Old Sep 01, 2013, 09:51 AM
sailorboy898 is offline
Find More Posts by sailorboy898
Joined Feb 2009
I know this thread is pretty dead.
But I'm modifying my first Pogo for some speed and thought I'd share.
First thing I did was glass the center section of the wing.
I'll probably get some pylon racing wheels and ditch the stock wheel and pants.
I've got a Turnigy 3648 1450kv motor.
5s 3000mah 40c battery.
getting a hobbywing 100s esc.
Hitech hs225 bb servos.
I'm going to add down thrust and right thrust to the motor.
Not sure yet how I'll get the cowl to fit.
Maybe once the thrust is dialed in Ill re-mount the motor mount to line up with the cowl.
Here's the first picture of my fiberglass job.
I'll keep posting as it progresses.
sailorboy898 is offline Find More Posts by sailorboy898
Old Sep 15, 2013, 09:48 PM
Joined Feb 2009
Progress on my Pogo.
I hated the coloring scheme, especially the school bus yellow.
I don't know why they didn't add some right thrust and down thrust.
I hate this stupid little landing gear and tail wheel set up.
So I've done some modifying.
Here's some progress pictures.
Old Sep 29, 2014, 12:02 PM
mvd1968 is offline
Find More Posts by mvd1968
The Netherlands, NH, Nieuw-Vennep
Joined Sep 2013
Got some Turnigy nano-tech 4000mah 4S 25~50C Lipo Pack lying around here.
Does this fit the pogo?
Capacity(mAh) 4000
Config (s) 4
Discharge (c) 25
Weight (g) 433
Max Charge Rate (C) 5
Length-A(mm) 173
Height-B(mm) 48
Width-C(mm) 26
mvd1968 is offline Find More Posts by mvd1968
Old Sep 29, 2014, 01:47 PM
rpotts is offline
Find More Posts by rpotts
Joined Jun 2008
Will these 4000's fit
Quick answer, I don't know if they will fit.
However, I can tell you that the 3000 mAh 4S 25C Nano-techs that I have fit my pogo with room to spare (flew mine yesterday as a matter of fact.. Their length is perfect. I slide the battery as far forward as it will go, the wires end up meeting up with the canopy. I rubberband some spongy padding to either side of the battery to keep it secure along with a small piece of velcro on the tray area to help secure the battery from sliding fore-aft. Look up 3000's on the Hobbyking website and see how the dimensions compare to the 4000's. I found the numbers given for the 3000's to be accurate. If the 4000's are not much thicker and any longer I don't think you will have any trouble. If it is longer you could face CG issues and canopy/battery interference problems, the latter being the bigger issue. Good luck.
Capacity(mAh) 4000
Config (s) 4
Discharge (c) 25
Weight (g) 433
Length-A(mm) 173
Height-B(mm) 48
Width-C(mm) 26
rpotts is offline Find More Posts by rpotts
Old Sep 30, 2014, 12:45 AM
mvd1968 is offline
Joined Sep 2013
Think the 4000 is to long
Capacity(mAh) 3000
Config (s) 4
Discharge (c) 25
Weight (g) 299
Length-A(mm) 150
Height-B(mm) 45
Width-C(mm) 24
Old Today, 10:43 PM
joeydog36 is online now
Find More Posts by joeydog36
Micro Man
Canada, ON, London
Joined Oct 2014
would anyone happened to know the dimensions of all the pieces in the front end from the where the leading edge of the wing to the fire wall? someone gave me three pogo's and all of them have the front of the fuse gone where the cowl goes over and would like to rebuild. All I have is the fire wall attached to the motor and where the front of the wing is attached to the fuse and back, I appreciate any replies and thanks in advance. Steve
joeydog36 is online now Find More Posts by joeydog36
E-Flite lower rudder for E-Flite Cub J3 25E bc-slowflyer Non R/C Items (FS/W) 14 Jul 19, 2011 09:23 PM
Discussion Horizon Hobby's 2010 New Release PZ Extra 300 & E-Flite LR-1A Pogo ChuckTseeker Electric Plane Talk 97 Sep 10, 2010 09:20 PM
Link E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others everydayflyer Batteries and Chargers 45 Apr 08, 2010 04:55 AM
Wanted E-flite Byp Yak / E-flite Yak NIB Moxy Aircraft - Electric - Airplanes (FS/W) 3 Feb 23, 2010 06:02 PM
Sold NIB E-Flite Cessna 182 w/E-Flite Brushless 400 motor Eplane Aircraft - Electric - Airplanes (FS/W) 4 Nov 29, 2009 12:32 PM
