Old Jan 16, 2005, 08:25 AM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
I dont think it will be a problem but you could work the set screw in and out a few times which will indent it into the aluminum.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Jan 16, 2005, 09:01 AM
BrianRickman is offline
Find More Posts by BrianRickman
Marlborough, Massachussetts, United States
Joined May 2002
Zagnutz flies with BP21
I took my new Zagnutz out this morning for a test flight. It has the following equipment on board:
BP21 motor/ESC combo
GWS 8x4HD prop
2 HS-81 servos
Hitec 555 receiver
CBP 1100Mah NIMH 10 cell battery pack
AUW 28 ounces
It is louder then I expected, but not unresonably so. I would not fly it near any houses early in the morning. It has plenty of power. I spent most of the flight at 50% throttle and was able to do loops and rolls after a slight dive at that setting. Power was substantially reduced after 6 minutes so I brought it in. I think the short flight was due to the battery being new (cycled once before this flight) and the cold temperature (22 F). After the flight the ESC and motor were both cool to the touch, and the battery was slightly warm. Overall, I'm quite happy with this setup.
BrianRickman is offline Find More Posts by BrianRickman
Old Jan 16, 2005, 09:16 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Brian: Is the noise from the prop or the motor?
If prop noise, trimming the TE away from the motor will reduce it.
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 16, 2005, 09:30 AM
Joined May 2002
The noise is from the prop. The first time I ran it up I was shocked at how loud it was, so I cut away a fair amount of the trailing edge around the prop and that reduced the noise level by half, but it's still louder then a GWS 350 gear motor with a 10 inch prop in a Beaver. It's also a bit louder then a Unicorn with a Speed 400 and Gunther prop, but not as loud or annoying as a stock Zagi. I think part of the noise problem is that the hollow airframe amplifies the sound.
Old Jan 16, 2005, 09:45 AM
Basil is offline
Find More Posts by Basil
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
When it runs , its smooth and quiet, but when I add throttle from anything below 100% to 100% is the stractcingproblem..Like its getting stuck or something...But this doesnt explain the 4 secs of hesitation from 0% to anything...
I gently tugged the solder connections going to the motor and all seem fine...Later on after church, Ill examine the battery and esc connections...By I highly doubt that is that...Im going to a friends house later to test it out..He has several Brushless setups so we can switch out the motor and esc to narrow the problem...
Editoral...Im not upset at BalsaPR, Im counting on their Customer Service.....Just frustrated my 1st brushless experience is less than satisfactory..
Basil is offline Find More Posts by Basil
Old Jan 16, 2005, 09:50 AM
Mat is offline
Mat
Find More Posts by Mat
Mat
The ground jumped at it!
Mat's Avatar
Ohio
Joined Jun 2004
Maby you end point adjustment on your transmitter is giving your esc an odd signal.
Mat is offline Find More Posts by Mat
Old Jan 16, 2005, 10:42 AM
Joined May 2002
Zagnutz pics
Here are pics of my motor mount and the whole plane. The motor mount is a wedge shaped block of EPP foam with a bit of plywood glued to the back. The battery is mounted across the point of the nose, which is why I have a big coroplast flap wrapped around the front of the plane.
Old Jan 16, 2005, 11:18 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
And here's a new one!!!
FB BOB just got a BP21 for Christmas... He put it on his "and WattNot" and proceeded to fly it into the fence WOT...... Everything was OK(the airframe, thank you Blucor) but the motor wouldn't turn over.... he Panicked , but we went back to the shop where I took the motor apart and found one of the leadout connections , before it went into the f/glas plate from the coils, had shorted to one of the coils(tiny silver marks on a couple windings) .... a bamboo skewer forced the offending wire away from the coil and Bingo .... it was running again, just FINE!!!!! ..... these motors are so simple ,it can only be a few things ..... try rewinding a j250 ...
New technology always has a few bugs , good thing we have so much communication to work them out.....Patience!!!!
gpw is offline Find More Posts by gpw
Old Jan 16, 2005, 11:47 AM
Foam rules
HdG Md.
Joined Jan 2003
Basil, remember who is going to look at your motor ESC when you shoot off like this before asking for official customer service.
http://www.rcgroups.com/forums/showthread.php?t=322770
Anyway, if it still is giving you problems send both in with a note, address. I'll take care of it.
Old Jan 16, 2005, 12:01 PM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Yep Yep!
If you dont have the time to test his motor Tog, just send it to me and i will be glad to test it
ewo
ewo is offline Find More Posts by ewo
Old Jan 16, 2005, 12:23 PM
IA-Flyer is offline
Find More Posts by IA-Flyer
IA-Flyer's Avatar
United States
Joined Nov 2003
Thanks for the insight Thatovalguy,
Personally, I hope people will continue to share their experiences (good or bad) with a product or company.
Even if it is hinted that they will receive reduced service quality if they do so.
But I do understand your frustration.
Jim
IA-Flyer is offline Find More Posts by IA-Flyer
Old Jan 16, 2005, 12:58 PM
68Strat is online now
Find More Posts by 68Strat
It's not a darn drone!
68Strat's Avatar
United States, MA, Andover
Joined Jun 2004
These brushless motors, really dont seem that powerful to me..
68Strat is online now Find More Posts by 68Strat
Old Jan 16, 2005, 01:19 PM
Foam rules
HdG Md.
Joined Jan 2003
Its just to pick the wording better as we all read these threads for the info, good or bad. Its just that wording like that before asking for support is out of line when he may only be the half persent with a bad one. Remember we've sold tons of them.
Old Jan 16, 2005, 01:28 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Mail him a box of tissues. My god it's not like you guys have spent 200 bucks on these little motors. Ive got three BP21's and one esc and all have been tested and work fine all the way up and down,7 volts to 11 volts.TOG did all of us brushless virgins a favor by introducing us to these. And for that I thank him.
TM
JAM is offline Find More Posts by JAM
Old Jan 16, 2005, 01:31 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
TM
Ditto
But i aint no virgin
ewo
$24 brushless motor - $49 with speed control part II arx_n_sparx Foamies (Kits) 310 Dec 13, 2005 06:36 AM
For Sale Hacker A20 Brushless motor & Hacker X20 Speed control Beaver1 Aircraft - Electric - Power Systems (FS/W) 2 Oct 31, 2005 01:26 PM
astro 020 brushless motor with speed control jeffery arthur Aircraft - Electric - Airplanes (FS/W) 5 Feb 21, 2005 07:16 AM
55 dollars brushless with speed control! SAVE YOUR MONEY.. Basil Power Systems 15 Jan 19, 2005 09:44 AM
Brushless Motor with Speed control for $89 shipped CONUS BrunswickOH Aircraft - Electric - Airplanes (FS/W) 7 Apr 18, 2004 07:07 AM
