Old Mar 16, 2014, 11:51 PM
CPA 30, SPA 523
Timthetoolman's Avatar
United States, TX, Fort Worth
Joined Nov 2009
To explain the comment above, the Dirty Birdy was in the back seat of my pickup because my wife and I had just finished a fine day of flying on November 17 (I think) when a Grand Cherokee with (4) 16 year olds pulled across our path and we T-boned them going 40 mph.
Everyone was ok except my wife got 3 broken ribs and my DB received some minor damage. They are both still recovering.
I never knew broken ribs were so bad...no laughing, no coughing, no fun!
I was trying to figure out how much it would take to repair the DB. I finally figured out how much it would cost and I sent an estimate to repair the DB to the kids insurance and they paid last month so I've got to order some new paint and today started constructing a new wing.
The elevator got a small bit chewed out of a corner but I think I can just fix that by forming it out a bit with some epoxy and micro balloons and hand paint a touch up on it.
The other wing could have been flown with the dent but I wasn't confident it wasn't going to change the way it flies. So I was going to strip the paint, fix the dent, and repaint it so I figured why not just make a new wing.
Today I took some foam cores I had laying around and sheeted them with 1/16" contest balsa (no Kevin, I haven't pulled the trigger on 1/32" yet...soon) and added the LE and TE caps. The LE caps aren't as big as they look, they will only be about 1/8"...just found a nice stick to use and it was a bit thicker than needed.
Timthetoolman is offline Find More Posts by Timthetoolman
Old Mar 20, 2014, 11:00 PM
CPA 30, SPA 523
Joined Nov 2009
The sweet mess of success!
Think I might try Kevin's method of the LE/TE hinge line...need to find some tooth picks.
Old Mar 21, 2014, 08:39 AM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Looks super great Tim.
Jet_Flyer is offline Find More Posts by Jet_Flyer
Old Mar 21, 2014, 05:07 PM
CPA 30, SPA 523
Joined Nov 2009
Thanks Mike.
So far I'm at 5.9 and 6.1 oz
Old Mar 22, 2014, 04:25 PM
CPA 30, SPA 523
Joined Nov 2009
6.6 oz and 6.8 with gear blocks
Old Mar 22, 2014, 07:22 PM
R_G
Wanna Hover? Fly a Heli!
R_G's Avatar
United States, PA, Farrell
Joined May 2010
Very nice looking wing panels Tim!
Ralph
R_G is offline Find More Posts by R_G
Old Mar 22, 2014, 08:16 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
The round ends on the gear block are pretty cool!
Old Mar 23, 2014, 12:36 AM
CPA 30, SPA 523
Joined Nov 2009
I use a router bit to cut the slots and found it was easier to round the blocks than square the slot.
Thanks Ralph
Tim
Old Mar 23, 2014, 09:24 AM
5005 days to retirement!
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
Tim, I'm not familiar with this method. Could you explain in more detail?
Thanks, Jim
jpurcha is online now Find More Posts by jpurcha
Latest blog entry: How time flies
Old Mar 23, 2014, 10:28 AM
CPA 30, SPA 523
Joined Nov 2009
Sure, look here http://www.rcgroups.com/forums/showt...1665547&page=2
Old Mar 24, 2014, 10:34 AM
CPA 30, SPA 523
Joined Nov 2009
I managed to get the wing servo trays in this weekend and mark locations for the ailerons which I think I'm going to make them 18" x 1.5".
Everyday I get more dings on this wing, I need to hurry and glass it!
I bet if a bug flew in the door and hit the wing I'd be filling a hole!
Weight at this point is 6.95 and 6.8
Old Apr 09, 2014, 05:00 PM
CPA 30, SPA 523
Joined Nov 2009
Kevin's method worked out pretty good. Not any easier than the other methods but I feel it worked out better for getting the cap strips the right thickness...nice tip.
Old Apr 10, 2014, 11:09 PM
CPA 30, SPA 523
Joined Nov 2009
I'm getting close to finishing this wing set. I talked to Leo at KlasskoteMO.com and he has the paint so I'm going to get that on the way.
I would like to discuss finishing methods. I usually vacuum the glass on with Mylar which gives me a mirror finish but what do you guys use?
Kevin uses dope or something to seal the wood. I think Matt (MTK) was using Aquanet to seal the wood first. Ideas?
I want to keep the weight down. However I'm at the point of making it too light and too soft so...
Build Log Bluejay Dirty Birdy 60 Build ReelDoc Classic Pattern Flying 26 Apr 13, 2013 05:50 PM
Question Dirty Birdy Servos Mac333 Electric Plane Talk 11 Apr 11, 2013 12:51 PM
Discussion GP Dirty Birdy ARF Build issue Lumpy05 Classic Pattern Flying 38 Feb 09, 2013 09:25 AM
Question Dirty Birdy Servos Mac333 Competition Aerobatics 3 Jan 26, 2013 11:26 AM
Discussion Tweety Birdy/Dirty Birdy 20 Build Restarted SpadCat2000 Classic Pattern Flying 26 Dec 16, 2012 10:16 AM
