Old May 04, 2015, 05:14 PM
Sabin is offline
Find More Posts by Sabin
Every pilot has his crash
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
Wing and tail incidence
Ever since I put a plane into a tree (and the wing was severed in two, fuselage cracked in a half dozen places), I've been thinking of rebuilding it from scratch. It's a mini ultra stick, if that helps, and I was wondering what a good amount of main wing/horizontal stab incidence would be. Would two degrees up on the wing and two degrees down on the stab be sufficient?
Sabin is offline Find More Posts by Sabin
Old May 04, 2015, 06:13 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
That would climb like mad. If its fully symmetrical airfoil, 0 -0-0 works fine. If its semi symmetrical, 0 to +1 on wing, same on stab, and a degree or two of down thrust. If flat bottom wing, 0 on wing, 1-2+ on stab, 1-3 down thrust. General numbers, perfecting takes time.
mrittinger is offline Find More Posts by mrittinger
Old May 04, 2015, 08:02 PM
Sabin is offline
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
Well, I'm debating wether or not to keep the straight wing with constant chord, or go with a bit of a taper for a little more speed. I'll be using a fully symmetrical airfoil regardless. Inverted performance must match upright performance.
But if you say zero wing incidence and zero empennage incidence would work for sport flying, I'll make sure that gets into the build.
Old May 05, 2015, 04:05 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Sticks work best all set at 0*. Got three different sizes, all at 0.
Edwin
edwin1 is offline Find More Posts by edwin1
Old May 05, 2015, 07:26 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
FWIW....
The pattern guys will wind up somewhere around 1/2+ on the wing about 1ish down thrust and maybe a tad positive on the stab. Now they do have adjustable incidence on the wing and stab which makes that very much easier to change.
Here is a guide to help out http://suddenlink.net/donramsey/Hebe...20Trimming.pdf
And a little deeper into trimming
http://www.ckaero.net/blog/triangulation-trimming-2-2/
Now go drive yourself crazy
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old May 09, 2015, 11:35 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Modern pattern birds move slower than days of old too. I've found that fully symmetrical wings fly well and trim well with 0-0-0 as a starting point.
As an aside, tapering won't add nearly as much speed as cutting span and using efficient wing tips.
Old May 09, 2015, 01:59 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
Thats a really good article. Jim Kirkland's old article is good as well. Setting up and dialing in can take all summer....
Help! 4.5m Ventus 2cx; Tail Incidence & Motor Incidence paulywood Scale Sailplanes 3 Dec 06, 2013 07:58 PM
Question V tail to wing incidence - need advice CactusJackSlade Thermal 7 Jan 24, 2003 03:36 PM
Question V tail to wing incidence CactusJackSlade Slope 1 Jan 21, 2003 04:59 PM
Wing/tail incidence in a Hercules C-130 HELP!!! CESARNOGUEIRA Scale Kit/Scratch Built 4 Nov 22, 2002 10:21 AM
Increase incidence at wing or tail? JamesD Power Systems 4 Dec 20, 2001 03:53 PM
