Old Jun 21, 2012, 05:47 PM
balsa flys better
micro_builder's Avatar
United States, TX, Fort Worth
Joined Jan 2005
construction suggestions
So i've got this nice new motor from Nitro for my micro hotliner project, I've got the wings and v tail done, but I'm having a hard time figuring out how to go about building the fuselage. I dont want to have a pod and boom style fuse, but rather a full fuse like the pic below.
Wishing I was more skilled in the art of fiberglass molding as I'd really like to do a fully molded fuse, but I dont think that will happen. So I'm thinking maybe a long block of balsa, carved into shaped, then cut down the middle, hollowed out then glued back together...seems like it would work. It could be much easier if I go with a square sided fuse, but I really want it rounded.
Any other suggestions?
Nick
micro_builder is offline Find More Posts by micro_builder
Old Jun 21, 2012, 09:03 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I've built fuses like that before and works well. Easier way is to tack glue two pieces of pink insulation foam together, carve to shape, then split it apart. Hollow out with a soldering gun with a piece of copper household wiring shaped like a spoon. To shape the fuse, make templates from bristol board with the inner shape to the curve of the fuse. Different ones with different shapes as the fuse gets smaller toward the rear. This way you keep both sides of the fuse exactly the same shape. This one was for a 25 sized glow, scratch built many yrs ago before I got into electrics. It was covered with 1/16 balsa, but not necessary for electric. Hope this helps for some ideas.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jun 21, 2012, 10:52 PM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
http://www.rcgroups.com/forums/showt...1376793&page=3
post number three.
Use the technique often.
gklein is offline Find More Posts by gklein
Old Jun 24, 2012, 10:13 AM
balsa flys better
Joined Jan 2005
Thanks guys, I'll have to give both of those techniques a shot.
I've got a long time friend of the family who happens to be an amazing clay artist, I may have to put him to work.
Thanks again,
Nick
Discussion Herr Bonanza under construction Megowcoupe Free Flight 8 Jul 23, 2012 09:56 PM
Help! Need Repair Suggestions - Broken F4D SkyRay; - Oops ADDED PICS !! old_dude Foamy EDFs 7 Jun 20, 2012 12:10 AM
Discussion Adhesive Suggestions for Foam Construction klockwerken Foamies (Scratchbuilt) 24 Nov 22, 2009 10:21 AM
Discussion Suggestions on flight box construction. Grim Reaper The Builders Workshop 16 Oct 26, 2007 04:45 PM
Question Spar Construction Suggestion? Bus Driver The Builders Workshop 24 Mar 17, 2005 10:43 PM
