Old Dec 21, 2013, 02:58 PM
Addicted
United States, CO, Parker
Joined Dec 2011
Question
Gear ratios
Hi guys, first time poster in the Robotics forum.
I'm trying to calculate gear ratios.
I need to increase the speed of a continuous-rotation servo.
I bought a few r/c car drive gears to tinker with. I'm thinking of putting an 84-tooth on top of the servo. That will drive a 28-tooth gear.
84/28 gives me a 3x speed increase. Say I wanted to get more. I could fix the driven 28-tooth gear to another 81-tooth gear. That is a 2.9x increase.
My question is say that servo rotates at 20rpm.
The first stage will increase that to 60rpm. Will the second stage then increase the 60rpm by 2.9 giving me a final rpm of 174rpm?
I feel like I should know this but thought I should check here.
Thanks!
Sixinarow is offline Find More Posts by Sixinarow
Old Jan 01, 2014, 09:09 PM
Denver, CO
Joined Dec 2005
Depends on how you connect the gears. If the 81 tooth is driven by the 28 tooth, it would reduce the rpm back almost to the original rpm. So if the 81 tooth was stacked on the 28 tooth it would have to drive a second 28 tooth gear to get the rpm increase.
Roto Rob is offline Find More Posts by Roto Rob
Old Jan 01, 2014, 10:11 PM
Addicted
Joined Dec 2011
Thanks, Rob. I ended up driving it direct as the servo is plenty fast at 60 rpm (pan for Go Pro).
Help! 1/8 crawler gear ratio... trf_414_m2 Off-road Cars 0 Dec 16, 2013 01:53 PM
Question Proper Fuel/Oil Ratio For A DLE 30 (Update) Rich215 Engines 8 Dec 01, 2013 04:37 PM
Help! Different Pinion and Spur Gear combos that result in the Same Gear ratio! e-flythis! Power Systems 6 Aug 01, 2007 09:19 PM
How to calculate the gear ratio for a gear box with teeth on the inside. sn1973 Foamies (Kits) 5 Oct 02, 2002 08:04 PM
