Old Mar 19, 2012, 09:27 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Originally Posted by Kwahn View Post
Are there also 5mm hubs? Most people I know would use the KPG 25 box for such an application and a 5mm shaft seems plenty strong for F5D power.
You can easily swap out the 5mm shaft carrier for a 6mm one--the5mm just has a turned down output end if I recall. Thet both have 6mm where it enters the bearings.
Steve
sneu is offline Find More Posts by sneu
Old Mar 19, 2012, 11:23 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by sneu View Post
You can easily swap out the 5mm shaft carrier for a 6mm one--the5mm just has a turned down output end if I recall. The both have 6mm where it enters the bearings.
Steve
No. The KPG25 shaft is 5mm all the way through the bearings.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Mar 19, 2012, 02:43 PM
schnepf is offline
Find More Posts by schnepf
Joined Nov 2011
Hi Georgi,
You have to clear your messages your account is full.
BR
Christian
schnepf is offline Find More Posts by schnepf
Old Mar 24, 2012, 03:06 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Steve,
No one has asked you the obvious question!
Does Neu have a motor/gearbox combinations that would be suitable to use with these GM props on 5 cells that also fits inside the fuselages of the common F5D models?
If Neu doesn't have anything yet, is it a priority at Neu to develop such powertrains?
Thanks in advance!
Peter
Peter M is offline Find More Posts by Peter M
Old Mar 25, 2012, 04:34 PM
big bruce is offline
Find More Posts by big bruce
big bruce
Joined Jul 2011
Originally Posted by Peter M View Post
Steve,
Thanks in advance!
Peter
I have some NEU 2800Kv with 4.4 maxxon gear boxes already ont he way from USA to me to try. As wella s the Leomotion 4200 Kv with 6.7 box that is running very nice!
big bruce is offline Find More Posts by big bruce
Old Mar 25, 2012, 05:12 PM
big bruce
Joined Jul 2011
Sounding like we won't see many direct drive in Romania this year !
Old Mar 26, 2012, 08:53 AM
markusvt is offline
Find More Posts by markusvt
215.0 MPH
markusvt's Avatar
United States, VT, Essex
Joined Jul 2007
What mod would you have to do to the X-Plane for this to fit?
Originally Posted by Dbox View Post
Now I have to make Neu fuse mold for the X-plane to accommodate 30mm spinners.Wonder,what current to expect with same motor set up and new props?Looking forward to easy launches without torque roll.
Thanx Steve for the good news.
Yuri.
markusvt is offline Find More Posts by markusvt
Old Mar 26, 2012, 10:33 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
To make a longer fuse nose cone with 30 mm in diameter at the end.
But decided not to bother as to fit NEU P32 box or even 27mm KPG 27 gearbox will be a challenge for the guys .
It would be easier and more practical to make these props with either 32mm -36mm spinners.With 5 and 6 mm shafts.In this case,You can cut the nose cone shorter.I would be first in line to buy then.
Now we have to beg Georgi ,which is not an easy task
Yuri.
Dbox is offline Find More Posts by Dbox
Old Mar 26, 2012, 11:02 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
If you try to get to anything much larger than a 32mm spinner-- a new blade will be needed. If you simply put a larger hub on it the diameter and pitch will be wrong.
Steve Neu
Old Mar 26, 2012, 11:04 AM
GeorgiMirov is offline
Find More Posts by GeorgiMirov
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
I will now make a fast simulation to see how props will fold to a 33mm fuse.
Here you go :
Not good at all. As Steve says , things are not that easy , and only putting a bigger spinner cone will not do the job.
GeorgiMirov is offline Find More Posts by GeorgiMirov
Old Mar 26, 2012, 12:32 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Then they have to be 5mm shafts .
KPG 25 is 25 mm diameter and will fit 30 mm nose cone .
But all KPG 25s have 5 mm shafts.
Yuri
Old Mar 26, 2012, 05:04 PM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Georgi,
What options do you recommend to adjust and finetune runnig-time in competition?
I assume there will be a big step between 10x23 and 11x22?
It looks like there is no option to change like -1,0,+1 Hubs?
Regards
Yello
Mreyello is offline Find More Posts by Mreyello
Old Mar 26, 2012, 05:09 PM
big bruce
Joined Jul 2011
I am currently drawing hubs to be machined for the folding blades. At first I was planning +2 and -2 and see what difference it makes, then I can do +/- 1 or 4, depends what is needed.
I have a very busy April, but hope to have these done in May.
Bruce
Old Mar 26, 2012, 05:20 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Bruce,
I think 4 will be too much,the big folders seem to be pretty senitive, if pitch-progress is not perfect,efficiency will drop much more compared to the small cam-props which can be twisted easy without much eta disadvantage.
Yello
Old Mar 26, 2012, 05:34 PM
big bruce
Joined Jul 2011
OK, so I start with just +/- 1 and 2 degree twist and see how it works.
For Sale Stratair viper f5d pylon racer very good condition xzatx Aircraft - Fuel - Airplanes (FS/W) 0 Feb 06, 2012 07:08 PM
Sold Voodoo F5D Pylon Racer - brand new, mint condition SPasierb Aircraft - Sailplanes (FS/W) 2 Jan 09, 2012 09:09 PM
Wanted Sobakin Stinger 400 , simular speed 400 pylon planes/f5d/ds buildbuildbuild Aircraft - Sailplanes (FS/W) 3 Dec 22, 2011 11:38 PM
Discussion USA F5D Pylon Team selection contest! sneu High Performance 17 Oct 25, 2011 09:14 AM
Sold Collection of pylon F5D props verticalflight Aircraft - Electric - Power Systems (FS/W) 3 Aug 02, 2009 09:39 PM
