Old Jun 14, 2013, 05:09 PM
AMA 119319
United States, AL, Tuscaloosa
Joined Jul 2009
Metal vs. Plastic?
Hey guys,
Need your opinion on this. Plastic will flex, metal is stronger but will bend during a mishap. For an HK 450, What would you upgrade from plastic to metal?
Thanks!
alarcer is offline Find More Posts by alarcer
Old Jun 14, 2013, 11:08 PM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Depending on the quality, metal components don't bend as easily and resist damage better than plastic.
The plastic parts may be better suited for micro helis because the amount of kinetic energy in them can be easily absorbed by plastic, but when you go large, a plastic rotorhead would disintegrate when put under the same stress that a metal rotorhead would go through in a crash.
The trick with metal components is that they're built really strong, but are also designed to transfer the energy somewhere else. A plastic rotorhead would hit something and break, a metal rotor head is solid enough to withstand the impact, and then channel the excess to disposable components, like the feathering and main shafts.
Exactly what parts of the HK450 are plastic? The only plastic 450 i've seen in person is the KDS 450QS.
Hajile is offline Find More Posts by Hajile
Old Jun 15, 2013, 07:45 AM
AMA 119319
Joined Jul 2009
The HK450's that I have are almost entirely plastic. The main frame, tail boom, 1/2 of the swash, the tail rotor hub and the linkages are metal The rest is plastic, from the rotor head to the bearing blocks and motor mount, etc.
Old Jun 20, 2013, 08:51 AM
elan's Avatar
VT
Joined Feb 2006
Originally Posted by alarcer View Post
Hey guys,
Thanks!
-As an aside, bear in mind you can replace key components in your model with metal. For instance, you could put a Tarot metal one-piece main bearing block assembly on your model as well as a metal tail block...
elan is offline Find More Posts by elan
Old Jun 21, 2013, 01:14 PM
AMA 119319
Joined Jul 2009
That is my exact question.......What should be upgraded from the get-go, and what is okay leaving plastic?
Old Jun 21, 2013, 08:14 PM
Joined Jul 2012
Anything that spins and has to handle a lot of torque. I would say it's the Main Rotor, Tail Rotor, Swash Plate and Tail Rotor Block, in that order.
I'm not really sure if the tail boom block matters because i have a plastic one and it's still ok. It's sandwiched beween two carbon fiber plates, with six steel bolts going right through it (Really thick metal) and held in place by 12 metal screws. It's probably the most secure part of the main frame.
The part i'm worried about is the main frame, that's supposed to be carbon fiber plates, not metal. If that bends in a crash, the spinning parts are going to lose alignment.
Old Jun 22, 2013, 07:11 PM
AMA 119319
Joined Jul 2009
I have decided to upgrade just about everything. and have ordered: Head(complete with swash), tail with holder, all bearing blocks, tail boom holder, motor mount, tail pitch slider, lever and linkages, plus others. I have not upgraded the frame. If I upgrade the frame, is it worth it upgrade to a Pro version?
Old Jun 24, 2013, 04:57 AM
Andy789's Avatar
Joined Feb 2013
This trend is expanding rapidly due to the multiple benefits provided by plastics compared to metal. All of them lead to significant productivity improvements and/or product differentiation.
Regards.
Andy.
Andy789 is offline Find More Posts by Andy789
Old Jun 28, 2013, 11:22 PM
Atomic Skull's Avatar
Joined Dec 2011
I bet a single piece mainshaft block like the helioption one but in plastic would work well. Sort of like the old plastic Trex 600 mainshaft blocks with metal bolts holding the two halves together only with the upper and lower blocks combined as one single piece.
Atomic Skull is offline Find More Posts by Atomic Skull
Discussion Plastic vs Metal vs Carbon Fiber ARCHER7153 Large Electric Helis 13 Nov 06, 2010 10:39 AM
Discussion T-Rex Metal head vs. plastic slozovsk Mini Helis 12 Apr 03, 2007 01:38 AM
Question Metal vs plastic.. Cost effectiveness billyzelsnack Mini Helis 22 Oct 26, 2006 10:07 PM
Discussion X400 experiment, ccpm vs mechanical, metal vs plastic. swatson144 Mini Helis 20 Jun 08, 2006 08:55 AM
Plastic vs Metal Servo Gears? Why not both? tdriedger Electric Heli Talk 4 May 30, 2003 12:50 AM
