Old Jun 05, 2013, 08:10 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Originally Posted by Granted View Post
My latest scratchbuilt
It's square with 400mm sides, 1150g AUW, Sunnysky 980s with SimonK'd F30s, a HK multiwii lite FC, two 3s 30c 3000mah batts and gets over 20min to a charge. It flies great tho the frame needs some torsional bracing.
Which props are you using? I just got four of these motors and need to get them into action.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jun 05, 2013, 08:16 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
1045 slo-fly.
Granted is online now Find More Posts by Granted
Old Jun 08, 2013, 07:02 PM
Earl E Adobtr is offline
Find More Posts by Earl E Adobtr
USA, CA, Mountain View
Joined Dec 2008
Light Weight Folding FPV H
I'm waiting for a brushless gimbal so the weight will unfortunately increase
Weight is 1311 grams as pictured
Size is 380mm x 235mm folded
Edit: Forgot to add last pic. Allows for swap out of control board/esc board/receiver modules.
Earl E Adobtr is offline Find More Posts by Earl E Adobtr
Old Jun 09, 2013, 10:10 PM
old moto head is offline
Find More Posts by old moto head
multi rotor induced O.C.D
old moto head's Avatar
United States, OR, Eagle Creek
Joined Apr 2013
i got tired of my dji 450 and needed some more room. i had some carbon fiber.. and this is what i ended up with 35x30mm motors 50/ 60 amp e.s.c open pilot cc3d.. 670 mm die angle rotor to rotor.. but overall it's a rectangle .. 385 x 540 mm
old moto head is offline Find More Posts by old moto head
Old Jun 27, 2013, 05:30 AM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Thank you to you all for sharing.
A small video QuadH wood by strong wind.
That flight
Team Red Kite Meetup in Montreux (4 min 13 sec)
eyesonsky is offline Find More Posts by eyesonsky
Old Jun 28, 2013, 01:19 AM
thinc2 is offline
Find More Posts by thinc2
Joined Apr 2013
That flight
http://www.youtube.com/watch?v=PUW9bbC1Yfo
Nice! What FC are you using - it is very stable at high altitudes when you yaw for your 360 photography.
thinc2 is offline Find More Posts by thinc2
Old Jun 28, 2013, 02:11 AM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
It is the openpilot CC3D
build log on http://forums.openpilot.org/topic/12...adh-470-wooden
she is also in the readymaderc store now
Old Jul 04, 2013, 06:30 PM
eyesonsky's Avatar
Switzerland
Joined Jul 2010
More fun with the wooden QuadH and with more power in 4S
QuadH CC3D test 4S (0 min 48 sec)
Old Jul 06, 2013, 04:37 PM
crezzee is offline
Find More Posts by crezzee
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
Love my DIY H quad:
FPV Quadcopter Racing (2 min 32 sec)
crezzee is offline Find More Posts by crezzee
Old Jul 13, 2013, 01:35 PM
floridabiker is offline
Find More Posts by floridabiker
Retired Flyer
United States, FL, Boynton Beach
Joined Nov 2011
Testing Newest DJI Firmware on my H-Quad
Testing Naza Firmware 3.14 on my Scratch Built H-Quad (1 min 31 sec)
floridabiker is offline Find More Posts by floridabiker
Old Jul 13, 2013, 10:14 PM
kenpoprofessor is offline
Find More Posts by kenpoprofessor
Multirotor geek
United States, AZ, Phoenix
Joined Mar 2013
Originally Posted by floridabiker View Post
Show me jealous, nice job
Have a great gun carryin' Kenpo day
Clyde
kenpoprofessor is offline Find More Posts by kenpoprofessor
Old Jul 13, 2013, 11:13 PM
Gregco10 is offline
Find More Posts by Gregco10
Gregco10's Avatar
Joined Jun 2012
I called this one Enderman like in Minecraft (tall skinny creepy) and it turned out to be a true monster. Rctimer 1200kv 2822 bell motors, 8" props, 30a Rctimer esc's, Multiwii Crius se, 1800mah Turnigy 3s 40c, Spektrum Dx6i. The battery sits under the flight control in the same plane as the motors to center the mass, the flight control is inline with the props, and the esc's sandwitched between the main frame halves, that leaves the bottom flat.
Those motors are very smooth and make the props sing (or as nice a song as $1.50 balanced Gemfans could possibly sing) Whatever the case, the low profile, high rpm, and small prop combo made this a blast to fly in a gusty field. It could be whipped around and flown like a plane. Turned up the yaw rate to help it rotate a little faster. It was a little power hungry though 6 to 7 minute flights. Unfortunately my confidence got the best of me and I attempted a flip which didn't end well. No major damage just lost a prop and broke the battery mounts. Enough to warrant a re-bulid though. It will fly again maybe with one of those 25a Hobbywing Quattros to clean up the wiring, the 4 30a jammies were pretty crammed in there. Sorry no video but my time with this one was short.
Description: Name: h 2.jpg
Description:
Description: Name: enderman.jpg
Description:
Gregco10 is offline Find More Posts by Gregco10
Old Jul 15, 2013, 11:12 PM
bayareaheli is offline
Find More Posts by bayareaheli
quit crying start flying
bayareaheli's Avatar
United States, CA
Joined Mar 2013
my huge H quad build
just got done welding it today
its 38 inches motor to motor with 20 inch props will be adding the motors tomorrow
bayareaheli is offline Find More Posts by bayareaheli
Old Jul 17, 2013, 11:48 AM
trickedout is offline
Find More Posts by trickedout
United States, NV, Pahrump
Joined Feb 2013
Here is the start of my first attempt to build my own frame. After destroying a TBS frame and Core I figured why not make my own frame and spend the extra $120 on other goodies... Here is the wood I picked up and the general layout I'm going after, it will be cut down of course. I saw another user on the very first page post a similar idea and I also got ideas based off the FLIP FPV and QAV400/500 to try a "dirty" and "clean" levels. I am not sure this is nessacary with wood so let me know what you think. I will use bobbins to make a third layer to mount the APM 2.5, GPS and Receiver and recording camera of choice. I had thought about battery on top but now leaning to battery underneath and running some landing gear.
trickedout is offline Find More Posts by trickedout
Old Jul 17, 2013, 03:08 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
I'm about to build an H quad and want it to have foldable legs like the one in the 4th post on this thread. It looks to me it is just friction that prevent the arms from folding in the air ? or is there something else I didn't see ?
carguy1994ca is offline Find More Posts by carguy1994ca
Discussion Steven Wang as our newest member of our GWS USA LLC. GWS4CEO GWS (Grand Wing Servo) 14 Jun 06, 2006 08:15 PM
E-Fli-owa check out our big event at our website! Goneflyin Electric Plane Talk 6 Sep 20, 2002 04:59 PM
E-Fli-owa check out our big event at our website! Goneflyin Parkflyers 1 Sep 19, 2002 08:42 AM
