Old Feb 01, 2013, 10:52 AM
United States, NY, Homer
Joined Nov 2006
Help!
Need a lipo battery recommendation
I have a seagull extra 260 63" span. I will use it for just sport flying and not 3d. It has a electrifly rimfire 80 and a CC talon 90 esc. I do want to run the servos off the bec since the esc is capable of it. My question is since i have not bought any batts for it yet what do you guys recommend as far as c rating and mah? I want to run 1 6s pack in this plane insted os 2 3s packs.
hoofhearted is offline Find More Posts by hoofhearted
Old Feb 01, 2013, 11:42 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
If your not flying 3D, I'd go with a 4000mah/ 30C/ 6S or even a 5000/6S/30c.
They supply good power for reasonable flight times and still be easy on the battery. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Feb 01, 2013, 12:20 PM
Joined Nov 2006
Thanks, Do you think I can get 2 5min flights from a 5000mah on one charge depending on throttle management?
Old Feb 01, 2013, 03:50 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
i think you would have to do a battery management check first to see if you can get 10 mns on a pack and check how many mahs go back into your battery, your trying to save a few bucks by not buying to many packs i take it,, i have a 40 size stick plane using 4 cell 4000 packs and can get 2 good 4 mns flights just like your thinking.
scottc39 is offline Find More Posts by scottc39
Old Feb 01, 2013, 04:13 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
I fly a similar size but bit lighter (under 8lb) Wind S 50e pattern model on 6S 5000, with minimal use of full power, which is around 1200W. I have my timer set for 7 minutes, and recharge about 60%. Considering discharge more than 80% is bad for the battery, and power drops off a fair bit in the last third or so of capacity, I think 2 x 5 minute flights on a single 5000 pack might be a bit optimistic. It'd probably take throttle management to the extent of just puttering around the circuit. I know it's a bit of an expense, but getting an extra pack or 2 and treating them gently is probably better value in the long run. BTW, mine are nothing fancy, just HK Zippy 25 or 30C.
scirocco is online now Find More Posts by scirocco
Old Feb 01, 2013, 05:43 PM
Joined Nov 2006
Thanks, That helps alot. Not trying to cheap out on batts, My field has no power so 4 flights with 2 packs would work out good.
Old Feb 01, 2013, 06:25 PM
scirocco's Avatar
Joined Feb 2001
I hear you on the recharge with those big packs at the field. I take 3 and that's it for that model. But I usually take 2 or 3 other modelss as well so that's plenty flying.
Help! Electric Retract recommendation needed Bombay Flight Accessories 7 Jan 31, 2013 06:24 PM
Discussion DA-50 Ignition Battery Recommendations ognolman Giant Scale Airplanes 4 Jan 23, 2013 01:13 PM
Question Can Anybody Recommend A Good 3s Battery? 08charger3.5 Off-road Cars 11 Jan 15, 2013 10:10 PM
Help! I need a control rod recommendation BigIron357 The Builders Workshop 10 Jan 11, 2013 08:06 AM
LiPo Batteries: Recommendations Trek2120 Batteries and Chargers 11 Jul 27, 2004 07:18 AM
