Old Oct 27, 2010, 05:37 PM
Chatenever is offline
Find More Posts by Chatenever
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Different Type of Lipo Construction?
I recently needed to dispose of a worn-out Zippy lipo. As per my usual protocol, my first step was to puncture the lipo inside a metal container to let the fluid inside leak out. In the past, this was sometimes a rather exciting experience, because one never knows how much "activity" will be produced from doing this. However, THIS time, when I punctured the cell, NOTHING leaked out. Curious, I proceeded to further cut away at the cell, and inside I found what appeared to be a stack of copper-like paper-thin plates individually coated with a black substance, and separated from adjoining plates by paper. I'd never seen Lipo cells before that did not contain fluid. Can anybody comment on the differences between the dry lipos and the wet ones?
Chatenever is offline Find More Posts by Chatenever
Old Oct 27, 2010, 05:51 PM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
I'm in battery mode reading up on lipos a lot. I just found a webpage that described lipo technology in some detail.
It said there is no "liquid electrolyte solution" like you find in other batteries. I think its all solid phase, but don't quote me on that.
rotagen is offline Find More Posts by rotagen
Old Oct 27, 2010, 07:16 PM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Yes, you're right. But every time prior to today when I punctured a Lipo, there WAS a liquid electrolyte solution inside. I was just wondering when the change came about, if the design changed with all Lipo brands, and what was the effect of that change.
Old Oct 27, 2010, 11:23 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Most new packs I destroy has a paste that, when overheated, becomes a goo like liquid.
I agree, I think it may be the new technology out there.
Rick
rampman is online now Find More Posts by rampman
Old Oct 28, 2010, 03:12 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
You are subjecting yourself to a dangerous situation by puncturing a LiPo.
The proper method of rendering a dead LiPo safe is to discharge it to zero via an automobile tail light or other form of resistance. When the light goes out short the two discharge leads together (solder or crimp). When discharging the pack may swell but will not burst.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Oct 28, 2010, 03:40 PM
rotagen is offline
rotagen's Avatar
Joined Jan 2005
If they piss me off enough, I like to puncture them with a compressor powered air cannon firing 6 inch lead spheres from about 20 yards. Either that or discharge a small plastic explosive underneath them after soaking with propane.
Old Oct 28, 2010, 04:05 PM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Originally Posted by rotagen View Post
if they piss me off enough, i like to puncture them with a compressor powered air cannon firing 6 inch lead spheres from about 20 yards. Either that or discharge a small plastic explosive underneath them after soaking with propane.
lol
Discussion I am so confused on what to buy, I hear different things from different stores sherlockshah Batteries and Chargers 17 Oct 08, 2010 05:42 PM
Discussion to use a s3 1300 mah lipo in series with 2 motors can type Rhondas Power Systems 13 Sep 06, 2010 05:42 AM
Discussion Connect 2 x Lipo in parallel (Different type) falcon16 Batteries and Chargers 13 Dec 04, 2006 11:59 AM
Will different charge rate give different discharge rate for lipo? eta Batteries and Chargers 7 Jan 17, 2005 10:23 AM
A bit different type of foam construction. mad mike Foamies (Kits) 1 Aug 06, 2004 10:09 AM
