Old Jun 04, 2012, 11:25 PM
bythesea is offline
Find More Posts by bythesea
Joined May 2012
Question
Does drag scale?
I've been reading about gliding and the three main forces: gravity, lift, and drag. Drag seems pretty easier to understand. I can't move as fast and have to use more energy when I'm hip deep in water. Track stars wear smooth spandex suits. But, I was curious if it has the same effect at all scales, or is simply related to total surface area, regardless of scale.
More specific to what I'm trying to achieve, a small RC glider, how much of a factor is drag at a 28" to say 1m wingspan. I'd imagine for this really big RC gliders it matters a lot, but does it really matter for a tiny glider? That is, is reasonably smooth good enough? Or is obsessive sanding, varnishing, filling, polishing, etc. par for the course? Are we talking doing filets at every join, or "just slap it together and throw dammit!", or somewhere in between?
Thanks for answering all my noob questions everyone.
bythesea is offline Find More Posts by bythesea
Old Jun 04, 2012, 11:40 PM
glidermang is offline
Find More Posts by glidermang
For smaller airplanes, drag will be less (they fly slower, so less drag. They weigh less, so less lift and therefore, also less drag). But (and this is a BIG BUT!), the relationship between lift and drag changes as size diminishes, with drag not decreasing to the same extent as lift.
Less total drag for smaller airplanes, sure. But lift/drag ratios don't scale.
To scale aerodynamic effects, you have to wrestle with the Reynolds Number (you can find the definition in Wikipedia). Reynolds Number compares the size of an object, with the density, velocity and viscosity of the fluid it's trying to move in. For small objects in air, the viscosity starts to really change things, compared to larger objects.
I'll let others chime in, now.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Jun 05, 2012, 06:35 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Read here if you want your eyes to bleed:
http://www.grc.nasa.gov/WWW/BGH/reynolds.html
And here for a lighter explanation (not really):
http://en.wikipedia.org/wiki/Reynolds_number
And for a good read that doesn't really apply to our stuff:
http://jila.colorado.edu/perkinsgrou...lds_number.pdf
tom43004 is offline Find More Posts by tom43004
Old Jun 05, 2012, 07:31 AM
tom:
That last paper is fantastic! What a tremendous grasp of small, sticky stuff.
Thank you very much for putting up that link.
Yours, Greg
Old Jun 05, 2012, 09:55 AM
bythesea is offline
Joined May 2012
Thanks a bunch everyone. I don't mind reading until my eyes bleed at all. What's a big help is knowing the search terms to look for since knowing the correct jargon is really important. I'm sure I'll be posting more question in this thread!
Cool Look what the cat dragged in... Sid3ways Multirotor Talk 6 Apr 12, 2012 05:54 AM
Discussion Warbird drag coefficient yomgui Modeling Science 9 Mar 16, 2012 05:32 AM
Discussion Thinking about induced drag, downwash aeronaut999 Modeling Science 0 Mar 01, 2012 10:02 AM
Discussion Cutting parasitic drag, improving scale fidelity harleym Scale Sailplanes 0 Feb 12, 2011 01:30 PM
Cool full scale "Drag Queen" gyro Ron_Fikes Auto Gyros 5 Apr 20, 2010 02:58 AM
