Old Oct 21, 2003, 07:44 PM
Sandston Va USA
Joined Mar 2001
Nemesis
Has anyone found the perfect location for the CG on the Nemesis. I'm using a PJS 300 motor and 2 340 lithiums. It glides very well when the motor is off which makes me think the CG is pretty close but it has a lot of down when flying inverted. I have to hold in some down stick to keep it level which makes it a little hairy sometimes when you are not expecting it to dive to the ground. Unlike my T3d which flies inverted just as well as right side up. If I fly my T3D first I tend to forget about the Nemesis inverted problem which makes for some pretty close calls when I first start off with the Nemesis.
busheadfox is offline Find More Posts by busheadfox
Old Oct 21, 2003, 07:55 PM
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
Mine needs a little down elevator no matter what I do. I have moved the cg way back and made sure the ailerons are completely level, but it still needs a little down.
fwilly is offline Find More Posts by fwilly
