Old Feb 10, 2016, 07:38 PM
jdm85 is offline
Find More Posts by jdm85
Canada, ON, Ottawa
Joined Feb 2016
What motor and ESC combo for 56" Bi Plane 6lbs
I am looking for some suggestions on Motor and ESC combo for my 56" Bi Plane roughly 6lbs with no electronics. Rated for glow .46- .60 size
jdm85 is offline Find More Posts by jdm85
Old Feb 10, 2016, 08:38 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
To get useful advice you need to advise:
1 the max prop diameter you are able to use with ground clearance that you're comfortable with.
2 whether you are willing to use any battery voltage or have constraints on batteries, eg 4S only, not 5 or 6s
scirocco is online now Find More Posts by scirocco
Old Feb 11, 2016, 07:29 AM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
Check the recommended stats for the sig hog bipe. It's about that size.
walter3rd is offline Find More Posts by walter3rd
Old Feb 11, 2016, 01:57 PM
stagger123 is offline
Find More Posts by stagger123
United States, MA, Arlington
Joined Jun 2012
Bipe conversion
A power 42 from eflite
Or any motor putting out at least 900watts of power
Watts per pound is the easiest way to figure this out been converting gas to electric for 8 yrs
6 lbs 600 watts
100 watts a pound for scale flight
200 watts a pound is good for acrobatic
And some 3D
Go 250 watts a pound on heavy 3D planed
It's easier than you think
100 watts a pound
Good luck
stagger123 is offline Find More Posts by stagger123
Old Feb 14, 2016, 11:17 AM
DustBen is offline
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
6 lbs 600 watts
And some 3D
100 watts a pound
Good luck
200 watts per pound is for a fully aerobatic plane of unlimited potential.
150 watts will do 3D.
If he's flying a sport plane in the Sunday flier range, 110-125 watts per pound will do average aerobatics. And if he flies on the wing, rather than the prop, 125 watts will be plenty of authority for every day flying.
A lot of it depends upon personal flying style. (Recall that 30 years ago, 2 strokes made about 1/2 the thrust at the prop that they do today.)
DustBen is offline Find More Posts by DustBen
Discussion What's a good motor/ESC/batt/prop combo for the NAN Orion? Ollinator44 Electric Sailplanes 4 Dec 30, 2015 09:09 AM
Discussion What's the best motor/ESC/batt/prop combo for the NAN Orion? Ollinator44 Electric Competition Soaring-F5J/ALES/e-Soaring 2 Dec 29, 2015 09:38 AM
Discussion What's a good motor/ESC/Batt/prop combo for the NAN Orion? Ollinator44 Thermal 2 Dec 28, 2015 09:04 AM
For Sale Bi Plane 56" robertabreu Aircraft - Fuel - Airplanes (FS/W) 13 Oct 16, 2015 05:09 PM
Question what would be the best ESC+Motor combo for the Talon using a 6S battery? HuguesD FPV Aircraft 2 Mar 17, 2014 08:42 AM
