Old Jul 03, 2002, 11:00 AM
bthomass is offline
Find More Posts by bthomass
Joined Dec 2000
2 LiPolys with Geared N20?
So, I can't fork out the $$ for the RFFS right now, but I'd really like to try something smaller. I'd like to go to an N20 geared and two LiPoly 140's (From Bob Selman) with the Feather, Jeti 040, and 2 stripped CS-10s. What I'd really like to try is the Herr 18" Cub http://www.iflyherr.com/k201.html
I don't think 1 LiPoly would be enough juice for my Servos/Rec.
Can anyone tell me if this sounds like a feasible setup?
I need a new toy...
bthomass is offline Find More Posts by bthomass
Old Jul 03, 2002, 12:25 PM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
It sounds fine assuming that you are using the HV N20.
A LV N20 may work on a single cell also.
For charging a 2-cell pack, the Potenski charger at WildRC for $27 works great!
Good luck!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jul 03, 2002, 03:30 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I have a Punkin bipe made from Dave Robelen's RC Microflight plans. See my Punkin Page. It has always been on the heavy side at 54.5 grams with 4 NiCds or NiMHs and can barely maintain altitude. So, next Saturday it gets a 2-cell LiP pack. This will save about 6 grams and boost power to the equivalent of 7 cells. Currently it has the N20-LV. Since replacing it with the HV version will require surgery on the plane, I'll fly it till the motor fries. The rest of the equipment is the Sky Hooks integrated receiver/ESC and Wes 3.0 servos. I hope these light batteries will save a failed plane that was built heavier than master builder Dave can.
BTW, I soldered up a JST harness that allows two of the LiP cells to be plugged into it making them wired in series. This weighs little and allows the best of both worlds where the same cells can also be used individually for other applications.
I'll let you know how it goes.
Gordon Johnson is offline Find More Posts by Gordon Johnson
B-2 with geared pusher/tractor, Good/Bad idea? CarreraGTSCS GWS (Grand Wing Servo) 0 Dec 25, 2004 01:56 PM
Graupner Speed Gear 600 2.8:1 Geared Motors NIB - $65 ropuri Aircraft - Electric - Airplanes (FS/W) 0 Jan 03, 2002 05:48 PM
Best sporty using 8*1650NiMH with geared Spd-300/400? mikej Sport Planes 0 Sep 18, 2001 09:03 AM
Need help with geared Mag. Mayhem set up slowflyer Power Systems 4 Aug 03, 2001 10:58 PM
480 motor with geared BB drive from Wattage... tnsfrk Electric Plane Talk 2 Jul 27, 2001 05:07 PM
