Old Feb 17, 2010, 02:24 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Question
Gluing Kfm Layers
I'm making a 32" 3D plane from 6mm Depron and want to place a KFm2 type layer on the wing.
What would be a good glue to secure the layers of 6mm Depron together?
Paul
FlyingW is offline Find More Posts by FlyingW
Old Feb 17, 2010, 06:07 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I use hot glue. I squirt the glue around the edges and a few swipes in the center area, and press the parts together. Obviously, you got to do this fast so the hot glue doesn't cool off.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Feb 17, 2010, 06:46 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
You are a far braver man than I, rusty!
I use PU. Very thin layer. Lots of weights - about 60 lbs of bar bells - set on a board on top of the wing section.
philba is offline Find More Posts by philba
Old Feb 17, 2010, 07:22 PM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Norway
Joined Feb 2010
I'm fairly new to foam building, but I have fallen in love with UHU-POR foam safe contact adhesive (sometimes called uhu-por Creative).
Spread it thin on both parts, let it dry until it's set but still tacky, five minutes usually does it, then join the parts. It remains slightly flexible, so it won't crack or flake like CA. You can even make hinges from it, by spreading it thinly over the flat side of a bevel-cut.
Once the parts touch, they're stuck, so you'll have to get it right the first time. For gluing my 42" Divinity wing with KFM airfoils, I laid the parts next to each other, glue side up, and used a couple of tape pieces as hinges, ensuring that that edge lined up perfectly.
meshyx is offline Find More Posts by meshyx
Old Feb 17, 2010, 07:38 PM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
philba... Its the only glue I had other then epoxy. I now have Gorrilla glue, but never tried it yet. Hot glue does fine, but you got to move fast!
Old Feb 17, 2010, 08:25 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
I've done hot glue on smaller surfaces, the pu glue is great, but I also like the 3M Super 77 adhesive spray. The Elmer's brand is not as good as the 3M. You need just put a thin layer on both halves, let it dry up a bit (about 5 to 10 minutes) then put them together. Make sure you line it up right, because you may only get one chance depending on how dry the glue has set up. I have also used fabric tac from Walmart, but don't care for it for this purpose.
Daddy-O
One more thought, if you use the pu glue, you really need to make sure the top layer is evenly weighed down with some heavy weights, because it will try to expand in the middle and will deform your two pieces somewhat if not weighed down good.
Daddy-O is offline Find More Posts by Daddy-O
Old Feb 17, 2010, 10:51 PM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
Oh yeah, learned that the hard way. also, don't take the weight off it too soon - it will surprise you.
Old Feb 18, 2010, 09:01 AM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Thanks guys,
I will try white Gorilla Glue. I've been using it ofr other stuff and like the way it performs.
Take care all,
Paul
Old Feb 18, 2010, 09:22 AM
Stef is offline
Find More Posts by Stef
Flying Saucer Mechanic
Stef's Avatar
Middle River MD
Joined Dec 2000
gluing foam
water based contact cement works well to.
Stef is offline Find More Posts by Stef
Old Feb 18, 2010, 11:19 AM
Daddy-O is offline
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
Yep, I forgot about that stuff - very good if allowed to get tacky before putting the pieces together. It's been awhile since I've used it though. I had a bunch here a long time ago. I wonder what I did with that...
Daddy-O
Old Feb 18, 2010, 01:42 PM
Rolland Benson is offline
Find More Posts by Rolland Benson
United States, MI, Parma
Joined Aug 2006
What brands of water based contact cement have you been using? I have had little success with these to date. It may be I am applying them improperly, possibly not letting them tack up eneough.
I was spoiled by the UHU foam contact ement that is no longer in my area. It is way to expensive to order in so I need a goo alternative.
The PU Elmers is what I have been using of late and I have to agree it works very good with no seperation a few months after application. I have also gotten to spreading it alot thinner than what I thought would work originally. Less is better especially if you are trying to avoid that foam up at the seams like on a Kfm wing when you glue the laminations up.
Rolland Benson is offline Find More Posts by Rolland Benson
Old Feb 18, 2010, 02:05 PM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
Yeah, It's taken me some time to really believe that a super thin layer of PU is all that's needed. I'd say that you need 1/3 to 1/4 of the amount of other glues. But that means a lot less weight from the glue and you still get a bond that is stronger than the foam. That's why PU is my favorite glue.
Old Feb 18, 2010, 08:33 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
PU is my first choice, Gorilla Quick specifically. It is about all I use any more. And make sure to go by the Garden Department and grab a small plastic plant misting bottle. The water is what wakes up the foaming action on PU and it will not be anywhere near as good without it.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 18, 2010, 08:44 PM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
Jack
I like gorilla glue too. I put it on thin and use an old credit card to squeegee it around to cover the whole gluing surface. Make it super thin than hit the layered piece with a spritz of water.
heymak is offline Find More Posts by heymak
Old Feb 24, 2010, 08:43 AM
Stef is offline
Stef's Avatar
Middle River MD
Joined Dec 2000
Gluing foam
I like the polyurethanes also but if the surface is shiny like depron or has a film on it like FFF poly glue will pull away or peel off. Sanding or small holes in the surface to give it "bite" is needed to insure a good bond. As for water based contact adhesive just follow can directions to the letter. You have to let the surfaces dry and as soon as they don't stick to your fingers put the 2 surfaces together and be careful of alignment
Discussion ** Kline-Fogleman (KFm) Airfoils - Building/Flying Discussion ** jackerbes Foamies (Scratchbuilt) 8369 Yesterday 02:28 AM
Question adding color btwn layers of the laminate film grfcon Slope 7 Jan 15, 2010 04:10 PM
Discussion Layering fanfold layers? Pongo Foamies (Scratchbuilt) 13 Oct 08, 2009 03:36 PM
Question gluing kevlar also gluing carbon fiber sheeting garthebar Sailplane Talk 4 Mar 07, 2004 06:23 AM
