Old Mar 07, 2014, 01:49 PM
blakeanderson is offline
Find More Posts by blakeanderson
Florida Fpv
United States, FL, Santa Rosa Beach
Joined Aug 2011
Will the tarot gimbal work on an airplane? I have found that it can be inverted (sensor too), just not sure if anyone has flown it at 30-40MPH and it do ok?
blakeanderson is offline Find More Posts by blakeanderson
Old Mar 07, 2014, 01:53 PM
w1msg is offline
Find More Posts by w1msg
Joined Oct 2013
Its about as aerodynamic as a Brick. I seriously doubt the gimbal motors could over come the winds at those speeds.
w1msg is offline Find More Posts by w1msg
Old Mar 07, 2014, 03:43 PM
muscleflex is offline
Find More Posts by muscleflex
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
I just got my gopro video connector but it was bent - is it ok to rebend it back to place or return it?
muscleflex is offline Find More Posts by muscleflex
Old Mar 07, 2014, 03:45 PM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
muscleflex: Just try it, it might be fine. You can always send it back later.
glmccready is offline Find More Posts by glmccready
Old Mar 07, 2014, 04:00 PM
laserj is offline
Find More Posts by laserj
United States, WI, Chippewa Falls
Joined Dec 2012
Mine was bent, not as bad but I was able to bend it back. If it breaks send the pics to the vendor for replacement.
laserj is offline Find More Posts by laserj
Old Mar 07, 2014, 04:03 PM
HexaFlexa is offline
Find More Posts by HexaFlexa
HexaFlexa's Avatar
United Kingdom, England, Addlestone
Joined May 2012
Yeah you have photo evidence its been stomped on try it. The seller probably wont even ask for it to be returned so you might end up with 2.. Or a bent but working one for Freeee
HexaFlexa is offline Find More Posts by HexaFlexa
Old Mar 07, 2014, 06:16 PM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
Ok thanks - I'll open it and will try it.
Old Mar 07, 2014, 06:32 PM
ElGuano is offline
Find More Posts by ElGuano
Joined Sep 2013
Ugh. The pins inside are SUPER delicate. My Tarot cable lasted less than a week before the USB pins gave out I had to get a USB cable with a metal jacket at the plug.
ElGuano is offline Find More Posts by ElGuano
Old Mar 08, 2014, 01:21 AM
PinDuke is offline
Find More Posts by PinDuke
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
I would not use that cable. If you are unlucky i might short out costing a lot more to fix then a new cable.
PinDuke is offline Find More Posts by PinDuke
Old Mar 08, 2014, 08:21 AM
John2905 is offline
Find More Posts by John2905
John2905's Avatar
United Kingdom, England, Hertfordshire
Joined Nov 2012
USB Plug retaining screw.
I have been searching this thread to find the size do this screw with no results. Probably there but I missed it. Can anyone help with the size please.
John
John2905 is offline Find More Posts by John2905
Old Mar 08, 2014, 09:41 AM
clough42 is offline
Find More Posts by clough42
Director of Esoteric Projects
clough42's Avatar
Joined May 2012
John
Uhh...what screw do you need help with?
clough42 is offline Find More Posts by clough42
Old Mar 08, 2014, 09:42 AM
Gary
glmccready's Avatar
Joined Mar 2011
If it looks like the pins might be touching you can always check the continuity of the leads.
http://electrical.about.com/od/elect...continuity.htm
Old Mar 08, 2014, 09:50 AM
ElGuano is offline
Joined Sep 2013
That's pretty tough with a connector that small: the pins are tiny, it's a 10-pin so there are pins bent on the unexposed side as well, and I think 7 out of the 10 of those pins are intended to be NC and one of the remaining ones has a resistor to ground. When mine failed I wasn't really able to get in there and test anything. I had to shine a bright light into the plug and see one of the pins had crunched all the way into the back.
Old Mar 08, 2014, 11:24 AM
Gary
glmccready's Avatar
Joined Mar 2011
ElGuano: Thanks for that info, those things are pretty small. They are supposed to be designed for 1000 of cycles. Of course, we are talking Chinese manufacturers, so who knows.
I did smoke a Gopro (but it still works), with 12v (3S) once. I smelled it before I saw it, and unplugged quick. Got my FPV Camera (12v) and GoPro (5v) leads reversed.
Old Mar 08, 2014, 11:28 AM
John2905 is offline
John2905's Avatar
Joined Nov 2012
It's the one that retains the USB plug for the GoPro. It screws into the Tarot GoPro mount. Looks like it is the one shown a few posts back in the poly bag. I think it could be M2 x 5 but I would like someone to confirm this before I order some.
John
Build Log GoPro Hero 3 Brushless Gimbal (Plywood) Skewp Multirotor Talk 20 Feb 21, 2015 06:57 AM
For Sale TAROT ARTF Brushless motor Gimbal by TACOTOY for DJI PHANTOM GOPRO 3 rctaco Aircraft - Electric - Multirotor (FS/W) 28 Jan 23, 2015 04:16 PM
Sold Brushless ready gimbal for gopro hero 3 hdworld Aircraft - Electric - Multirotor (FS/W) 29 Jul 13, 2013 03:32 AM
For Sale Brushless ready gimbal for gopro hero 3 hdworld Aircraft - Electric - Multirotor (FS/W) 15 May 06, 2013 07:42 AM
Sold Complete Brushless Gimbal Setup for GoPro Hero 2 crd FPV Equipment (FS/W) 2 Apr 28, 2013 10:14 PM
