2010
Fair enough ....
But usually a good charge up initially and then use is good enough ...
Very few people actually use full capacity of batterys and I assume you will charge up model after a sessions flying ...
I use 2300mAh NiMH in my models / Tx's - never do cycle charges except to check periodically. Many of mine are over 2 yrs old - some 3yrs. They are all delivering same as when new and near enough stated capacity.
As example : My Tx's use 8 cells ... all 2300mAh AA's. None have been cycled, but I get over 9hrs use of Tx before Low Volt alarm sounds - even with my old 2 - 3yr olds. Average Tx uses 250 - 300mA .... simple maths ... 9 x 250 = 2250mAh .... and that's at LVA meaning there is still life left in the cells. QED.
To be honest all you do with cycling is use up lives of the batterys.
Others will disagree I know - but that's life.
Nigel
Old Jan 24, 2015, 11:41 PM
solentlife's Avatar
Joined Jan 2010
As a standard Rx pack - yes I would. But then again I'm like that.
Nigel
Old Jan 24, 2015, 11:50 PM
Cpt.
osman1986's Avatar
Joined Aug 2012
Ok, well thanks for the advice! I discharged it down to 4.8v but I'm not staying up waiting for it any longer so I took it off and put the charger on it so it will be ready for tomorrow. I have flown it prob 8-10 times on the initial charge and it only went down to 5v so I'm guessing at that rate I should be ok without cycling it a few times. I may try to do it on the next rainy day!
Old Jan 24, 2015, 11:59 PM
solentlife's Avatar
Joined Jan 2010
All three of these are flown on 4.8v NiMH 2300mAh packs. None are cycled - except occasionally to check capacity is still good. The model in centre is over 3 yrs old ...
Never had any brown-outs - I fly FrSky anyway which I've never heard it happen with ... never had any problems.
The Pitts to the left has an LED power indicator on the side of fuselage next to Rx switch. Even after a days flying .. maybe 3 ~ 4 x 10 min flights - it's still in green.
Nigel
Question X4 Lipo disharge voltage BigR Hitec/Multiplex USA 0 Dec 15, 2014 11:25 PM
Discussion Is my Turnigy LSD 6.0V 2300 Mah Reciever battery disharging / charging correctly ? DieselDesigns Batteries and Chargers 4 Aug 16, 2014 04:46 AM
shulze and lipo disharge question NCguy Batteries and Chargers 10 Sep 28, 2005 08:58 PM
Sold 15C High Disharge cells $9 supi7 Aircraft - Electric - Airplanes (FS/W) 3 Aug 02, 2005 06:36 PM
Astro Lithium Disharge function? JohnTz Batteries and Chargers 21 Jan 20, 2004 11:20 PM
