Old Aug 21, 2012, 08:38 PM
beach1 is online now
Find More Posts by beach1
ALES AVA flap4
Guys: I am looking for data on the new Ava Pro Flapped 4 electric. I am interested in power set up, weight, servos selected for elevator/ rudder in tail. How much weight if any did you add to nose for balance...responses appreciated
beach1 is online now Find More Posts by beach1
Old Aug 22, 2012, 07:44 AM
jh2rc97 is offline
Find More Posts by jh2rc97
Dallas, TX
Joined Jan 2005
While it is not the Pro version I did assemble a AVA-EF about a year ago. Here is the build thread.
http://www.rcgroups.com/forums/showthread.php?t=1488024
Motor: Neu 1110/1.5Y/5.2
ESC: ICE50 Lite
Battery: 3s A123 2300 (Also has a 2s A123 1100 for Rx)
Servos:
Flaps - HS-85MG
Rudder - HS-5065MG
Elevator - HS-5065MG
With all the battery weight I have up front I have had to add about 1/4 oz to the tail to balance. Total weight is 61 oz and I don't remember what prop I am using but power is ~360 watts and it takes about 20-25 seconds to make it to 200m.
jh2rc97 is offline Find More Posts by jh2rc97
Old Aug 22, 2012, 04:14 PM
Bob J is online now
Find More Posts by Bob J
Fond du Lac, WI
Joined Mar 2005
Here is the setup I am using in my AVA 4-Flap:
Motor: Hacker B-40 10L 4.4:1 gearbox
Prop: AeroNaut 16 X 8
ESC: Castle ICE Lite 100
Battery Thunder Power 1800 mah 3S
Servos:
Rudder, Elevator MKS DS6125
Ailerons HiTec HS-5125
Flaps JR DS 378
Climbs to 200m in about 24-26 seconds.
I had a couple of problems in assembling mine:
1 - The vertical fin did not mate properly with the tailboom; the tailboom was too large in diameter.
2 - The wings did not mate properly with the fuselage; the spacing between the holes in the wings was considerably different than the spacing of the bolt holes in the wing pylon.
3 - The wing saddle mates poorly with the fuselage.
If you order one I would suggest that you carefully check all pieces for proper fit before beginning assembly.
Regards,
Bob Johnson
Bob J is online now Find More Posts by Bob J
Old Aug 28, 2012, 08:47 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
Dude,
An affordable approach with competitive edge.
MKS 6100 all around, maybe 378's for flaps.
HK 2221/10 - 3000KV
with Micro Edition 5:1 NL from Reisenauer's
CFK 19x8 prop, Reisenauer spinner.
Sunrise 60A ESC ( http://www.reisenauer.de/artikeldetails.php5?aid=1421 ) , the only chinese electronics I use. no need for an external BEC.
TP 3S LIPO 1800mAh 65C.
Good to go.
André
Jebera is offline Find More Posts by Jebera
Found standard ava flapped wing or whole ava Greg Athey Aircraft - Sailplanes (FS/W) 5 Jul 26, 2012 11:20 PM
Found Ava-E, or Pulsar, or other ~3m E thermal plane. doo Aircraft - Sailplanes (FS/W) 2 Jun 11, 2012 03:47 PM
Wanted ava or ava pro wing tips bigwheels0 Aircraft - Sailplanes (FS/W) 1 Apr 17, 2012 04:42 PM
Discussion ALES - Let's discuss non-Radian foamies for ALES aeajr Electric Sailplanes 20 Feb 05, 2012 12:26 AM
Sold AVA Pro E -- ALES PLANE dharban Aircraft - Sailplanes (FS/W) 1 Dec 01, 2011 08:03 PM
