Old May 02, 2012, 10:21 AM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
McCoy .19 stunt engine
My mate has acquired a McCoy .19 engine. It is the CL version, with a red head.
Anyway, it ran very badly. I determined that it had been assembled with the incorrect orientation of the cylinder liner.
It now runs pretty well.
BUT. .. the piston has a machined protrusion on its crown; something to do with squishing, I expect. This protrusion is offset to one side, effectively screening the inlet ports from the exhaust ports. I'm sorry, I don't know the correct name for this protrusion.
My question is, "should the protrusion be closer to the exhaust ports, or the inlet ports. In other words, how do I tell whether the piston is correctly orientated?"
Hope that makes sense.
While you're at it, can you explain how this thing works?
bogbeagle is offline Find More Posts by bogbeagle
Old May 02, 2012, 10:51 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes they call that style of engine a crossflow scavenged or loop scavenged engine.
The baffle on top of the piston is used to cause the air/fuel charge to loop up and over so that less of the air/fuel charge goes out of the exhaust port.
The baffle is located closest to the transfer port on the engine farthest from the exhaust port.
earlwb is offline Find More Posts by earlwb
Old May 02, 2012, 11:42 AM
Joined Mar 2007
Ah, thanks.
I'd figured that was its purpose. Made the changes. It now runs like a good un.
Not a bad buy at 7... the previous owner thought he was selling us a knackered engine. It will be going in something vintagey.
Old May 02, 2012, 01:38 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is a pretty good deal for you. They can be a lot of fun and they run pretty good too.
Old May 02, 2012, 02:28 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
The McCoy Redhead 19 is a favorite engine. A friend had one on a Brodak trainer. It would fly the trainer, but not very well. It had the reversed liner as you describe. I've bought several cheap fleamarket engines which had the same fixable problem. I have several of the engines. I have one on a trainer which has had 100's of flights. It has no compression, but is usually a one flip start, given head prime and a choke, and runs to suit. Running all castor fuel, maybe 25% oil, will serve your engine well. Mine is running on Sig champion 10% nitro, 20% oil, half castor, half synthetic. Any expert will tell you that my fuel is not what is usually recommended.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old May 03, 2012, 02:35 AM
Joined Mar 2007
These engines are not too common in the UK. Well, I've never seen one, in 20-odd years of model flying.
I dunno what fuel we were using... nothing exotic, though.
The only other McCoy I can recall, came with one of those plastic CL models ... late '60s, I think.
Old May 05, 2012, 05:14 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
Feed it lots of castor, don't ever let it run lean. The McCoy P/L are relatively soft and will get wasted very quickly on a lean run.
NACA0012 is offline Find More Posts by NACA0012
Old May 15, 2012, 09:20 AM
706jim is offline
Find More Posts by 706jim
I had one of these years ago and could never get it to run. Perhaps mine had the liner reversed as well.
706jim is offline Find More Posts by 706jim
For Sale Antique McCoy .19 CL engine in great condition nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 25, 2012 07:48 PM
For Sale Antique McCoy Super Stunt 36 nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 12, 2012 09:31 PM
For Sale 3 McCoy .19 controline engines $60 shipped sagomon Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 02, 2012 09:47 AM
Help! McCoy .19 with 2 needle, 2 speed engine. Transplant92 Engines 2 Dec 12, 2011 02:47 PM
For Sale veco 19+mccoy 19 pugstrip Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 15, 2009 10:09 AM
