Old Jul 30, 2012, 07:38 PM
packardpursuit is offline
Find More Posts by packardpursuit
Joined Jan 2009
cox engine questions
I was given a fairly large collection of model engines. Three or four being various Babe Bee incarnations. Decided to combine these with my own and have undertaken a reconditioning program of all, hopefully to running/flying(?) condtion.
First question: I've got the prop washer and threaded collar off my favorite TeeDee .049, wishing to replace the plasic carb housing. Is this threaded also or just pressed on. I've simply forgotton since mid 80's! In any event, the old collar is not coming off as easlily as I remember. Any advise?
Second Q: One of the gift engines has a muffler w/spring wraped around to adjust exhuast opening and an exhaust pipe stiking out Rt side. The cylender seems screwed right down on top opf the spring starter. Appears to have two ports in cylinder wall, one infront and one directly behind. finish is all aluminum except for fins and bronze back plate but also has stunt tank like on a GoldenBee. What engine is this?
Third Q: Another gift .o49 engine has a black plastic back plate/mount like the red PT-19 mount. It also came with a reverse pitch black prop of 4-3/8" diam. Tips are thickend, almost to knobs at the tips. The spring starter appears to have a clutch arraingment that automatically grips the prop washer (has a hex section to fit into the black plastic spring collar) when wound backwards for strarting. Also the exhaust ports are a pair of transverse slits front/back of Cylinder.. Is this a helecopter engine from one of those RTF reaction helos Cox had a few years back?
Thanks in advance
charlie
packardpursuit is offline Find More Posts by packardpursuit
Old Jul 30, 2012, 08:40 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Removing the plastic carb body requires unscrewing the Anodized ring/collar behind the prop driver..which forces the propdriver off the spline crank end More than a bit Mickey Mouse.
Yes.. it can be tough to get off.
Try not to chew it up too much, as the oem Cox wrenches are poor quality and barely up to the task expected. So be careful.
Also be sure you actually need to remove the plastic bit.
The muffler gizmo sounds like a QRC .. Works OK.. sux some power but tames the Shriek ! .. some.
Motors fitted to the ewww.. plastic barely or non flying Cox in a Box airplanes were basically Junk. Had them, felt truly cheated of my paper route earnings and lived to tell the tale.
Slit exhaust engines are best quickly disposed of on EBAY imo
Having said that some love 'em.
But then there is a customer for every perversion :-)
Bare is offline Find More Posts by Bare
Old Aug 02, 2012, 03:00 PM
ahrma_581 is offline
Find More Posts by ahrma_581
All power to the two stroke!
ahrma_581's Avatar
United States, AZ, Ajo
Joined Jun 2012
The TD crankcase where the venturi holder fits is tapered. Combined with leftover castor oil goo, the holder may take a little persuasion to remove, but it just comes straight off, no mysteries.
And yes, it is Mickey Mouse to use the collet to force the drive plate off the crank. That's why you should use a prop screw or stud and a bench vise as an improvised arbor press to take the plate off.
ahrma_581 is offline Find More Posts by ahrma_581
Old Aug 07, 2012, 05:35 PM
Norm Furutani is offline
Find More Posts by Norm Furutani
Norm Furutani's Avatar
United States, CA, Gardena
Use the vise or even a drill press, but put a block of wood behind the crankcase so it does not get marred. Also remove the piston/connecting rod. Don't lose the thin steel thrust washer.
The plastic bit slides off, but like ahrma says, it might be gummed up. Some heat like a hair dryer or heat gun will help- don't melt the plastic!
Q3- sounds like a standard product motor. This was used on a number of the ready to flies, including the helicopter. The thickened tips on the prop was meant to make the prop safer.
I like using product motors, but i toss the spring starter bits. The old style spring starter was OK, but the newer auto grabber just drags on the motor.
- Norm
Norm Furutani is offline Find More Posts by Norm Furutani
Old Aug 09, 2012, 08:15 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
Originally Posted by Bare View Post
...Slit exhaust engines are best quickly disposed of on EBAY imo
Sorry Bare, but no they're not. That slit exhaust comes with a newer type internal bypass porting that produces more power than the older non-SPI Bees that had open exhaust. Combined with a newer type short piston that allows it to have SPI(sub port induction-can be seen as a gap under the piston at TDC), they out perform the older style open-exhaust cylinders such as the pre-1996 Black Widow.
RknRusty is offline Find More Posts by RknRusty
Old Aug 10, 2012, 11:25 AM
Bare is offline
Canada
Joined Nov 2000
OK....Would be a Dull world, if we all thought similarly :-)
Not so sure about that one though.
I have a 'few' BW's from first to last (a couple of slit ex ones too).
Yup.. bought a couple, first season they came out..still have them too.
Then a 'few' more over the years.
Later ones do have a goofy looking but quite workable spring starter though...useable enough so they haven't been removed.
But my very first BW's remain as MY very best performing examples.. still :-).
Small variance in porting gouges or not, I have not seen (noticed?) advantage beyond the starters on my newest ones.
Any 'improvements' seem illusory, to me at least.
In fairness I was referring to those "product' engines.
Clearly there are those that think them worth buying.... ergo; EBay.
I do not .
Old Aug 10, 2012, 03:11 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
Also in fairness I should add, any facts I claim to know about later Cox engines refer to the ones actually made by Leroy Cox's company and not the toy rocket makers. Estes had no quality cares, throwing parts at each other, not test fitting pistons, cylinders and cranks and screwing things together that barely resembled the original engine name. Not being one of the avid collectors, I cannot eyeball an engine and tell you from when and where it originated. Yeah, many of those latest ones were carp. And many were full of metal burrs, requiring dis-assembly and inspection before the first fueling.
Discussion Question about starting Cox .049 engines halfaflyer Control Line 29 Jul 17, 2012 04:19 PM
Sold Cox buggy engines jsesere Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 15, 2012 01:28 AM
Discussion Cox engine question Mcgivern Engines 2 Apr 27, 2009 07:48 PM
