Old Apr 19, 2015, 02:10 AM
felixx is online now
Find More Posts by felixx
crash expert
New Zealand, Canterbury, Christchurch
Joined Apr 2014
dollar tree foam bipe
So if I was to build a smallish (indoor and calm day bipe) out of dollar tree foam, what would you folks recommend?
I am a beginner - intermediate builder.
Foam safe CA is hard (for me) to find in NZ, so will mainly use PVA, Hot glue, and gorilla glue.
Glenn
felixx is online now Find More Posts by felixx
Old Apr 19, 2015, 02:11 AM
crash expert
Joined Apr 2014
PS I have 4 sheets of Adams Board, this is like gold over here
Old Apr 19, 2015, 02:32 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Backyard Bipe 26" span
http://www.rcgroups.com/forums/showthread.php?t=1046798
10 g motor
Bipie
http://www.rcgroups.com/forums/showt...ighlight=bipie
JJ Biplane
http://www.rcgroups.com/forums/showt...Jupiter+Junior
Ultimate
http://www.rcgroups.com/forums/showthread.php?t=620974
Scratchbuilt Paleo Pitts, wing span 30", prop 9x4.7, battery 3S 850 mAh
http://www.rcgroups.com/forums/showthread.php?t=2324576
Cheap Bipe
http://www.rcgroups.com/forums/showthread.php?t=1061900
OSB the One Sheet Bipe - springer
http://www.rcgroups.com/forums/showthread.php?t=1368918
Span 30" 1700KV 24gm Blue wonder motor, 7x6 sf prop (or 8x4.3, but the 7incher flys better), 12amp esc, 2s 800mah pack. She uses a HK V1 2.4 setup with 5gm Hextronik servos. All up weight less battery comes to 7.5oz for the swept wing V2 with landing gear and cowl.
ZimmyBipe
http://www.rcgroups.com/forums/showthread.php?t=2394907
Mac50L is offline Find More Posts by Mac50L
Old Apr 19, 2015, 03:14 AM
crash expert
Joined Apr 2014
Thanks Sandy, I know you are building a Bipie, it inspired me..
Old Apr 19, 2015, 03:55 AM
Mac50L is offline
Joined Oct 2011
All part of the service (databases).
I could trace off what I have if you wish though waiting until it flies might also be a good idea. At next indoor flying, traced off plan that is?
A biplane can be a little more fiddly as if using 4 ailerons, there's linkages plus, obviously, twice as many wings. Not sure what the almost doubled area does to wing area vs weight calculations but it could make for a reasonable wing span with a big wing area for indoor.
Anyone got the calculations?
Now if you go triplane as at the airshow two weeks ago with near a dozen Fokker triplanes, there really was some lift.
Old Apr 19, 2015, 03:57 AM
crash expert
Joined Apr 2014
I think RET will be ample for me.. I just installed a heater in my shed.. About to make a collapsible work bench! Winter plane builds.. gonna be great!
Old Jul 06, 2015, 06:26 AM
RcPro97 is offline
Find More Posts by RcPro97
Joined Nov 2014
I'm from Christchurch too! Where do you guys get ur foam from? I have looked heaps foe a place that sells foam good for building. Thanks.
RcPro97 is offline Find More Posts by RcPro97
Old Jul 06, 2015, 07:34 AM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
As mentioned on the build thread, i added ailerons to the OSG bottom wing only, and have plenty of authority for normal flight to mild acrobatics. I wouldn't bother with the upper wing ailerons. Leaving top wing plain also allows swapping top wing to bottom and making it into a RET monoplane - kinda fun at an indoor venue. "Didn't you just fly that plane with two wings???"
springer is online now Find More Posts by springer
Old Jul 06, 2015, 05:03 PM
crash expert
Joined Apr 2014
Hi RCPro what part of churchur are you in?
Old Jul 06, 2015, 06:01 PM
Mac50L is offline
Joined Oct 2011
The Tiger Moth only has ailerons on the lower wing. Personally, on the Bipie, I went for upper and lower ailerons though rolls still aren't all that fast. Add lots of rudder and they go wild.
RCPro I sent you a PM.
Springer, I hope the dollar here doesn't keep dropping as it will make foam even more expensive, might cost $6 for an airframe...... Though the Bipie with more bits must cost up towards $9 A cup of coffee is getting more expensive than a plane sometimes
Old Jul 07, 2015, 09:05 PM
RcPro97 is offline
Joined Nov 2014
South brighton
Old Jul 07, 2015, 10:13 PM
Mac50L is offline
Joined Oct 2011
Originally Posted by RcPro97 View Post
South brighton
Have you read my private message to you?
Old Jul 08, 2015, 03:29 AM
crash expert
Joined Apr 2014
I suggest an RCGroups chch meet to discuss bipes and foam.
I am in Casebrook so I am in the middle
So I am offering my place.
Build Log Dollar Tree Foam ... EZ-Jets Lockey Foamies (Scratchbuilt) 903 Today 04:13 AM
Discussion Dollar Tree Foam Board Woes anitelite Foamies (Scratchbuilt) 31 Apr 18, 2015 07:13 AM
Question How to cut dollar tree foam fast and easy ? Umair.f Foamies (Scratchbuilt) 11 Feb 24, 2015 01:01 PM
Video FT Kraken Dollar Tree Foam Board Flight budkeywest Foamies (Scratchbuilt) 1 Jan 02, 2015 07:16 PM
Question A Few Questions About Dollar Tree Foam Board? Suixle Foamies (Scratchbuilt) 15 Dec 19, 2014 12:58 PM
