Old Dec 05, 2012, 02:47 AM
JJ1984 is offline
Find More Posts by JJ1984
Joined Sep 2012
V911 Aileron Trim probs
Hello all,
I recieved my V911 which is a beaut to fly.
Prob i have is that it wanders to the right. I took it all apart to make sure the servo rods were equal length. I also made sure everything was finger tight, no loose screws or anything.
Took it up and the same thing. So I have to have the aileron trim maximum to the left. This shouldnt be the case so that it hovers is it?
JJ1984 is offline Find More Posts by JJ1984
Old Dec 05, 2012, 04:24 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Servo length doesn't have to be equal. The thing about the v911 swashplate is that it's offset by 45 degrees. One servo is for aeleron the other is for elevator, there is no mixing involved. So just unhook the servo that controls elevator and resize it, ignore the other servo.
Hajile is online now Find More Posts by Hajile
Old Dec 05, 2012, 06:06 AM
JJ1984 is offline
Joined Sep 2012
Arghh so me making them both the same size i prob have disrupted it.
What length should i make the elevator servo rod.
Old Dec 05, 2012, 08:24 AM
Joined Jul 2012
Whoops, i meant aeleron (aeleron = left/right, elevator = forward/back). Unhook the link for the left hand servo (Just wrap your finger around the link and pull it right off the ball.) turn it four times clockwise to shorten it, re-attach it to the swash, try flying it again. Just shorten it if it keeps going right, and lengthen if it keeps going left.
Old Dec 05, 2012, 08:31 AM
JJ1984 is offline
Joined Sep 2012
Thank you. Wicked reply. Im going to give it ago tonight. Cheers
Old Dec 10, 2012, 11:16 AM
ichibansf is offline
Find More Posts by ichibansf
Joined Dec 2006
I just got a v911 and binded it to my v939 transmitter. When I power up it immediately starts going to the right, fast. I'll try to figure this thing out using your suggestion. Thanks!
ichibansf is offline Find More Posts by ichibansf
Old Dec 11, 2012, 08:23 AM
JJ1984 is offline
Joined Sep 2012
NAd yes awesome reply. It certainly works brilliantly.
I canged the heights until it takes of and hovers straight.
WHat causes the heli to start being twitchy. I have changed blades. The tail motor sometimes struggles at low power. If i power it up its ok. Makes the heli twitch and turn left or right suddenly.
Discussion WL Toys V911 tail motor needs too much rudder trim after less than 10 flights? TapouT21 Micro Helis 26 Feb 01, 2015 05:06 PM
Discussion V911 mechanical trim? dearing Micro Helis 8 Dec 27, 2012 10:16 PM
Discussion JR X-388S aileron trim tab not working nkkromhof Radios 2 Mar 31, 2012 10:08 PM
Wanted (Aileron) Trim tab for JR X-388S nkkromhof Aircraft - General - Radio Equipment (FS/W) 0 Mar 31, 2012 07:11 PM
Discussion DX7 broken aileron trim switch evz Radios 7 Mar 22, 2012 06:14 PM
