Old Apr 03, 2012, 08:55 PM
syzygyQ is online now
Find More Posts by syzygyQ
Joined Oct 2011
Helidrive ESC
Originally Posted by sp00fman View Post
Promised a follow up... this ESC is GREAT!
Onboard 6A switching BEC: 5,5V unloaded, 5V at 6amp (real test with lightbulb)... pass!
Softstart mode - Heli fast: just flip to idle1 and go fly... pass!
Govenormode - with active flywheel enabled : Headspeed nice and constant and heli feels powerfull in all moves. no bogging.... pass!!
Weight: 60g with connectors. its a bit heavy, as a Plush 30Amp + Sbec also work fine at 30g, but the weight gain is not all that noticeable.
www.youtube.com/watch?v=7gyoigbGiAw
This is the only item still on backorder for my 450 build. Your video confirms that it's worth waiting for.
Thanks!
syzygyQ is online now Find More Posts by syzygyQ
Old Apr 03, 2012, 09:11 PM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Yep definately the EXI 450 PRO is just as good as the HK450
EXI 450
Exi 450 pro how low can it get video #2 (5 min 30 sec)
HK450
Copterx FBL unit in HK450 (4 min 26 sec)
hgc.trex 450 (5 min 38 sec)
pitchp is offline Find More Posts by pitchp
Old Apr 04, 2012, 09:54 AM
Kam Arrow is online now
Find More Posts by Kam Arrow
Citizen #302
USA, OR, Canby
Joined Oct 2007
Originally Posted by evltoy View Post
helical gears run quieter, but are weaker then straight cut gears. This is the why I install straight cut gears in my rally car gearbox.
With the shaft snapping, it could be the mesh was not setup correctly, grub screw into pinion too tight and fractured the shaft or just a weak shaft in the 2218H motor.
The 2218 has a weak shaft, it is 3.17 mm where the pinion fits but steps down to 3mm where it goes into the can, and that is right where it snapped.
Kam Arrow is online now Find More Posts by Kam Arrow
Old Apr 04, 2012, 10:29 PM
nickxx4360 is offline
Find More Posts by nickxx4360
P-P- Playoffs??
nickxx4360's Avatar
Joined Feb 2012
Update: programmed the esc. I soldered motor connections, esc and ubec. I used the XT60 connectors for the esc. I did a bind process to my receiver, hooked all the servos, esc and motor. Everything powered up and worked great!
I am so excited. I hope to be done with the kit for this weekend.
nickxx4360 is offline Find More Posts by nickxx4360
Old Apr 04, 2012, 10:39 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
I just ordered 3 HK450 GT heli's and 4 airwolf fuselages
Black_heart is offline Find More Posts by Black_heart
Old Apr 04, 2012, 10:47 PM
Joined Oct 2011
Way to go Buddy!!!
I'm rooting for you big time!
Old Apr 05, 2012, 04:41 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
For all you 4S 450 fans, here's a nice motor.
http://www.hobbyking.com/hobbyking/s...tor_400w_.html
Turnigy L2815-2700 Brushless Heli Motor (400w) 4S/450 size Heli
Spec. 4S
RPM/V: 2700 KV
Voltage: 14.8v(4s)
No load Current: 1.5A
Max Current: 35A
Max Power: 400W
Shaft Size : 3.175mm
Shaft Length: 18mm
Dimension: 28mm x 36mm
Thrust: 690g
Weight: 66g
Old Apr 05, 2012, 07:51 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
And of course the 3S fanatics
http://www.hobbyking.com/hobbyking/s...0kv_430w_.html
Turnigy L2815H-3450 Brushless Heli Motor (400w) 450 size Heli
Spec.
RPM/V: 3450 KV
Voltage: 11.1v(3s)
No load Current: 2.6A
Max Current: 42A
Max Power: 430W
Shaft Length: 18mm
Thrust: 600g
Weight: 66g
Old Apr 05, 2012, 08:26 AM
P-P- Playoffs??
nickxx4360's Avatar
Joined Feb 2012
WOW! That is so eye candy!
I want one, or two. would make great replacement motors
Old Apr 05, 2012, 09:22 AM
whitejoy is offline
Find More Posts by whitejoy
Joined Oct 2009
Spec.
RPM/V: 3450 KV
Voltage: 11.1v(3s)
Max Current: 42A
Max Power: 430W
Shaft Length: 18mm
Thrust: 600g
Weight: 66g
Is the "flat spot" for the pinion screw on the shaft on the wrong side? Should it at the bottom of the shaft. instead of at the top?
whitejoy is offline Find More Posts by whitejoy
Old Apr 05, 2012, 11:08 AM
Exi450 is offline
Find More Posts by Exi450
Joined Apr 2012
Hey, Exi 450 pro or Hk450 pro , both belt driven? WHich one for a begginer, most stable one? What electrics do you reccomend?
Exi450 is offline Find More Posts by Exi450
Old Apr 05, 2012, 02:24 PM
john aeras is offline
Find More Posts by john aeras
john aeras's Avatar
Canada, ON, Toronto
Joined Jan 2009
Both are similar, stability depends on electronics. Read a few pages back, alot of suggestions on electronics.
john aeras is offline Find More Posts by john aeras
Old Apr 05, 2012, 02:35 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Perhaps you can install the pinion upside down on this motor
Seriously, it looks like a nice motor. I have one from this series on my 250 and its nice for its price. Smooth and powerful now, BUT it came with terrible bearings in there. I hope this mother is better build.
Any info about the inner shaft diameter? I sure hope its 4mm and not 3,17 or 3mm.. Its hard to find 3,17 ID bearings and impossible to find 3mm shafts with 3,17mm ends.
sp00fman is offline Find More Posts by sp00fman
Old Apr 05, 2012, 09:45 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
that is so true!
Old Apr 06, 2012, 12:41 AM
mhills51 is online now
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I was just thinking of selling one of my HK450's. The one with all blue aluminum and the scary movie canopy, but I thought I don't want to pack it all up and I don't think I would get that much out of it. Even though it's never been crashed and is all set to fly. I just took it up last weekend and thought is was such a slug after flying my 450pro and the 250's. To change it would cost more than I am willing to put into it and it would still be nothing but a old 450se.
That is when a idea hit me. Slap some training gear on that and give it to one of your boys, but is that child abuse? Getting your own son addicted to a drug this strong? ohh the humanity's
mhills51 is online now Find More Posts by mhills51
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 21 Feb 25, 2010 12:48 PM
