Old Jul 19, 2015, 07:32 PM
xchampkevin is offline
Find More Posts by xchampkevin
United States, CA, Walnut
Joined Nov 2014
Need help! Genesis
I recently just got a genesis rc boat from hk. After lubing the driveshaft and putting it back in, I tested in my pool. The propeller became loose. I removed it and the metal thing with the propeller (what is it called?) in the strut looks like thhe inside is stripped. What should I do? Thanks
xchampkevin is offline Find More Posts by xchampkevin
Old Jul 19, 2015, 10:01 PM
Harquebus is offline
Find More Posts by Harquebus
I see all your typos
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
"Metal thing with the propeller": Prop shaft or the tube (e.g. stuffing box) the prop shaft rotates in?
It looks like the threads on the drive shaft are damaged or "stripped". If it's not too bad, reinstall the propeller and secure it with Loctite....
Harquebus is offline Find More Posts by Harquebus
Old Jul 19, 2015, 10:58 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
The harden tail shaft has come unsoldered from the cable drive. It has to be silver soldered back to the cable in order to work.
frankg is offline Find More Posts by frankg
Old Jul 20, 2015, 03:57 AM
Harquebus's Avatar
Joined Jan 2006
Good eye. I needed better photos and/or description but it was no small feat for FrankG.
Old Jul 20, 2015, 05:14 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
If I'm not mistaken, the flexshaft on the Genesis has a square end which fits in the endpiece, no soldering involved.
Lacking better pictures, it seems to me the drivedog hasn't been secured on the endpiece.
The setscrew should sit on the flat section, preferably secured with a drop of nailpolish.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jul 21, 2015, 02:07 AM
Joined Nov 2014
Sorrry, about the bad pictures, it's my dad's boat and I didnt have time. I didnt see any set screw on the driveshaft. We tried to squeeze it on to the flexshaft, but it just cracked. The inside is also stripped, so where could I get a new one? Thanks.
Old Jul 22, 2015, 02:44 AM
Banana37 is offline
Find More Posts by Banana37
Joined Jul 2015
http://www.hobbyking.com/hobbyking/s...ngth_1pc_.html
Banana37 is offline Find More Posts by Banana37
Discussion need help regarding GENESIS OFFSHORE BRUSHLESS RC TWIN HULL (1045MM) wdac Dock Talk 0 Jul 05, 2015 04:34 PM
Discussion Advice needed Outer Limits/Smash Shark/Genesis Glondar Racing Boats - Electric 51 Mar 29, 2015 01:55 PM
Help! Genesis Stock 3S setup Any Good? This is for a school project. Need HELP ASAP please! bbrc77 Racing Boats - Electric 2 Aug 13, 2014 07:57 PM
Discussion looking for help to reinforce my genesis blklifeguard Racing Boats - Electric 0 Aug 05, 2014 06:02 PM
Discussion Need help with genesis set up Big phil Racing Boats - Electric 18 Mar 05, 2011 07:35 PM
