Old Aug 02, 2012, 02:17 PM
Ruyman is offline
Find More Posts by Ruyman
Tenerife (Spain)
Joined Feb 2007
Help!
Help with the assembly of the Snipp Pylon Racer!!
Hello friends!
I just purchased this model of pylon, I'm waiting that I get and I will equip follows:
http://www.espritmodel.com/snipp-pylon-racer-arf.aspx
-3-servo HS-65HB
- 3S 2200 35C/70C
-2w-20 Het + apc 4, 75 x 4, 75 + Esc 80amp (static 47 amp., and 487 Watts)
See do not want to move from 500 Watts of power. First because I don't know to how many Watts you can hold this model with security and thus also will increase the longer flight.
Would I like to know if someone possesses the manual online, as if it is necessary to modify something in the assembly and if the CG that brings the manual is correct?
Thank you.
Ruyman is offline Find More Posts by Ruyman
Old Aug 03, 2012, 10:39 AM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
I don't have a Snipp but this might help you: http://www.rcgroups.com/forums/showt...w+fast+s+snipp
arcticflyer is online now Find More Posts by arcticflyer
Old Aug 08, 2012, 04:40 AM
Ruyman is offline
Tenerife (Spain)
Joined Feb 2007
Thank you arcticflyer!
I've been reading various open wires and it seems the wing must be sanded so that it fits well in the fuse. The CG must delay it and I was not clear if the engine bed has zero impact and affect the flight of the aircraft!
Sold Snipp Pylon Racer JDsF16 Aircraft - Electric - Airplanes (FS/W) 1 Oct 16, 2011 05:32 PM
Discussion Snipp Carbon Pylon Racer Esprit Model High Performance 0 Mar 15, 2011 12:55 PM
Discussion New toys Snipp & Trick Pylon Racers Esprit Model High Performance 5 Oct 27, 2010 10:15 PM
Wanted Snipp or similar Electric Pylon racer Flying Low Aircraft - Electric - Airplanes (FS/W) 0 Mar 31, 2008 08:16 AM
Help, questions, and advise needed with Az-Shrike Pylon Racer Saeed Foamies (Kits) 0 Feb 22, 2004 07:44 PM
