Old Jul 19, 2016, 11:24 AM
lashidalgo is offline
Find More Posts by lashidalgo
United States, NJ, Gloucester County
Joined Feb 2015
Question
How to fix broken fuselage boom mount? Nitroplanes Swift glider
Hi guys,
I recently purchase a nitroplanes swift glider which I crash on the 2 flight
Now that I have more time I wanted to fix it, but I don't know how to align the boom with the fuselage... Any ideas?
I already sanded both surfaces. Here the pictures
I've got some z proxy and fiber glass cloth to work on it.
Sent from my Nexus 6 using Tapatalk
lashidalgo is offline Find More Posts by lashidalgo
Old Jul 19, 2016, 12:08 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hmmm. You might be able to use a cardboard tube inside the boom to hold things in place until the glue sets. The tube from a roll of toilet paper, split and wrapped with plastic, just might work.
Cheers!
peterlngh is offline Find More Posts by peterlngh
Old Jul 19, 2016, 04:01 PM
Joined Feb 2015
I was thinking in making an inner fiberglass tube somehow, but the real problem here is not how you glue it, the problem is how you make sure that the boom is aligned perfectly.
Old Jul 20, 2016, 02:31 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Search for a fishing rod segment that fits perfectly inside the boom, after removing the wrecks of former pod pipe.
It is stronger than a typical glider boom, and has a slight taper, about 1 mm at 25 cm, perfect for a good friction based jointing, as the fishing rod segments are usually assembled together
Cut a piece long enough to have a solid join each side, I think 10 cm is enough, 5cm in each side.
Aligning is not an issue, use a string going from tail end to motor shaft as alignment guide.
Fit the joining piece in the boom without any glue, and glue only inside pod using 20 min epoxy with microballoons.
For my pod and boom fuselages I never glue the boom ! Just firmly fit the boom on the pipe, and tape the jointing line with 2 layers of clear tape, will never cease in flight but could act as a fuse at impact If the boom-pipe connection has a play put some layers of tape on the pod pipe until the join is made very firm only by friction.
renatoa is online now Find More Posts by renatoa
Video Repairing a broken tail boom on a full scale glider bjaffee Slope 18 Nov 26, 2015 03:03 AM
Help! How fix a broken tail boom ? lamafever Hand Launch 5 Sep 17, 2010 05:03 PM
How I fix broken carbon Boom treehog Hand Launch 3 Mar 06, 2005 03:52 PM
Suggestions on how to fix a broken CF boom? KurtMc Hand Launch 9 Sep 19, 2004 07:00 AM
how to fix a broken fuselage? mhackney Ornithopters 2 May 06, 2003 08:58 AM
