Old Jan 18, 2005, 12:08 PM
Basil is offline
Find More Posts by Basil
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
Originally Posted by Mat
Sorry basil for that comment.
Can anyone give me a very breif explanation on how the winding of the coil effects rpm and torge.
Hey, I didnt take any offense to the comment, was I suppose to I have no idea how these motors work, to learn the windings, turns, etc, is a whole other hobby and I dont have any more spare time..
For any more specs, goto Balsapr.com and look under brushless motors for all the specs..
Basil is offline Find More Posts by Basil
Old Jan 18, 2005, 02:42 PM
Mat is offline
Mat
Find More Posts by Mat
Mat
The ground jumped at it!
Mat's Avatar
Ohio
Joined Jun 2004
As the plane starts going faster will the ampdraw decrease a little bit compared to the static amp draw?
Mat is offline Find More Posts by Mat
Old Jan 18, 2005, 02:59 PM
BrianRickman is offline
Find More Posts by BrianRickman
Marlborough, Massachussetts, United States
Joined May 2002
Mat,
Usually the in-flight amp draw is lower, though the Motocalc simulator shows it increasing slightly in flight with very high pitch props, i.e. 7x6 or 7x7. Amp draw will certainly be lower in flight if you use something less then full throttle.
BrianRickman is offline Find More Posts by BrianRickman
Old Jan 18, 2005, 06:37 PM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
Do the motors come pre-mounted to the GearBox?
Old Jan 18, 2005, 09:33 PM
RonD is offline
Find More Posts by RonD
Rochester,MN
Joined Feb 2001
If the prop is stalled in static testing, the current may go up when the plane picks up speed. If the prop is not stalled the current will go down as the prop unloads.
The motors come mounted to the gearbox, although it's not really a gearbox, it's just a gearbox frame used as a mount.
RonD is offline Find More Posts by RonD
Old Jan 18, 2005, 11:38 PM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
Rought Row, THE SAGA Continues...
Went to the (NOT SO) NSLHS to exchange out my combo. No problems there...However, my new setup didnt come mounted to the gearbox although it did come with the tiny scews and nuts. (no biggie) BUT----The gearbox didnt come with any holes so I switched to a GWS box and the holes in the silver mount do not come close to aligning. I am only able to align the bottom hole.
I wish I took a picture of the 1st setup, b/c the motors are very different...The 1st's shaft was much much longer, the silver upside down bowl was larger, and there was no black nut after the silver bowl....Other than that it works but I havent given WOT yet and have no way to stick mount it.
Old Jan 19, 2005, 07:07 AM
94ZA4 is offline
Find More Posts by 94ZA4
WWW.AWLHOBBIES.COM
Elmira Regional, New York, United States
Joined Jul 2004
Mine did not come mounted either. If you look at the holes in the aluminum mount they are an offset triangle. The top hole goes in the hole where the stick goes. This puts the shft right over where the shaft would normally exit. Then just notch or drill little holes in the plastic mount where the holes line up. Install and you are all set. A little bit of a pain, but not that bad.
94ZA4 is offline Find More Posts by 94ZA4
Old Jan 19, 2005, 07:14 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Being an old 1/2A flyer ,I kinda ' appreciate the firewall mount ...very compact and easy to use... don't get me wrong , I like the stick mount ,but in this case it is a bit unusual .... firewall is simply a plywood circle glued to the stick ...hahahahaha Works!!!!! try it , you'll like it .....
gpw is offline Find More Posts by gpw
Old Jan 19, 2005, 07:41 AM
Ecaf is offline
Find More Posts by Ecaf
Heli Addict....
Ecaf's Avatar
West Dundee, Il.
Joined Nov 2003
Ill second that. After getting mine, I immediately put it onto a firewall mount. Some 2-56 bolts and blind nuts and I was all set. Works great.
TB
Ecaf is offline Find More Posts by Ecaf
Old Jan 19, 2005, 07:45 AM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
OK, it was no big deal, however, Im just trying to compare what my LHS has compared to what everyone else has.. I mounted it just as 94ZA4,
1st setup came pre-mount with all the nuts/bolts already installed... Without having more than 1 to compare im in the dark here...
Old Jan 19, 2005, 07:49 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Ecaf , you bet !!! All we need now is a simple firewall/assembly as universal as the stick system... ply circle and triangle would do it ...mount perfect on a profile anyway , that's always the hangUP...
Old Jan 19, 2005, 09:54 AM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
How much longer can I extend the leads from the motor/esc? Is there a preferred side to lengthen? I need only about 2-3 inches.
Old Jan 19, 2005, 09:06 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Gpw how about the 3/8" mounting square with just a flat plate on the end. They make an aluminum version of the GWS box so someday maybe one similar for what we need??
TM
JAM is offline Find More Posts by JAM
Old Jan 20, 2005, 06:42 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Tow ... that would probably work fine .... this motor has the same radial mount as all the other cool outrunners and those charge extra for the mounts too....
Old Jan 20, 2005, 10:55 AM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
One nice thing about firewall mounting - its easy to shim for right-thrust or down-thrust by slipping a washer or two onto the appropriate bolt between the motor and firewall. It's a lot harder to change the thrust angle with a stick-mount, once it's been glued into the fusleage.
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
$24 brushless motor - $49 with speed control part II arx_n_sparx Foamies (Kits) 310 Dec 13, 2005 06:36 AM
For Sale Hacker A20 Brushless motor & Hacker X20 Speed control Beaver1 Aircraft - Electric - Power Systems (FS/W) 2 Oct 31, 2005 01:26 PM
astro 020 brushless motor with speed control jeffery arthur Aircraft - Electric - Airplanes (FS/W) 5 Feb 21, 2005 07:16 AM
55 dollars brushless with speed control! SAVE YOUR MONEY.. Basil Power Systems 15 Jan 19, 2005 09:44 AM
Brushless Motor with Speed control for $89 shipped CONUS BrunswickOH Aircraft - Electric - Airplanes (FS/W) 7 Apr 18, 2004 07:07 AM
